Question about Zanussi TC7102W Electric Dryer
Drier wont heat up when used - Zanussi TC7102W Electric Dryer
  • 45 Answers
Replace the heating element.
Posted on Apr 28, 2010
I have a hotpoint drier that doesnt heat its electric
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Mar 13, 2011 | Hotpoint Dryers
My drier wont start. Power at back of switch
There can be a few reasons why an electric dryer does not heat...
Check out this tip that I wrote... it iwll help you find tha thing that is causing your problem..
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Apr 06, 2010 | Crosley CDE6000 Electric Dryer
Is there a reset button? Dryer wont dry but does
Does this heat up at all? Gas/Electric? Does it dry by 'sensor'? At this age, if you use softener sheets, the drier thinks everything is dry.
If you dry by sensor, you probably have a problem with a certain coating on your sensor from softening sheets. clean the sensor in accord with the instructions from the manufacturer. Shy of that, you can use alcohol to clean the sensor. You will probably find it on the back wall of your drier.
Sep 21, 2009 | Dryers
My drier is a Maytag, it is not heating up the way it should be.
There is a chamber that the air blows down before hitting the vent pipe. It may need to be cleaned. But you want to make sure when you push your dryer back, that the vent doesn't kink. good luck. Overall you drier works, your just having a venting issue.
Apr 04, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Tumble drier works but wont heat
Hi can you tell me what make model etc.... I then can tell you what is wrong!
Dec 28, 2008 | Hotpoint Dryers
My dryer will run but won't heat
you either need a new heating element or limit switches
Nov 02, 2008 | Whirlpool LER8648P Electric Dryer
MY drier heating element shows 9 ohms continuity, it also shows 120 volts into and out of it when the drier is running. But the heating element wont heat up?
Have you checked the voltage at the outlet? You're supposed to read 220-240 VAC at the heating element. Your dryer heating circuits require at least 220 VAC to work. The motor, however, only uses 120 VAC. That's why your dryer may be running, but the heating circuits aren't heating. I would go back and check your outlet. You may be missing one leg of the 220 service, or have a loose, burned, or broken wire in the plug or terminal block (on the back of the dryer). Let me know what you find. I hope this helps you.
Oct 17, 2008 | Whirlpool Dryers
DRIER OVER HEATS, WORKS ONLY ON "FLUFF" CYCLE
You need to have the thermostats tested by a qualified servicer.
May 21, 2008 | Crosley CDE6000 Electric Dryer
Estate dryer kicks off circuit
you can check where the cord is connected to the drier did you use the cord off your old drier see if the cord is tight at the back of the drier and the center terminal of the cord should be on the center of the terminal block and why did you buy a new drier hold my rating till were done please
Jan 30, 2008 | Estate TEDX640JQ Electric Dryer
Zanussi TC7102W Electric Dryer Logo
134 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
