Question about Craftsman Garden
CRAFTSMAN DLM 917 378 501
CRAFTSMAN DLM 917 378 501 HOW CAN I GET AN OPERATORS MANUAL SO THAT I CAN KNOW HOW TO USE THIS CRAFTSMAN 5.5 EZ WALK
3 Suggested Answers
SOURCE: how do I replace the pull cord on a craftsman 6.75
Remove the three or four bolts holding on the pull cover and lift it off the mower.
Get a length of new pull cord and fish it into the hole the cord comes out of while passing it into the cord reel underneath the cover. There should be a hole in the reel where you can see where the cord should come out. Then you tie a knot into that end of the cord. With the cord now on the reel you wind it backwards with free end of the cable enough turns to **** in the free cord when you let it go. Usually 6-10 turns minimum. Remember to allow for the distance to the lawn mower handle! Unless your cord terminates at the top of the pull cover.
Good luck and be careful!
Posted on Oct 07, 2010
hunter19_46m
  • 7482 Answers
SOURCE: I left my mower a
Hi apoeter...
Let the mower dry out...put a fan on it to dry it faster let the fan stay on overnight or at least 8 hrs...if it doesn't start then here are some things to check below..
Make sure you are getting spark at the spark plug, to do this:
Remove your spark plug and check to be sure you are getting a bright blue spark at the spark plug.
You do this by grounding the plug on the head of the engine and pulling the crank rope...watching the plug for spark.
If you are getting a nice blue spark then skip A below and go to B.
A...If you do not get a nice blue spark then you may need to replace the electronic module.
Note: If you have to replace the module be sure to measure the position it is in, it is critical to starting.
Take a picture for later reassembly.
B...Also take some fine grit sandpaper (not emery) and lightly sand the flywheel where the magnet is located to clean any rust or corrosion from the magnet area.
Then follow the procedure below:
Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Write down on a piece of paper and or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.
Mark each piece with a awl, or some kind of sharp instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line/s condition...after a while they will degrade and need replacement.
Check/Clean/Replace your fuel filter if you have one.
When you remove your fuel lines from the carburetor be sure to make a drawing or take a picture of how the lines are connected to the carburetor.
Also a good time to take a picture for later reference for reassembly.
If the mower is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Please take time to rate me thumbs up
Posted on Sep 23, 2011
How to tighten the drive belt on Craftsman 7.25 EZ Walk mower
If there is any adjustment at all it will be done on the drive cable itself not the belt. You will adjust the cable in order to pull more tension on the belt.
Oct 17, 2015 | Craftsman Garden
How do i take off the pull start from a craftsman model 917.377582 lawnmower
engine numbers would be helpful buttttt.... the perimeter of the recoil assy should be 3-5 small screws. remove them and it should come off, the is as long as you have a eagerbeaver engine ( tecumseh ohv )
Apr 15, 2015 | Sears Garden
How do I get an owners manual for my snowblower Craftsman EZ steer 9.0 28"
Go to the Sears Parts Direct website and enter your model number where it says to. Here's the link. http://www.searspartsdirect.com/partsdirect/user-manuals
Nov 20, 2014 | Craftsman 28 In 277cc* Dual-Stage...
I need an owners manual for a Craftsman EZ steer 9.0 28" snow blower
Have you tryed searspartsdirect.com as long as you have the model and serial number you should be able to find it.If not let me know
Nov 20, 2014 | Craftsman 28 In 277cc Dual-Stage...
How do I change the belt on a Briggs and Stratton Self Propelled 7.25ex lawn mower
unbolt top cover 5/16, unbolt bottom cover 3/8 unbolt blade 9/16 or 5/8 remove old belt, install new one, install covers and blade
Oct 01, 2014 | Briggs & Stratton Garden
Ez switch is broken
I think I have the same problem. The ez-fire lever won't lock in place. Sound familiar?
May 22, 2012 | Craftsman Gas Mini - Tiller/Edger
I need to program my transmitter to work with the db dlm-3 for a 2003 suburban. The transmitter is also operating a silencer alarm model 6918a. It is a silencer 4 button transmitter
the db-dlm3 is a module to make your door locks work with any alarm. the transmitter is not programed to the module but to the alarm if you need to program transmitter turn key to on position push valet 5 times then hit lock button on remote
Dec 10, 2009 | DB-DLM-3 Door Lock Module
Garden Logo
507 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
