-   I have exactly the same problem with my Packard Bell Store & Save USB 2.0 external hard drive. It has worked just fine for more than a year. All of a sudden, non of my computers cann recognizes it as an external drive anymore.-   whilpert
It includes the following: Beeping noise and flashing LED SituationWhen I turn on the Store & Save, it makes a beeping noise and the LED flashes continuously.
DetailsThese symptoms indicate that the AC adapter is not providing enough power.
SolutionThe AC adapter will need to be replaced.
I hope this helps, Bob
In fact the new drive is the same exact size. In fact both are wd2500 drive. I had one drive die I...
(More)
In fact the new drive is the same exact size. In fact both are wd2500 drive. I had one drive die I replaced it with an exact duplicate but when I try to mirror the other drive - the system thinks its smaller
how to make a toshiba model number ph3100u-1exb compatible with my xbox 360
Other harddrives...
(More)
Other harddrives normaly work but the toshiba is new. By the way it's a terabyte external harddrive.
Drive will not power up, tried another working power supply, still no good, scsi termination light...
(More)
Drive will not power up, tried another working power supply, still no good, scsi termination light lights up when termination set to ''I'', but power and activity led's do not light up. If you insert a disk, nothing happens and you have to manually remove the disk
