Question about Arris SURFboard SBG900 Wireless Router (DHSBG900)
I have a motorola sbg900 my provider is comcast. My problem is that the router drops the connection. This started about a month ago, and its very difficult or impossible to get on line. Any suggestions?
    President:
  • 1,768 Answers
1. check the status page of the router
2. Then check with the ISP for any outages, maintenance. ask the provider to test the line to your premise
Posted on Apr 29, 2010
Does the motorola surboard sbc6580 modem have phone connetion
Hello:
Neither the SBG900 nor the SBG6580 have a phone jack.
A cable modem with a phone jack is called an eMTA (Embedded Multimedia Terminal Adapter: Cable modem Wikipedia the free encyclopedia.)
Most cable companies will only have one alternative to their own equipment when it comes to eMTAs. For example, Comcast only works with the Arris 722G: Customer Owned Arris 722G FAQ Comcast Help and Support Forums, and they'll insist that it can only work if you bought it from Best Buy.
If you wanted to keep your SBG900 or SBG6580 and have VOIP phone service, look into a service like Ooma.
May 03, 2014 | Arris SURFboard SBG900 Wireless Router...
How do I secure my connection?
Hi. There's a lot of ways to secure your connection. Just follow this link
http://media2.comcast.net/anon.comcastonline2/support/help/manuals/Motorola_SBG900.pdf
May 14, 2011 | Arris SURFboard SBG900 Wireless Router...
I have a Motorola Surfboard SBG900 wireless router and my provider is comcast. Comcast came out and changed some wiring and connections but i continue to loose connection, every couple of minutes. What...
i had the same problem. it turned out the power to the modem was shorting just enough to throw me off and have comcast resetting the ip address and connection. i fixed it by getting a new power supply and plugging it in to a really good strip bar. hope this helps
May 28, 2010 | Arris SURFboard SBG900 Wireless Router...
We just tried to secure our wireless motorola sbg900 and now the wireless portion doesn't work. We have to use an ethernet cable. How do we reverse this and still make it secure?
To change any wireless settings on the router, you will need to make wired connections to the router.
If you change the wireless settings on the wireless laptop it will drop the connection because you are changing a wireless setting.
Click Here for more info about networking
Oct 17, 2009 | Arris SURFboard SBG900 Wireless Router...
Hi. just got cable internet (Comcast) and am
that's normal, wireless is normally between 1/4 and 1/2 the speed of your wired connection. normally the router gives priority to wired devices, but this should not cause you any further slow down unless you have wired devices plugged in at the same time you are using wireless. this can be changed from your router's admin page.
Aug 14, 2009 | Arris SURFboard SBG900 Wireless Router...
Sbg900 wireless connectivety
I had that long time ago. Now I do not broadcast ESSID and changed the channel to 11 (I also use Vonage and when the call was placed the wifi was dropped. No longer).
Changing the MTU to 1452 (on the gateway) helps with the connection. Just to make sure I assigned the first IP address a bit away from the starting point, .10 so that somebody around having the same would not confuse my settings.
Feb 09, 2009 | Arris SURFboard SBG900 Wireless Router...
I have a Surfboard SBG900 router and cannot connect to VPN
The issue you have is not due to enabling WPA. It is due to enabling Firewall protection. Either turnoff firewall or use custom option to enable required ports.
Nov 26, 2008 | Arris SURFboard SBG900 Wireless Router...
Home Networking
Is the laptop an xp machine? If so:
In order to access shared files on a Windows XP computer (or any computer running Samba) from a Mac, the Mac will need to "connect" to the Windows XP computer and "mount" the shared files.
Instructions:
Start at the "Go" drop down menu at the top of your screen, then "Connect to server".
If the computer you wish to connect to is listed, just select it from the list.
If the computer is not listed, type into the "Server Address" field 'smb://' followed by the computer name or IP address of the computer to which you want to connect.
Click the "Connect" button in the bottom right corner of the window. See more at the link below:
http://www.mac-connect.com/win_from_mac.php
Jul 08, 2008 | Arris SURFboard SBG900 (49402201900) Modem
Motorola SURFboard SBG900 loss ethernet connection
Please remove the program of your router and re install it again and it will work..
Good luck
Johnson
Jan 03, 2008 | Arris SURFboard SBG900 (49402201900) Modem
Arris SURFboard SBG900 Wireless Router (DHSBG900) Logo
186 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
jimmy Leo
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
