Question about Craftsman 55 Torque 158cc 22" Push Lawn Mower ()
Lawnmower runs for 2 or 3 minutes then stops running craftsman 6.5 hp push mower
  • 26 Answers
Check the spark plug, setting, and the armature-magneto condition and the setting between it and the fly wheel.
Posted on Aug 01, 2012
  • 54 Answers
Sounds like you might have a fuel flow restriction, maybe an in line filter?
Posted on Apr 28, 2010
Will start but will only stay running if you prim it until its warm then runs fine
Lawn Mower Repair pt.1: starts & dies, Tecumseh/Craftsman ...
? 2:10
https://www.youtube.com/watch?v=IVYYYpAviPA
Mar 7, 2011 - Uploaded by Alameda Repair Shop
Spray with starting fluid and the engine runs a bit longer but dies.... I especially like how you use the gas can to hold up the mower, Classic :) ... After I started it up, it would only stay running for a few seconds before dying. .... LAWNMOWER REPAIR: briggsand stratton pulsa prime carb overhaul - Duration: ...
How to fix a gas lawnmower that starts then dies - YouTube
? 7:37
https://www.youtube.com/watch?v=caa0WrpxqyU
May 3, 2011 - Uploaded by SmallEngineRepairGuy
This is a how to video on what to do if your gas mower starts up then dies after a ... I have a different lawnmower and not very mechanical but this got my ... Got the job done and now i can do a thorough cleanout of it when i run it dry of gas. .... How to FixBriggs & Stratton Small Engine that Only Runs Off the ...
Craftsman 5.3hp starts but won't stay running... - DoItYourself ...
Dec 09, 2015 | Briggs & Stratton Briggs Stratton Intek V...
Craftsman lawnmower wont stay running
Michael it sounds like there may be a blokage on you air filter. Check it and clean it then make sure there is not too much oil in the mower.
Jul 18, 2013 | Garden
Lawnmower cuts off after 15 minutes
loosen the fuel cap and try it the vent might be plugged in it
May 30, 2012 | Craftsman Garden
Lawnmower looses power. Sounds like it is running on one cylinder. Have changed spark plugs, air filter, gas filter, drain gas, pulled fuel cylinoid from bottom of carbarator and drained. Replaced and...
Hi, first check the oil. If it smells like fuel, change the oil. Secondly if oil smells ok, check the valve clearances and adjust if incorrect. Let me know if the oil smells like fuel and I will help with a fix to stop it happening again. Regards Phil.
Aug 05, 2011 | Craftsman 26 Hp 54" Deck Yard Tractor
I have a craftsman 6.75 hp push mower. It starts
Use fresh gas only first
then if still an issue remove carb.and clean all components and orifices with a good carb. cleaner and air hose or soak it in a automotive grade carb cleaner,spray residue with carb,cleaner and blow dry with air--reassemble and reinstall
May 28, 2010 | Garden
Craftsman DT4000 Running loudly
believe i had same problem this is what i did i took took the head cover under the carb and my needles was bent had to replace them now it works great again
May 19, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Lawnmower will not move in gear with motor running
Hi
Check to see if any oil leaks between rear wheels where the tractor was parked. Also make sure hydrostatic disengage lever, at rear of tractor by hitch, has to be pushed in.
Apr 05, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Push mower runs then quits!!
My toro mower starts and will run for ablut 15 minutes and starts to cut out and eventually stop running. What could be the problem
Apr 01, 2009 | Craftsman Garden
Craftsman 55 Torque 158cc 22" Push Lawn Mower () Logo
1,076 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
