How do i add ram to the ASUS A2800S
I can't find the two ram slots to remove/replace the existing memory modules on the ASUS A2800S notebook.
Does anyone know how to do it?
    Sergeant:
    Champion:
  • 305 Answers
They are on the under side of laptop turn over then remove covers till you find the sticks, replace all other covers there should only be 3 try smallest one first.gently push the 2 prongs on outside of sticks apart sticks will pop up. remove take to computer vender and they will sell you the correct memory sticks.
hope this helps.
Posted on Apr 28, 2010
Blue screen when trying upgrade memory
If you are adding more RAM to the existing RAM then then new RAM maybe incompatible with the existing RAM. Use RAM that is the same specs as the existing RAM and from the same manufacturer.
Feb 15, 2013 | Computers & Internet
How to install memory to my Acer Aspire 570 G Notebook PC
Most laptops have a panel on the bottom of the laptop that provides access to the RAM memory slot/s. Remove this panel to reveal the RAM slot, Insert a RAM module that is the same make and model as the original one.
If your laptop has a single 512Mb RAM module then add another 512Mb of RAM to increase the total RAM to 1Gb.
Feb 24, 2012 | Acer Aspire Notebook PC
How to add memory to Toshiba Satellite M110s3094. I know there are 3 or 4 slots but I only see the one with the current memory and I want to add to the existing memory
First of all you need to know the limitation of your the Laptop from its specifications. Know the right type of memory and maximum capacity of your laptop. For your case, I've researched and you may have 2GB maximum on your laptop with 1GB maximum each slot of type DDR2 PC2-5300. Then follow the below instruction.
· Power your laptop down and remove the power cord.Remove the battery.
· Ground yourself using an ESD wrist strap or other method to prevent damage to your computer chips from static electricity.
· Locate the Memory Access door. You'll find this in the detailed specs for your computer retrieved from the Toshiba support site. In most cases, it will be on the underside of your laptop, but some Toshiba models place the RAM under the keyboard.
· Unscrew the screw for the Memory Access door. Place the screw in a small container to avoid losing it. Remove door.
· Remove the memory SODIMMs that you are replacing by gently pressing apart the latches at either end of the module. The RAM module will pop up to a 45 degree angle. Pull it from the slot at that angle.
· Align the new memory module in the slot, matching the notched edge of the RAM with the notch in the slot. Gently push it into place at a 45 degree angle. You won't be able to see the gold pins when it is fully in the slot.
· Gently rotate the module downward until you feel it click into place as the side clips catch the chip.
· Replace the memory access door and screws.
· Replace the battery.
· Power up the computer and check to be sure that the new memory is recognized.
Jul 15, 2011 | Toshiba Satellite® M115-S1061 PC Notebook
Motherboard P5B-TMX-GB-SI diagram need to add addition RAM could do with contact numbers
DDR2 Upgrade for the ASUS P5B-TMX-GB-SI Motherboard 4GB kit (2GBx2), 240-pin DIMM, DDR2 PC2-8500 memory module
Part Number: CT2KIT25664AA1067
Guaranteed-compatible with the ASUS P5B-TMX-GB-SI
http://www.crucial.com/store/listparts.aspx?mfr=ASUS&model=P5B-TMX-GB-SI
you can see all of the crucial updates for this motherboard ram
hope this helps
2q==
Jun 16, 2011 | Computers & Internet
How do i install a memory ram on my computer acer 5050
I don't know your model laptop, but most laptops have one or two memory slots on the bottom of the laptop behind a panel. Remove the panel to reveal the RAM slot/s.
When installing RAM, say 1Gb when there is two 256Mb RAM modules, then you need to replace the existing RAM with two 512Mb RAM modules. Make sure the new RAM is the same speed as the original RAM or faster RAM.
Oct 16, 2010 | Acer Aspire 5050-3242 Notebook
How can I increase memory of toshiba Satellite A105
A RAM expansion slot is located on the bottom of the laptop behind a small panel. Remove the panel to get access to the RAM slot/s. It may have two RAM slots, if it has only one the the 1st RAM slot will most likely be located under the keyboard.
If the laptop has two RAM slots on the bottom of the laptop and the 2nd one is empty then you can add anothe RAM module. Try to get the same make and model as the original to double your RAM..
If both slots are occupied then you need to replace the existing RAM with larger capacity RAM modules.
Sep 02, 2010 | Toshiba Satellite A105 Notebook
Memory (Upgrade-Max) how I buy for the ASUS L 7200?
You could have tried GOOGLE.
Your computer has 64mb ram built in and can take a maximum of 320mb. You have 1 slot to add memory too
You can add 256MB, 144-pin SODIMM, SDRAM, PC133
Jul 26, 2010 | ASUS L 7200 Notebook
The board for this appears to have a dead ram slot.If putting ram into second slot the monitor just goes black with line distortions.Remove the Ram and install to first slot everything works ok add a 2nd...
Inspect the memory slot carefully. If there are are bent pins in the slot , you can probably align them with a pointed tip. Otherwise the best option would to replace the motherboard. Because after the process RAM is the fastest component in the computer. Out of experience in repairing the motherboards ,i recommend to replace the motherboard.
Thanks Fixya
Proton
Jun 17, 2010 | HP Compaq Presario SR1720NX (EL435AA) PC...
I am using this ASUS (asus M2N-MX nvidia mcp61p chipset
According to the manufacturer's web-site:
http://usa.asus.com/product.aspx?P_ID=0pKBwEIE8tqMT4j7
this motherboard has 4 x DIMM sockets,
supporting a maximum of 4 GB
of DDR2 800/667/533/ Non-ECC, Un-buffered Memory
and supports Dual Channel memory architecture.
So, add one 512MB DDR2 533 Mhz RAM into one of the slots,
being sure to leave *ONE* *EMPTY* slot between the two sticks,
in order to enable the high-performance "dual-channel" option.
Try your computer -- it should feel faster.
If you still think that need more RAM, buy two 512MB (or two 1024MB) DDR2 533 Mhz RAM, putting the 2 sticks into the two empty slots.
Dec 26, 2009 | ASUS M2N-MX Motherboard
I want to add RAM, but I haven't yet found the slots. Can someone tell me where they are?
The slot will be on the bottom (the part of the laptop that sits on the desk). Remove the screw(s) that are holding the cover and you will see the existing RAM (usually a green module about 2 inches in length).
Apr 13, 2009 | Computers & Internet
Computers & Internet Logo
301 people viewed this question
David Payne
David Payne
