Question about Plantronics Explorer 330 Headset
Lg lotus does not locate plantronics 925. have been using motorola h700 with no issues. have turned off phone and 925 and retried several times. lotus does not see any other devices.
    Prodigy:
    An expert who has answered 500 questions.
  • 537 Answers
Once you make your LG Lotus discoverable, then put the Plantronics Discovery 925 into pairing mode by holding the call control button until the headset flashes red and blue. Here is the link below for the Discovery 925 pairing instructions.
Plantronics Discovery Pairing Instructions
Good luck from Headsets Direct!
Posted on Oct 21, 2011
Problems with dicovery 925 keep blinking purple light and can't pair with the phone help
Something you may want to try is start from the beginning. Check to make sure there are no other bluetooth devices loaded onto your phone that might interfere with the process. Turn off your phone. Disconnecting the battery of your mobile for 30 seconds and reconnecting helps to reset the phone. The instructions for turning off the headset and re-pairing the two devices are located in the following link for the Plantronics Discovery 925 User's Guide.
Sep 03, 2011 | Plantronics Discovery 925 Bluetooth...
I have an LG phone and my Discovery 925 bluetooth from Plantronics won't connect anymore. When I have it in discovery mode my phones message states "no devices found."
You want to make sure that there is no other bluetooth interference on your phone and follow the instructions on the link for the Plantronics Discovery 925 (see page 4).
Jul 17, 2011 | Plantronics Discovery 925 Bluetooth...
I can hear the person on the other end, but they can't hear me on my plantronics Discovery 925
Try using the headset on a different phone. This will narrow down if it's a compatibility issue with your phone or a defective headset. If you pair to a different phone and experience the same dead microphone, that means the headset is the issue. If it's less than a year old, you can have it replaced directly from Plantronics. Plantronics tech support can be reached at 1-800-544-4660 x 5538.
Good Luck from Headsets Direct!
May 18, 2011 | Plantronics Discovery 925 Bluetooth...
Plantronics 925 Discovery won't connect with Droid 2
  • Turn on Bluetooth within your phone - Consult phone instruction booklet
  • Put phone into pairing mode - Consult phone instruction booklet
  • Put headset into pairing mode - With headset off, press and hold Call Control Button
    until the headset begins to flash red and blue.
  • Select "Add new device" on your phone.
  • Select the Plantronics headset when prompted. Enter "0000" as passcode.
  • Your 925 headset will now have a continuous blue light blinking.
  • Choose "Yes" if your phones asks if you want to bond to the 925 headset.
  • Your phone is now paired with the Plantronics 925 headset and ready for use.
  • Please leave me a good rating!
    Sep 04, 2010 | Plantronics Discovery 925 Bluetooth...
    Lg lotus does not locate 925. have turned off
    I was able to use myBluetooth Headset on Windows 7 by installing the drivers found in this link: http://blog.komeil.com/2009/05/installing-bluetooth-headset-in-windows.html
    Good luck! It took me about a week to find the solution.
    Apr 27, 2010 | Plantronics Discovery 925 Bluetooth...
    How to connect the LG Voyager - plantronics discovery 925?
    From all my research in the past few days (1-11 March 2010) I have found out that bluetooth hands free via bluetooth is not possible with the Motorola Droid or the Eris Droid. The problem is with the Google android operating system not your bluetooth device. After calling Motorola and Verizon tech support, both say that "They are working on it." I really hope they update/fix their os because I really want to buy a couple of their phones. They said to wait until 31 March 2010. Hopefully they will get their act together.
    Jun 25, 2009 | Plantronics Discovery 925 Bluetooth...
    Motorola H700 won't pair with LG CU720 phone
    You will need to enter pairing mode on your device. The H700 User Manual indicates that you do so by first turning off any previously paired device and opening the headset BOOM. The indicator light should light a steady purple while in pairing mode.
    You may not need to turn off your phone if you do not desire this, you may be able to get by turning the blue tooth function off and on, on your phone and attempt to pair again.
    Pairing Pin is likely 0000.
    Dec 29, 2008 | Motorola Mobility H700 Wireless Headset
    Can't hear headset
    Here is a list of compatible bluetooth headsets taken from the Blackberry web site.
  • Flamingo™ Bluetooth Headset *
  • Jabra® BT250v
  • Jabra JX10
  • Jabra BT125
  • Logitech® Mobile Pro™ Headset
  • Motorola® Bluetooth Headset H500 **
  • Motorola Bluetooth Headset HS820
  • Motorola Bluetooth Headset HS850
  • nXZEN™ 5000
  • Plantronics M3000 Bluetooth Headset
  • Plantronics Discovery™ 640 Bluetooth Headset
  • Plantronics Explorer™ 320 Bluetooth Headset
  • Plantronics Voyager™ 510 Bluetooth Headset
  • scala-500™ ***
  • Sony® Ericsson® Akono™ Bluetooth Headset HBH-602
  • It may be a compatibility issue with the H700. You may want to make sure the volume is turned up fully on the headset as well.
    Good Luck
    Jun 28, 2008 | Motorola Mobility H700 Wireless Headset
    Palm Centro and Moto h700 bluetooth
    I think its a compatability problem also. you may have to get a headset specifically designed for Centro or try a plantronics headset they work great www.n1wireless.com
    Dec 08, 2007 | Motorola Mobility H700 Wireless Headset
    It's paired up with treo, but when treo rings, the headset will not work.
    there are known compatability issues with palm treo and blackberry phones when trying to use this type of headset .
    I recomend a Plantronics brand headset with your phone.
    Nov 17, 2007 | Motorola Mobility H700 Wireless Headset
    Plantronics Explorer  330 Headset Logo
    137 people viewed this question
    Top Plantronics Radio Communications Experts
    LeAnna Mathews
    LeAnna Mathews
    Level 1 Expert
    Ed Nelson
    Ed Nelson
    shaun taylor
    Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
