Question about Linksys WRT160N Wireless Router
WRTN 160n will not reconize a brother wireless HL 2170Wprinter when i have connected the ethernet.
    President:
  • 1,768 Answers
1. verify the name of the router then log into the printer and see if you can see it.
2.check the printer settings.
3. Walk through the printer setup and set it up wirelessly.
Posted on Apr 29, 2010
Hi! I have a brother HL-2170W printer. It is connected via ethernet cable to a Dynalink RTA1046VW router (which is sitting on top of the printer) and I have a HP pavillion entertainment PC that is...
Hi!
Your Printer is connected to the (network) router via ethernet cable. Hence, it is a NETWORK PRINTER NOT A WIRELESS DEVICE, no matter your PC is connected to the network wirelessly. So, search for and install the printer as a NETWORK PRINTER. From the printer installation, it should searh and find the printer and susequently install the required drivers.
Moreover, you may checkout the followings link for instructions on how to install/ add a network printer.
LINK-1, LINK-2
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck!
CreativeTECH
Apr 04, 2011 | Brother HL-2170W Mono Laser Printer
I can't install the router from the CD to my computer, I follow the steps, but when it says please wait reconizeing your router, it want reconize it says check the ethernet conections.
You don't need to install a wireless router. unplug your modem, connect the ethernet cable from your modem to the port on your router labeled internet or WAN, and then plug in the modem and router. Connect your computer to the network and you should be online.
Mar 04, 2011 | Linksys WRT160N Wireless Router
Hello, I have a Linksys Router model No. WRT 160N and have problems with the wireless signal. Doesn't appear the wireless symbol ON and I have connected already the modem cable. The modem is OK cuz I can...
* NOTE: If you tried to set-up the WRT-160N Router previously, but failed, with the Router ON, press the "Reset" button on the back panel and hold it down for 10 seconds, then release. This will reset the Router to factory settings and erase all previous data.
Then do this
1. Hook up the Linksys WRT-160N Router to the modem(cable, DSL or satelitte)
2. Hook up the Linksys WRT-160N Router to your computer via a LAN cable with the LAN cable in Port #1 on the Linksys WRT-160N Router.
3. Type http://192.168.1.1 in the address bar of your web browser.
4. Log-on to the Linksys WRT-160N Router with these log-on credentials:
Username: linksys (lower-case)
Password: admin (lower-case)
5. Click on the "Clone PC MAC Address" tab.
6. Click the "Clone PC MAC Address" button.
7. Click "Save", click "Continue".
8. Click the "Wireless Security" tab.
9. Choose "WPA2 Personal - TKIP/AES" for encrypted security.
10. Enter encryption password (passphrase).
11. Click "Save", click "Continue".
12. Exit the web browser.
13. Disconnect the LAN cable from the computer and Port #1 on the Linksys WRT-160N Router.
In about 5 seconds, your wireless connection should be up and running.
Sep 15, 2010 | Linksys WRT160N Wireless Router
I have netgear wireless N-300 router. Linksys cable modem. Arius phone modem ( comcast trip play). Netgear not reconizing ethernet connection. My connection is yellow ethernet cable to linksys, grey...
If you mean phone modem on PC then no. Check connection between pc and router by acessing the webinterface (instuctions in linksys user manual).
If all OK there then contact your ISP.
Sep 03, 2010 | Computers & Internet
We just got two brother hl 2170w printers from a lab across campus, they were configured for a wireless connection and now we are trying to connect them to the network via a wired connection. the test page...
hi there, this should work for you:
When you disconnect an Ethernet cable from the printer, wireless network will be enabled.
On the other hand, when the Ethernet cable is connected to the printer, wired network is enabled.
If you press the Go button for approx. 13 seconds, the network setting page will be printed out. Then release the Go button, wired network will be switched to wireless network even if the Ethernet cable is still connected.
You can then verify your network settings and change between wired and wireless setups.
Apr 16, 2010 | Brother HL-2170W Laser Printer
Brother 2170W "fails to associate"
Have you tried the SecureEasySetup method of connecting your HL-2170W to your wireless network?
Basically, it involves no wires:
1) Press the wireless setup button on the back of your printer (you may need to use a pen or pointed object)
2) Press the SecureEasySetup button on your router
3) Let the two sort it out - Green Go button on printer indicates success.
A complete guide for using the SecureEasySetup for your brother model:
Brother SecureEasySetup Method
I hope this helps!
Jan 26, 2010 | Brother HL-2170W Mono Laser Printer
I CAN'T GET THE PRINTER TO FIND ANY WIRELESS DEVICES,
Ethernet, USB is really iffy. You might want to invest in a WIRELESS PRINT SERVER
Mar 04, 2009 | Brother HL-2170W Laser Printer
Connecting the WAG160N to a Cable broadband supply
Yes, it will work. Hook it up like this:
Ethernet cable from the back of your cable modem to the internet port of the 160n. Any computer that will be wired to the internet will then run from the ethernet port in the back of the computer to one of the four ports on the 160 otherwise, using your wireless internet, the computer will be able to see the signal put out by the 160 and connect to it. Oh and please take a moment to rate this solution with a fixya rating. Thanks!
Jan 02, 2009 | Linksys Computers & Internet
Connect to wireless network
plug an ethernet cable into one of the ethernet jacks on the router and the other end into the printer. run driver installation setup on your computer that is connected to the wireless network and choose peer-to-peer networking. let your computer search for the network printer. follow installation instructions to complete.
you can download the driver here
http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/download_top.html?reg=us&c=us&lang=en&prod=hl2070n_all
Jul 29, 2008 | Brother HL-2070N Laser Printer
Linksys WRT160N Wireless Router  Logo
193 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
