Question about Sony Playstation 3 (PS3) Console
What does this falt code mean? 8002291A and how do i fix it?
    Guru:
  • 1,049 Answers
Trophy Error 8002291AIt thinks that you are using a save file that no longer matches the trophy data. Essentially your save file or the trophy data is corrupted and no longer accessible. Usually, you just need to wait for the game to update.
If that doesn't work.
Easy fix, delete your saves...hard fix, try and fix the corrupted data.
Posted on Apr 27, 2010
Ill try fix the corrupt data for mw2 btw those sony ***** better pick up ther act or im moving to xbox
Posted on Nov 13, 2011
2006 Pontiac g6 code p1258 . The temperature gauge was fluctuating while driving from overheating to normal operation temp but no actual sign of overheating . So I replaced the coolant temp sensor ran it...
I suggest changing the cooling thermostat to make sure it's not getting stuck causing temporary overheating and flush the system and put fresh coolant in.
The guage will go hotter then go back to normal every time the thermostat opens to let cooled water into the engine block which is normal. Time for concern is when the guage goes hot and stays there along with bubbling sounds and coolant overflow onto the ground. Which you probably already know.
Mar 02, 2018 | Pontiac Cars & Trucks
What is 85 falt code mean
check with a dealer or auto parts store locally
Feb 12, 2018 | Cars & Trucks
Unimac. Why is it displaying E FL and won't spin?
Unimac Washer Product Support ' ManualsOnline.com
laundry.manualsonline.com/support/unimac/washer/
Unimac Washer uw60b20u80001. 0 Solutions ... on start up unlock door light stays on.display sa. Unimac ... washer has falt code E FL what does this mean and.
E fl error code on industrial uni Mac washer. What's it mean ...
www.fixya.com/support/t20744713-e_fl_error_code_industrial_uni_mac
Jan 07, 2016 | Washing Machines
Man TGA 440 falt code 03300-06
I can't answer your question about Dolls, Playsets & Toy Figures "Man TGA 440 falt code 03300-06" because simply, I can't understand whay do you mean.
Please reformulate your question, so maybe someone else might help you
May 04, 2015 | Toys
Fa206cc falt code is po188
code PO188 fuel temperature sensor b high input. that means fuel rail temperature sensor circuit high input.fuel temperature sensor located on left of fuel rail just ahead of fuel supply line pipe.
May 21, 2013 | Cars & Trucks
Showing LL error code
This error code means LARGE LOAD and shows thatthe machine is overladed with washing. Remove some and reset the machine and all should be well. If the fault persists then the following will need to be checked:
Sep 08, 2012 | Washing Machines
I have falt codes on air cinditioner screen after a battery change, how do i reset?
scan the ob2 port, verify trouble code, then clear with scan tool
Mar 17, 2012 | 2001 Jaguar S-Type
1989 dodge datona 2.2 turbo coge 13
hello i got a 1990 dodge daytona shelby the code 13 is MAP sensor signal to the computer (ECU) not changing so the map sensor is should be on the firewall with a vacuum line on it little black box looking thing well make sure it plug in and good and that it dose not have a leaking vacuum line if that dose not work you have a bad map sensor thay run about 30 to 100 at auto zone o onec you think you fix it remove the battery term for about 5 mins with the key on and trun the key off before conttecting the battey back up drive for about 20 mins to see if the code show up if you get code 55 all that means is end of falt code list you mite get a code 12 meaning The battery has been disconnected and the computer (ECU) has been reset hope that help keep that daytona runing it a good car
Oct 07, 2009 | 1989 Dodge Daytona
Oven not work
It can be fixed, that falt means your oven got to hot. Recomend replacing the temp sensor.
dmparenti
Jan 09, 2009 | Kitchen Ranges
Sony Playstation 3 (PS3) Console Logo
1,508 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
