Error message FF-81 Service Error - Office Equipment & Supplies
    Sergeant:
  • 152 Answers
I think this link will help you....
click here
Posted on Apr 27, 2010
My HP printer shows: "13.ff.ff. jam in right door" error message, what can I do?
I could not find this error on HP tech site documented for this printer, but on the 551 which is the same engine without the scanner and this error indicates a problem with multiple sensors. If you have run a sensor test and all sensors test ok then the service documentation states that the DC controller is likely the issue.
Jun 04, 2015 | HP LaserJet Enterprise 500 color M575dn -...
Why does the screen read "device error" when I turn it on?
http://is.gd/B05L6B
According to the user manual for the device, on page 81, it reads:
If any of these errors occur, turn the the unit power OFF and restart it.
If these error message continue to appear, please contact a TASCAM Service Center.
***Device Error*** (the one you're asking about)
FileErr
FX Busy
FX Rx Failed
I
/F Error
Mount Error
SaveParam Fail
SD-Card Error!
SD Not Found
SD Read Busy
SD Write Busy
Looks like your unit may require servicing at an authorized Tascam service center.
Good Luck!!
Oct 12, 2013 | Tascam DP-03 DP03 8-Track Digital...
HP4101 SERVICE ERROR 49.ff
Software error or Motherboard is defective.
Jul 30, 2012 | HP LaserJet 4350 Printer
Error on display er ff
Hi, here are the error codes and meanings for your Refrigerator
Error Code, All Error Codes will have an ER on the left side, followed by the error on the right:
Er IF - Icemaker Fan Error - This can be caused by frostaccumulation on or around the icemaker fan. Unplug the unit for 3-4hours to allow this to melt off. If error code persists, call CustomerService.
Er FF - Freezer Fan Error - This can be caused by frost accumulationon or around the freezer fan. Unplug the unit for 3-4 hours to allowthis to melt off. If error code persists, call Customer Service.
For remaining error codes, try unplugging the unit for a couple ofminutes to reset the unit. If the error code persists, call CustomerService
Er FS - Freezer Sensor Error
Er rS - Refrigerator Sensor Error
Er ds - Defrost Sensor Error
Er dH - Defrost Heater Error
Er CF - Cooling Motor Error
Er CO - Communications Error
Thank you.
Jun 06, 2012 | Refrigerators
My LG display is reading ER FF what does this mean and what can I do to fix it?
Error Code Er FF
This code is not to be confused with the O FF or demo mode error message. The "Er FF" error code indicates a problem with the unit's freezer fan. The freezer fan controls the temperature in the freezer. The source of this error is most likely ice buildup. As with the Er IF error, allowing the unit to thaw should resolve the issue. Contact customer service if the error code continues to be displayed after having thawed the unit.
Hope helps.
Apr 03, 2011 | Refrigerators
I have a Kenmore Refr. Model # 795.77563600 has a Error FF
The FF error code indicates that the freezer fan motor is defective.
You need a new main control board and evaporator fan motor.
The fridge is made by LG, but rebranded as Kenmore by Sears. First 3 digits is the tell. You can call Sears for parts.
LG refrigerator repair in orange county, ca
Feb 05, 2010 | Refrigerators
Error message ER FF - refrigerator is not cooling as a result
I would replace the evaporator fan, this fan problem is hard to diagnose because the fan will spin but not fast enough to circulate the chilled air thru the freezer and the refrigerator. The minimum cost to repair/replace is around $300.00
Jul 26, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
16 -bit error on amd
may be over heating problem
open the pc side panel and clear the dust from pc and cpu fan
Jul 21, 2009 | Computers & Internet
Having sharp Photo copy, Model-AR121. It is not working. Pls. provide me service center.
Sharp AR-121 code
CC Original not detected E1 00 Lost communication with the Sorter 10 Lost communication with the Sorter 11 ASIC error 12 Image Processing Unit error 13 ROM error 14 NVRAM error 15 Page memory fault 16 SIMM not present or installed incorectly 17 Page rotation error in RAM 80 Electronic sort board error 81 82 84 88 E7 03 Lens position error 04 White level calibration error 05 Black level calibration error 12 CCD calibration error F1 06 Shift sort motor overloaded F5 02 Exposure lamp blown F6 00 Fax board problems 10 80 81 82 84 88 F9 00 Printer board problems 10 80 81 82 84 88 H2 00 Fusing unit temperature error H3 00 Overheated fusing unit H4 00 The fusing unit doesn't heat up L1 00 Scanner position error L3 00 Scanner position error L4 01 Main motor drive overloaded 10 Separation motor overloaded L6 10 Polygon mirror motor not up to speed L8 01 Zero cross signal error U2 04 EPROM error 11 Main counter error 12 EPROM error U3 29 Mirror position error U9 00 Op panel problem 81 82 84 88 U95 Firmware error
Apr 08, 2009 | Sharp Office Equipment & Supplies
HP Designjet 800 with a 'system error 81:01'
i have hp dnj Plotter 500 Printer Is Redy But Self Test & Computer Print Than Error 81:01 Papar Jam
Feb 23, 2009 | HP Office Equipment & Supplies
119 people viewed this question
k24674
jasbo
jasbo
