Question about Bose QuietComfort 3 Acoustic Noise Cancelling Consumer Headphones
My headphones are feedbacking all of a sudden
My Bose headphones just started to feedback on me. When I turn them on, a piercing whine occurs whenever I pull the earpieces apart (that is, to put them on my head!). If the earpieces are together, there is no feedback, but the second I start pulling them apart....ouch! I've had these headphones for a couple of years now, and they've just started doing this. What's going on?? Thanks!
  • 1 more comment
  • Anonymous Jan 21, 2009
    Mine do the same thing almost. Whenever I put my hand near the earpiece or lean against the pillow on the plane there is an ear piercing screech. This is more aparent on the right ear than the left but still happens on both sides. This set has been like this since new yet none of my friends who own the exact headphones have this issue.
  • Laecee Feb 12, 2009
    Whenever I lean on my pillow the same thing happens.  Any other ideas? I didn't find any moisture in my battery compartment...hmmm...help?
  • ironmantg Mar 27, 2009
    I have the same problem. The humming noise is coming from the right ear speaker... Any solutions?
    New Friend:
  • 20 Answers
The design of these headphones includes a microphone on the outside and on the inside of each earcup. The outside microphone detects outside noise. The inside microphone monitors what you are hearing and when it detects that the outside noise is present inside, the active noise-canceling circuits remove that noise. This happens fast enough that you perceive a siginficant reduction in the outside noise getting to your ears.
The airspace inside the earcup is a tuned chamber defined by the foam in the ear cushion. This is important because with the inside microphone in close proximity, but at a 90-degree angle to the speaker, the circuit must be designed to eliminate the normal feedback that occurs.
If the foam in the ear cushion has weakened/deteriorated to the point that it no longer has it's original shape, (in particular the lower half of the ear cushion), the size and shape of the air chamber inside of the earcup is directing more of the speaker sound toward the microphone than the design can compensate for causing audio feedback to occur. You are hearing that feedback.
On my QC-3 headphones, I can cause the feedback squeal in both earcups, with the left earcup being more sensitive to the shape change than the right.
It may be time to replace the ear cushions. If so, they are available from Bose for around $35/pair.
http://www.bose.com/controller?url=/shop_online/headphones/noise_cancelling_headphones/accessories/qc3_earcushionkit_acc.jsp
Posted on Oct 22, 2013
    New Friend:
I had the feed back problem, then they stopped working altogether. New pair under warranty, same problem after 6 months. A pair of QC20i's gave up within a few weeks (volume control stopped working, replaced under warranty, gave them to a nephew.
The answer, unfortunately, is Sennheiser until Bose get their quality back.
Posted on Jun 22, 2015
    New Friend:
I had the same problem. If I brought my hand near the earphone I got a screech. I called Bose service and she said that it might be bad contact where the wire plugs into the earphone. She suggested reseating the plug. This seemed to work. Later I cleaned both plugs on the connecting wire with an electronic contact cleaner. The problem is gone.
Posted on Apr 24, 2013
Solved....I opened up the battery compartment, and there was a small bit of moisture inside. Once I dried it out, the feedback stopped. It's surprising to me that a moisture problem would manifest itself as feedback, but there you go.
Posted on Mar 25, 2008
Thanks, I have the same problem..i just changed the battery yesterday and saw corrosion on it! I will dry it out. that feedback was amazingly loud..thanks to all!
Posted on Jul 28, 2009
  • Prestige_Fix Oct 11, 2010
    Hi I had the same issue. I had taken my Bose headphones (Bose QuietComfort 3 Acoustic Noise Cancelling Headphones) into the bath with me to listen to my iPod. I’ve had them for about a year now and have not had an issue taking them into the bath with me.
    However, I think the steam from the bath may have caused the left side earpiece to give a screeching feedback noise. I covered it with my hand and the noise would come back. Some times with the headphones turned on, sometimes without. The noise however would always come when I had the battery placed in. If I removed the battery the feedback screech would not happen.
    At first I got the hair dryer and tried to dry the head phones. Then I placed my lips on the metal ‘grill thing’ just under the Bose log in the outer side of the ear piece and sucked. I tried the head phones and they worked.
    Conclusion:
    The feedback is cause by mousier getting into the mechanics of the headphone. Try and avoid getting the wet or exposed to steam, etc.
    Hope this helped.
SOURCE:
Phones get a peersing screach; itgets louder when you press the side where the on/off switch is
The design of these headphones includes a microphone on the outside and on the inside of each earcup. The outside microphone detects outside noise. The inside microphone monitors what you are hearing and when it detects that the outside noise is present inside, the active noise-canceling circuits remove that noise. This happens fast enough that you perceive a significant reduction in the outside noise getting to your ears.
The airspace inside the earcup is a tuned chamber defined by the foam in the ear cushion. This is important because with the inside microphone in close proximity, but at a 90-degree angle to the speaker, the circuit must be designed to eliminate the normal feedback that occurs. When you press the earcup close to your ear, you are changing the size and shape of the air chamber inside of the earcup thus directing more of the speaker sound toward the microphone than the design can compensate for causing audio feedback to occur. You are hearing that feedback. Removing your hand from the earcup should restore the shape of the air chamber allowing the circuits to return to normal operation.
If the feedback occurs too easily when you are NOT pressing on the earcup, then the foam may have weakened/deteriorated and it may be time to replace the ear cushion.
Dec 01, 2013 | Bose QuietComfort 3 Acoustic Noise...
Mic feedback with numark c3fx
Feedback occurs whenever a microphone is being amplified, and it picks up its own signal above a certain level. Unfortunately, there's no way to reduce this possibility using just the Numark C3FX - you can only turn the microphone level down. The only way to reduce feedback through a speaker system is to use a graphic equalizer. Here's a good resource for how to do that: http://rfmedia.hubpages.com/hub/Controlling-Microphone-Feedback-with-a-Graphic-Equalizer
Nov 07, 2013 | Numark C3FX 4-Channel Rack Mixer With...
Severe squelch in left ear phone
The airspace inside the earcup is a tuned chamber defined by the shape of the foam in the ear cushion. This is important because with the inside microphone in close proximity, but at a 90-degree angle to the speaker, the circuit must be designed to eliminate the normal feedback that occurs.
It is probably time to replace the ear cushions. If so, they are available from Bose for $35/pair.
QuietComfort 3 Acoustic Noise Cancelling Headphones Bose Product Support
They are also available aftermarket at Amazon.com for $16.99/pair
Replacement Earpad ear pad Cushions For Bose QuietComfort 3 QC3 Headphones...
or $5.69/pair.
Bluecell Pair of Replacement Earpad Ear Pad Cushion for Bose Quietcomfort...
Aug 29, 2013 | Bose QuietComfort 3 Acoustic Noise...
Ear piercing feedback
Uninstall the program and reboot the computer to see if the feedback stops, if yes! re-install Skype to see if that will solve the problem.
Mar 29, 2013 | Dell Inspiron Computers & Internet
My speakers emit a brrr sound whenever i turn on the machine and when i play musicplease help
Have you tried headphones? from the description you are getting feedback through the main speakers, the problem is the headphone jack, or the audio output ic.
Apr 23, 2012 | HEWLETT-PACKARD Probook 4530S
Hi, when I press the left eatcup close to my ear, there is this very loud high pitch noise that comes from it and is unbareable. I have to removed them inmediately. What can I do, and what those this...
Aug 13, 2011 | Bose QuietComfort 3 Acoustic Noise...
First i was having issues with the sounds blotching out and now im having terrible feedback problems. When the active noise cancelling is on the speakers sound off ear piercing pitch! what do i do?
I would recommend that you do not plug in noise cancelling headphones to the jacks ON your speakers. Plug it in directly to your source and you should not face this problem.
Mar 08, 2011 | Jabra C820s Headphones
Hello, I just got a Bose QC3 on eBay. It works fine except the cable which is not the original one but a one from T'nB and the left earpiece has a very annoying whistling noise when I press it or even...
i would buy a new ear cup.and a new battery. and perhaps a new cord.
i had a problem w/ my ear cups and i noticed that when i bought the new ear cups the sound was better.
i also read that if the battery got alot of usage (4 plus year) then the whistling noise comes from that. i'm starting to have the same problem. i have had my headphones for a long time. i think like anything else that operates on batteries its time to change it.
Mar 06, 2011 | Bose QuietComfort 3 Acoustic Noise...
Feedback sound like wind noise in right headphone of QC3, starts quietly and gradually gains in strength. Sometimes disappears, then comes back again. No sign of moisture in battery compartment. Any ideas?
The airspace inside the lower half of the earcup is a tuned chamber defined by the foam in the ear cushion. This is important because with the inside microphone in close proximity, but at a 90-degree angle to the speaker, the circuit must be designed to eliminate the normal feedback that occurs. When the foam has weakened or deteriorated to the point that the size and shape of the chamber cannot be maintained, more of the speaker sound is directed toward the microphone than the design can compensate for causing audio feedback to occur. This also happens when the lower half of the ear cushion is compressed. Since this is occuring during normal use,
it may be time to replace the ear cushions. They are available from Bose for $35 per pair.
Sep 18, 2009 | Bose QuietComfort 3 Acoustic Noise...
Bose QC3 makes a high pitch noise when i press it against my ear
Feb 16, 2009 | Apple Bose QuietComfort 2 Acoustic Noise...
Bose QuietComfort  3 Acoustic Noise Cancelling  Consumer Headphones Logo
2,509 people viewed this question
Top Bose Audio Players & Recorders Experts
Steve Allison
Steve Allison
Ekse
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
