Question about Maytag Legacy Series Top Load Washer
SAV205DAWW Maytag Washer Belt Replacement Instructions
Same problem. Need instruction set to replace belt.
[email protected]
  • 5 more comments
  • Anonymous Apr 12, 2008
    Maytag Legacy SAV515DAWW Top Loader, about 2 months ago it leaked from the laundry room on the third to the landing over the open stair case on the 2nd floor. I have been using it occassionally with a pan under the drain pipe during each use. Last week it popped the belt, and low and be hold, we went to install another belt today, had no manual, as it came with house when we purchased it 2 years ago, so we ended up here searching for help to install the belt. Thanks to you and your postings, we stopped, pulled the motor out to find... it is rusted inside, had a ton of water inside of it. I have never owned a Maytag appliance, as I have always been faithful to Hot Point... (I beleive now it is GE).... and my last washer and dryer I had for 19 years and sold them as a pair for 175.00 just 2 years ago. Boy am I regretting that. This washer has never leveled, even though we have leveled it 100 times and now this..... I will never buy another Maytag product, now that I have read your comments and found that Maytag is just sitting back and acting like it isn't their problem. It is no wonder the Maytag man is so bored, they won't let him go out and do his job!! I am thinking that I should junk this thing.... any one have another suggestions.... what do you reccommend I replace it with?
  • mrton May 27, 2008
    Belt broke and I need to replace it. How can I remove the pump from the motor
  • eeemd Jun 17, 2008
    washer stopped spinning.  I was happy at first that it was "just" the belt. but now it seems rediculous that you have to take the whole motor apart in order to put a new belt on.
  • davis1157 Sep 29, 2008
    My Maytag washer fills up washes for a few minutes the discharges the water then fills up again and on and on ect.
  • willy chee Mar 29, 2009
    Belt broke on the Legacy. I tipped it back to replace the belt, but there is a panel on the baottom covering the belts. It has major spring anchors in it. What's the procedure to remove the springs to remove the plate to replace the belt?
    Isn't it a good precaution to replace both belts instead of just one?
    Mave Maytag Legacy Washer.
    Access to replace bottom belts is hindered by plate covering base and used as an anchor for stabilizing springs.
    How do you remove the plate to change thje belts?
    Must the motot be removed to change the belts?
    Isn't it wise to change both belts while you are at it?
    The spin belt broke.
    Maytag Legacy Model SAV515DAWW
  • Anonymous Mar 15, 2014
    replace Matag SAV205DAWW drive belt tension lever
This is specifically for a Maytag Legacy SAV515DAWW, but may apply to the whole Legacy line.
There is only one drive belt on this washer and it is not accessible directly from the bottom as a pan forms the bottom of the case. All work can be performed through the bottom front panel, once it is removed.
Before one starts, an overview is helpful. The motor for the washer is bounted just behind the access panel. Attached to the shaft at the motor bottom is the drive pully for the drum belt, along with the belt tensioning pully and spring. Below that is the pump assembly attached by three screws in the shafts, which are accessible only from the bottom. What you must do, is remove the pump by unfastening four hex-head bolts, then rotate the motor and pump assembly bottom upwards to the front, so the bottom of the shafts containing the torx head screws fastening the pump are accessible.
While everything is all together it is helpful to notice that the far support for the pump is in almost a direct line with the motor shaft and the tum pully shaft. When you reassemble the components, this vertical pump support must go between the belt. As you face the washer, the tensioning pully will ride on the outside of the right side of the belt.
1. Unplug the washer.
2. Pull it out from the wall, so it may be tilted back at about a 45 degree angle and will not fall foreward.
3 Remove the two hex head screws on the right and left bottom front of the washer. The panel should lift out from the bottom, Two pins hold the top of the panel in.
4. Examine the mechanism as described above.
5. Detach (Unhook) the tensioning pulley spring from the front of the bracket above the pump..
It is not necessary to remove any of the hoses. There is adequate flexibility and slack for replacing the belt.
6. Remove the four hex bolts attaching the galvanized motor bracket to the frame.
7. Rotate the motor back, so the pump bottom faces the front.
8. Remove the three torx head screws in the pump support arms.
9. Detach the pump from the motor. Gently pry it off or gently strike the body of the pump away from the motor with a soft faced mallet.
10. Place the new belt on the motor pully and reinstall the pump, so the leg closes to the tub pulley is inside the two sides of the belt. Reinstall the pump screws in the plastic shafts.
11. Reinstall the motor and fasten the bolts.
12. Make sure the tensioning pulley is to your right of the belt and then side your hands to the rear and slip the belt under the drum pulley and completely around it.
13 Feed the belt onto the drum pulley. I did this by reaching back with my left hand and feeding the belt, coming from the motor pulley, into the drum pulley, then slowly rotating the right side of the drum to me with my right hand.
14 Check to ensure the tensioning pulley is to the right of the belts, then reattach the spring, so the pulley forces the righthand belt to the left.
15. Set the washer upright, open the lid and rotate the drum around twice using your hands. This will help seat the belt on the pulleys and ensure the drum is not stuck.
16. Make sure the cycle switch is pulled out (set to off) and plug the power in.
17. Set on a wash cycle and looking in the bottom , check for proper operation. If the motor appears to be stalling, immediately turn the unit off. Rotate to tub some more by hand and test for operation. If it still doesn't work, see help, your problem is more than just a belt!
18. If everything seems to work, toss in a test load of laundry and pat yourself on the back for being able to save some money!
Posted on Mar 30, 2009
    Scholar:
  • 196 Answers
First comment: mrton
There are four bolts holding the motor to the chassis. Remove the four bolts, slide you hand back along the belt and released the belt from the transmission pulley. Once this is done, turn the motor and pump upside down and you will see the three star screws that hold the pump on. Remove the screws and slide the pump off. If the pump is stuck you will have no choice but to break the pump off and replace it.
Second comment:Guest
I'm sorry you have had such a hard time with your Maytag washer. The problem may very well be a cracked pump or leaking tub seal.
As to a replacement ? All machines have pros and cons and can be difficult to choose. I'd look at a Whirlpool for two reasons. Price and ease of repair. Most whirlpools do suffer minor problems as time goes on but very few have major breakdowns.
Posted on Jun 04, 2008
SOURCE:
Is it always necessary to purchase a new pump when replacing the belt on top load Maytag Washer? Model No. SAV205DAWW
Not necessary, unless you are suspicious for a problem pump. Or if want to avoid another problem.
Otherwise you must not do it.God bless you
Oct 16, 2012 | Maytag Washing Machines
Maytag A108 pump belt slips and doesn't pump, is there a belt tensioner that engages when the water needs to be pumped out?
The pump belt is designed to be loose to a certain degree, however the drive and pump belt should be replaced every 11 years to maintain optimum performance. The instructions on the belt packaging shows how to properly set the tension. The motor mount may also need some attention at this stage of life. Remove the 2 philips screws at the bottom of the front panel and disengage from the top panel by pulling outward at the bottom of the front panel. Tilt washer slightly backwards far enough to reach under and pull off the drive and pump belt. Make sure that the motor rolls freely in the motor mount assembly. Lubricate with 3 in 1 oil if necessary, (or other light wt. oil). Install new belts as per package instructions. Test spin before replacing front panel.
Aug 16, 2009 | Maytag Washing Machines
Belt replacement instructions for Maytag Ensignia model MDE4658AYW electrical dryer
Try Googling " user manual for Maytag Ensignia MDE4658AYW ". You may have to go to the Maytag web site and ask for manual. Sometimes I've had to ask for repair manual instead of user manual. Good luck.
Jul 24, 2009 | Dryers
How to change belt on maytag model sav205daww.
hi. thanks for the question. pull washer away from the wall. tip back and lean it to the wall .belts are underneath. nice and easy. thanks the appliance doc . please rate me
Oct 01, 2008 | Maytag Washing Machines
Maytag washer repair
I had the repair guys out 3 months ago maytag paid for labor I paid $150 for seal and bearings, tub froze and belt broke. the tub now is making the loud screams that others complain about I contacted maytag and reapir servce and talked with the tech. this machine is a piece of S$%^ the seal fails on a regular basis and bearings get water in them. I just missed my 3 month waranty and will not pay for that repair again. people at home depot agree that this machine is trouble. the machine must be taken completely down from the top to replace the bearings and or the belt. the tub must be removed. If you call maytag they will pay for the labor but not the parts.
Jan 06, 2008 | Maytag Legacy Series Top Load Washer
MAYTAG WASHER SAV205DAWW
This calls for some dis-assembly of the washer. Are you still looking for assistance ?
Jan 01, 2008 | Maytag Legacy Series Top Load Washer
i can step you through it in a live chat session
Sep 27, 2007 | Washing Machines
Washing Machines Logo
4,987 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
