Question about Amana SXD524VW Side by Side Refrigerator
Freezer won't go below 32 degrees
Refrigerator and freezer won't cool. Condenser motor fan seized up. will replacing condenser motor fan repair unit? Unit is an Amana side by side
SXD22S2W
  • 409 Answers
Need condenser fan for unit to cool properly
Posted on Apr 28, 2010
Hotpoint refridgeerator not cooling HSS251FMD
Sounds like a Freon leak. How old is the unit? You will have to decide if it's worth fixing or to replace. GOOD LUCK FRIEND.
Nov 15, 2014 | Refrigerators
Maytag Refirgerator Model MTB2156FE freezer not cooling below 32 degrees
HI PAUL.FREEZER NOT COOLING could be for many reasons.go through the basics first .1-check if your freezer is iced up 2 if yes defrost it all completely first .then turn on 3-if ok then your problem could be 4-defrost timer 5-defrost heater 6-t/stat.if not iced up then check /clean thoroughly the condenser unit 7-check con/fan 8-check condenser should be warm/hot.if cold and motor hot then it could be lack of refrigerant (internal leak?) hope this helps.ALI
Jun 30, 2012 | Refrigerators
Refrigerator & freezer compartments @ 64 & 24 degrees F. respectively.condenser coil clean, however, "clean condenser coil" appears on display even after being reset. circuit board...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 16, 2011 | Sub-Zero 650 / O Bottom Freezer...
Frigidaire model PHSC239DSBO does not cool properly in both the freezer and refrigerator. The freezer temp will not go below 32 degrees and the refrigerator will not go below 53 degrees. Suggestions???
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Apr 15, 2011 | Refrigerators
Inconsistent cooling, no ice, noisy fan motor.
Refrigerator
Here is a tip that I wrote about refrigerators and the fan noise that they develop sometimes...
Refrigerator Fan Noise
heatman101
Feb 25, 2011 | Viking DFSB483 Side by Side Refrigerator
Fridge is working fine at 37 degrees, but freezer warmed up to 32 degrees. The Freezer is blowing cold air into the freezer compartment.
Refrigerator
heatman101
Feb 15, 2011 | GE Profile Arctica Stainless Steel Top...
I have a amana bc20tw fridge with bottom freezer that is keeping cold in the freezer and cool (43 degrees) in the fridge. I checked the coils in the freezer and there is no ice or major frost. Also, the...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Oct 15, 2010 | Amana ABB1927DE Bottom Freezer...
Sub zero 532. freezer works fine --0 degrees. fridge wont get below 50 degrees. cleaned condenser fins- still no decrease in temp
check the fan that runs between the freezer and the fridge --check fan for ice blockage -debris-or damage / clean or clear blockage --if not running test wiring and connections as well as motor /repair or replace //also check fan damper is not frozen or blocked its flap that opens and closes for air to flow //----ur fridge side is cooled from the the freezer side the cold air is blown in from the freezer if fan or damper is not working correctly than fridge is usually warm and freezer is working properly
Jun 28, 2010 | Sub-Zero 690 Side by Side Refrigerator
Samsung refrigerator Not cooling below 45 degrees
heatman101
dffg
Mar 14, 2009 | Samsung RF265AA Bottom Freezer French Door...
Amana SXD524VW Side by Side Refrigerator Logo
531 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
