Question about Ricoh FAX5000L Plain Paper Laser
Ricoh savin 3699/9980 fax
Need to reset service code 06 appeared when electricity came off then on How to enter service mode to try to reset
4 Suggested Answers
jaylex
  • 417 Answers
SOURCE: Ricoh Fax 3800L Error code
Hi there the error code that you are getting appears to be for the left lock where the fuser is make sure that the door is shut fully and turn the machine off then on again if this doesn't work then it is more likely to be the laser unit and this will need replacing.
Hope this is of some help to you.
Thanks J
Posted on Jan 06, 2008
jaylex
  • 417 Answers
SOURCE: Service error 0544 on a Ricoh Fax 5510L
Hi there the error you have is that the fuser unit is lower than 130 degrees for 1 minute. Suggestion replace fuser unit turn power off the on. If problem still persists replace control board or power board.
Thanks Jason
Posted on Aug 17, 2008
Logjam
  • 159 Answers
SOURCE: storing numbers in speed dail for the Savin Fax 3699
1. Press "USER TOOL"
2. Press 1.
3. Press 1 again
4. Enter 01
5. Press a free Quick Dial key
6. Enter the fax number.
7. Press [Name]
8. Enter name for this Quick Dial
9. Press [OK]
10 Press [OK] again
11 Press [PrevMenu]
12 Press [PrevMenu] again
13.Press [Menu]
14.Press[Exit]
Posted on Aug 19, 2008
blueydfox
  • 13 Answers
SOURCE: Richo 3310 fax
What is the model? There are not all the same for the service mode. And what is the reset code for?
Posted on Aug 28, 2008
Error 0548H Ricoh fax 4420L
Fuser Error. Check fuser thermistor. reset fuser error. Go to Service Mode press 1 0 7 , clear/stop , 1 copy, 5 mode, ok, 810, ok, change to 1, press half tone and ok simultaneously. fax will rebook automatically and fuser error is reset.
Jun 20, 2015 | Ricoh Office Equipment & Supplies
SC392 ERROR CODE
There's a video showing how to clear SC error codes: Resetting Ricoh Savin Lanier SC Error Code There's also a discussion here: Thread Ricoh Aficio 220 error SC392
Jun 30, 2014 | Ricoh 885288 Black Copier Toner Cartridge...
On digital screen of copier code sc555...what is the problem approx. how much to repair?
fuser temperature problem code.IF YOUR MACHINE IS A RICOH,SAVIN.
GESTNER, OR LANIER YOU CAN TRY TO CLEAR IT YOURSELF.PUSH
YELLOW CLEARALL BUTTON THEN ENTER 1,0,7.STOP HOLD THE STOP BUTTON DOWN UNTIL THE SCREEN CHANGES ABOUT 3 SECONDS.PUSH THE ICON BOX THAT SAYS COPIER SP A NEW SCREEN WIIL APPEAR DO NOT TOUCH IT. TURN THE MAIN POWER
SWITCH OFFFOR TEN SECONDS.THE MACHINE WILL ATTEMPT TO
RESET AND WARMUP PROPERLY IF CODE COMES BACK YOU WILL
NEED SERVICE ABOUT 200.00 FOR FIRST HOUR PLUS PARTS IF NEEDED
May 10, 2010 | Office Equipment & Supplies
They code from the display is 0-02H what is the meaning and what is the solution of that?
You haven't included the model number, but it looks to me like a "Ricoh" error code (or possibly Savin / Gestetner which are the same)
Error 02-02H is a fuser error, and is either the heater lamp, fuse or thermistor, causing the "warm up error". This can only be reset by a needlessly over-complicated procedure in service mode once the trouble is fixed.
May 04, 2009 | Office Equipment & Supplies
Ricoh Fax 3700L
Fuser error.....Either blown fuse, bad thermistor, or blown lamp. Problem needs to be repaired, and then a WAY over complicated reset procedure has to be performed in service mode to clear the error.
Apr 28, 2009 | Ricoh Office Equipment & Supplies
Richo 3310 fax
Aug 28, 2008 | Ricoh FAX3900L Plain Paper Laser
Richo 3310 fax
To enter in to service mode press: "clear modes" ,107, "red cl " and hold the red btn for 30 sec
all in that order.
Aug 22, 2008 | Ricoh FAX5510NF Plain Paper Laser
Need to reset savin 3740 fax to factory defaults
Found documentation of Ricoh's website. They are the manufacturor of Savin products. The default access code is 2222. Entering this allowed me to get into the network settings and change the IP scheme.
Jul 25, 2008 | Office Equipment & Supplies
Ricoh FAX5000L Plain Paper Laser Logo
98 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Bernard D'Souza
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
