Question about Garden
Fuel line diagram model 2450 - Garden
    President:
  • 2,220 Answers
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best. Fuel components and part numbers are listed but may be on different illustrations. They are also beneficial with disassembly/reassembly (a "2450 Gas Saw Type 7" example IPL follows. may not be your saw):
http://www.ordertree.com/modelinfo/PWE/2450-Gas-Saw-Type-7/75.2450-Gas-Saw-Type-7.1.59.1.html
Poulan.com (All models)
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
The Poulan print is deceptive, my schematic (below) is correct.
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on Apr 27, 2010
We need some fule diagram
Posted on Jun 12, 2010
3 Suggested Answers
wentlanv
  • 710 Answers
SOURCE: I HAVE TO REPLACE FUEL LINES ON A POULAN MODEL
Sorry to hear of your predicament. It's upsetting but not that hard to fix.
You'll have to drain the gas out of the tank first and toss it if it isn't fresh. Remove the filler cap. Take the cover off the saw and possibly the air filter if it's in the way.
Turn the saw upside down and shake the fuel filter to the opening of the gas tank (it's inside the tank) and grab it with a needle nose pliers and pull it out. If the line was that bad, you'll want to replace the fuel filter also.
You'll need to get new fuel line, which is clear tubing. You'll need about 6-8 inches of tubing.
Attach the new line to the fuel filter and feed the line into the gas tank and through the hole in the bottom. Pull it all the through to the interior of the saw. Feed the line around to the small metal tube on the carburetor. Before you connect to the carb, cut the excess line off.
If your saw has a priming bulb, connect the line to the fuel entrance on the bulb.
I hope this helps. If it does, I'd appreciate a 4 thumbs up vote. Thanks,
Handie Andie
Posted on Apr 15, 2011
Testimonial: "I SURE WANT TO THANK YOU. I DID JUST WHAT YOU SAID AND EVERYTHING WORKS GREAT. ONE PULL AND IT'S RUNNING. I HAD TO BUY A COUPLE TEES & DID WHAT YOU SA"
  • 2239 Answers
SOURCE: I replaced fuel and carb
It is quite difficult to explain exactly how it fits, the cable always looks too long and has to curl around on itself back to the trigger, the picture shows quite well how it goes, the end of the cable with a dog leg in it goes to the carb, as far as i remember it goes to the upper hole in the carb spindle, just push it into the hole and turn through 90%, the other end fits into the throttle trigger.adw1_9.jpg
Posted on Sep 10, 2011
Fuel line diagrams
What make, model and year is the bike you need a diagram for??
Sep 13, 2014 | Motorcycles
I replaced fuel and carb lines on my Poulan 2450 chain saw. I cannot seem to find the correct path/attachment for the throttle connection. Parts diagrams do not show this. Can someone provide a diagram...
Sep 10, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I HAVE TO REPLACE FUEL LINES ON A POULAN MODEL 2450 CHAIN SAW NOT SURE WHERE TO HOOK THE LINES TO AS THE OLD LINES WAS ROTTEN AND CAME OFF THE POSTS OR LOCATIONS WHERE THEY WERE HOOKED
Handie Andie
Apr 15, 2011 | Poulan Garden
Poulan chainsaw 2450 picture of gasline hoses conected
OK here goes, no pic but I will describe the best I can. This model should be equipped with a primer. The first thing you need to do is identify which connector is suction (in) and which one is return (out). Once you have done this it's simple. The return (out) has a line that goes right back to the tank. The suction (in) line hooks to the carburetor. The main fuel line from the tank with a filter on one end has the other end that connects to the carburetor. Now, with two fittings on the carburetor, find the one closest to the fuel pump cover (usually held on by one screw). This is the inlet fitting to the carburetor. This is where the fuel line connects that goes inside the tank with the filter on it. The lower or opposite fitting is where the suction line from the primer connects. This should do it. The return (out) line is usually a larger OD line than the suction & fuel line, which are the same size OD lines.
Feb 12, 2011 | Poulan Garden
Replacing fuel line on trimmer model 775r - have have removed all the fuel lines and the bubble, but have forgotten the exact pattern to replacing the three fuel lines
Hi: I'm a new user to this forum. I recently had to repalse the 3 fuel lines on my ryobi model #775r. After researching the problem, I diagramed the flow of fuel in order to repace the fuel lines. If you require a copy of this diagram, send me an email . Regards, Tony
Oct 07, 2010 | Ryobi Garden
I have a Poulan 2450 thats not getting any fuel, I drained the fuel tank. When I looked inside and the fuel line,the white filter and the gromet which goes from the inside to the outside of the tank was...
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, an output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Take lots of notes and a few digital photographs to help with reassembly.
Typical fuel system:
Poulan.com
2450 Gas Saw Type# - # is the dash number of your serial number.
HTH
Lou
No one illustration shows all fuel system components.
Nov 28, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Garden Logo
837 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
