Question about Garden
I have a strimmer that wont run. there is a spark there is fuel and all wiring is fine. When I try to start it it wont. I take the spark plug out and it is wet. Everything seems to be how it should be. I havent altered the adjustment screws or done anything to it bar take the spark plug out to check it
  • 333 Answers
The carborator is stuck open. The needle valve is leaking. Get a rebuild kit and rebuild it. Or since your gonna do that. Try and take it apart yourself, real easy so you dont rip the gaskets when you take it apart. Or better yet, take it off. The set screws are 1 1/4 turns out. Check them by tightning them up and counting. Then open em up few turns. Shake it around and blow through the fuel barbs with canned air. Make sure you hold the butterfly valve open like giving it gas. Then tap it against your hand blow out some more. Maybee you get the little varnish like stuff out of it and it start back shutting the gas off? Put together, Tighten both set screws all way in. Then back out 1 1/4 turns. Dry sqark plug with tourch. Put it in start it up. Then after it warm up run good. Final adjust the screws 1/8 turn in to make it run good.
Posted on May 06, 2010
My craftsman 25cc leaf blower wont start
pull the plug, plug into wire, touch head of plug to metal on engine. hold by rubber boot while touching pull starter, see if you get a spark across the plug gap, its small but you can see it. if no spark check switch. if plenty of spark clean fuel system and check primer
Nov 04, 2014 | Garden
My stihl fs56 strimmer will not start,i have a spark & fuel new plug cleaned carb help please
if you have spark and fuel then id be looking at lack of compression.. damaged piston ring or damaged crank seal/gasket
Apr 15, 2014 | Stihl Garden
2002 Blazer will not start. It fires and sounds like it is going to start every time I turn the key, but will not start. Sometimes it sounds like it starts, but dies immediately. (within 1 or 2 second
if you know its getting fuel then lest talk about spark check the spark plug wires and the spark plugs if you got spark see if your getting air check the air filter if its to dirty it wont start beacuse clean air wont come through
Sep 09, 2012 | 2002 Chevrolet Blazer
Petrol strimmer,, spark at plug,, petrol & 2
I have a flymo 430 petrol strimmer and cannot start it. ive cleaned the filter, put in new plug it went first time and then stopped and wont start again the plug seems to get wet all the time any ideas
Jul 03, 2011 | McCulloch Heavy Machinery
Will not start--new battery,alternator,cam sensor,crank sensor,plug wires..gets fuel and spark,starter fine,cranks but wont start.
put a timing light on it. if in time then spray some ether in intake. if tries to run now its a fuel problem. make sure plugs are gapped properly. if you got timing,spark,gas at right pressure, and compression it should run.
Jun 21, 2010 | 1996 Subaru Legacy
Running fine. Died and wont start. Cranks fine
can you hear the fuel pump kick on when you turn the key on but without crancking the engine? Generally the fuel pump will prime for about two to three seconds when you first turn the key on. if you don't hear it that's probably the culprit. If you do hear it it may be a bad pump. also should check to see if you have spark. You can do this by removing a plug wire and using another spark plug. Ground the plug to somthing metal and have someone crank the engine (making sure you are not touching the plug or metal) You should see a spark while cranking. Good luck
Jun 20, 2010 | 1985 Ford F150
1989 Cutlass wont start
the filter on fuel pump might be clogged as well or fuel pump needs replaced
Oct 01, 2009 | 1989 Oldsmobile Cutlass Ciera
2004 tahoe. Worked fine two days ago. Wont start but turns over. replaced fuel filter,now what?
check for spark and fuel at the motor! take one of the spark plug wires off and remove the spark plug and put the wire back on it and rest the spark plug on a negitive ground point and have someone try to start it and see if the is spark. to check to see if fuel is getting up there locate the fuel presure relief valve on the fuel rail that the injectors are connected to and while someone it trying to start it depress the valve and see if fuel squirt out.
Sep 16, 2009 | 2004 Chevrolet Tahoe
Petrol strimmer good spark but wont start
if it ran fine then it quit it is more likely the pick up tube in the fuel tank
Sep 14, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
