Question about HP LaserJet 1320 Printer
We have a HP LaserJet 1320 printer that is leaving black marks or streaks on the paper-maybe ghosting(?). We have switched cartridges and it is still appearing. Any help would be appreciated!
    Guru:
  • 1,049 Answers
Vertical lines, ghosting, streaks, and dots usually indicate a problem with the fuser when it doesn't regulate temperature correctly. When this happens the toner sticks to the drums and then copies the impression on successive pages, or gets scratched by the sand papery build up making lines as each sheet goes through.
Horizontal lines, page dusting, and vacant areas on the page are usually the toner or the drum, which on most printers are one unit.
If you have replaced the cartridge and the problem didn't go away, you probably have to replace the fuser.
Posted on Apr 27, 2010
Hp lasject 4050a toner cartridge have black line in the paper
The vertical lines can be caused by a damaged fuser assembly. The fuser heats the toner and melts it onto the paper. The roller is covered with teflon and when it gets worn down it leaves streaks or "ghost" images on the paper. Here is an article dealing with the lines on a Laserjet 2100 printer but the cause is the same for the 400 and 4050 series printers. Check your fuser as per the information in the above article and if need be order a replacement fuser from somewhere like Amazon.
Mar 16, 2013 | HP LaserJet 4050n Printer
HP LaserJet 1320 Printer Problems & Solutions leaving black streak on far outer edge of paper left side
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage. Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head. Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Feb 14, 2011 | HP LaserJet 1320 Printer
I m getting dotted dashed vertical line while printing
Cartridges: Most of these problems are related to the toner cartridge. If you don't have another cartridge to test it you can diagnose the problem another way. Put a sheet of paper in tray 1. Run a configuration page with your hand on the power switch. When the page reaches midway, turn the power off. You may have to do this a couple more times to get the timing correct. Now that you have stopped the paper midway, carefully remove the cartridge and the paper from the machine. Inspect it to see if the problem exists before it reached the fuser. If it does then it is in the cartridge, or possibly it could be in the Laser or scanner assembly. If it does not, then you have a bad fuser assembly. Remove the fuser and inspect it.
It could also be the transfer roller:
When the transfer roller begins to fail, one of the first signs of trouble will be black streaks on the paper. If you notice black marks on the sides of your printouts, chances are your LaserJet printer has a transfer roller that has begun to wear out. These black marks look like tire treads, so if you see that type of pattern it is important to order a replacement transfer roller and install it as soon as possible.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jan 29, 2011 | HP LaserJet 1320 Printer
My HP LaserJet 1320 is showing an Orange Light ( Exclamation mark inside the Triangle) and i could not make any printing... It's keep showing that problem after restart the Printer. Can anyone give me some...
if the light is blinking it means
1. either the cartridge door is open
2. or paper tray is empty
3 or paper is misfeed
4. or paper jam
Verify that the print
cartridge is present and
that the print-cartridge
door is closed correctly.
2. Verify that media is
present in the input tray.
3. Clear any jams and
perform paper-path
functional checks.
4. Make sure that the
interlocks are operating
correctly.
Jan 12, 2011 | HP LaserJet 1320 Printer
HP Laserjet 1320 replaced cartridge, toner light stays on
it may be not a genuine one, or you have a paper jam inside the printer
Mar 25, 2010 | HP LaserJet 1320 Printer
Leaves streaks vertically on paper changed cartridge still there. 2600n printer
when you open the front of the print you will see the streaks on the black transfer sheet.
Close the front door half way or until all the cartridge doors open.
You will see the same streaks on the problem cartridge(s) as on the transfer sheet.
Change that particular cartridge, let the printer recalibrate, and presto streaks are gone.
Feb 13, 2010 | HP Color LaserJet 2600n Printer
Hp laserjet 1320 black tint printing on paper
you must be change your toner cartridge
Nov 05, 2009 | HP LaserJet 1320 Printer
Laserjet 1320 is printing a streak down the left side of the page. I replaced the fuser and toner. What's next?
Checking the paper path for ink deposits might be the solution. I had a similar problem sometime ago, where the fuser got some scratch damage for unknown reasons and i suppose was causing unfused ink to accumulate after the fuser, leaving streaks on paper.
Oct 23, 2009 | HP LaserJet 1320 Printer
My LaserJet printer prints lines or streaks on every page
Can't read the entire heading for your post, but it sounds like a defective toner cartridge. Replace it.
Apr 25, 2009 | HP LaserJet 1320 Printer
STREAK LEFT ON RIGHTHAND SIDE OF PRINTED PAGE
Fuser sleeve is contaminated and needs replacing - cheaper to replace the printer.
Apr 16, 2009 | HP LaserJet 1020 Printer
HP LaserJet 1320 Printer Logo
1,217 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
