Question about Dell 2130cn Laser Printer
I have a constant 'paper jam' message on DELL 2130cn.
I have a constant 'paper jam' message appearing everytime I print but there is no paper jammed. It seems to be struggling to pull the paper through the printer from the tray. Any suggestions?
FixinFax
  • 3085 Answers
SOURCE: My HP2600n continues to say Jam in Tray 2 and is
Pull out the paper cassette and clean the rubber feed rollers with alcohol.
Posted on Jul 06, 2009
SOURCE: Dell photo printer 942 all in one paper jam
Paper jams can be real or false. The all-in-one may report a paper jam when there is not any jammed paper, however, the solution to a real paper jam or a false paper jam is the same. Up-grading the printer firmware could also fix this kind of issue, however I would appreciate if you try the steps below before you up-grade the printer firmware.
To fix the paper Jam errors please try the following steps:
1. Confirm that no foreign materials are inside the machine.
2. Confirm that usable paper is set.
3. Confirm that the paper is set properly.
4. Confirm that recommended paper is used, and the number of sheets set does not exceed the required limit.
5. Disconnect the printer power cord as well as the printer cable form the printer.
6. Turn the printer upside down and shake the printer in order to remove any obstacle which is stuck inside the printer causing the paper jam error.
Open the printer cover and remove the cartridges and check carefully if there is any small piece of paper which is stuck inside, if so carefully remove it.
7. Disconnect the printer power cord and press and hold the power button on the printer for about 15 to 20 seconds( this will release the flee power) and reconnect the printer and check.
If the above mentioned steps do not fix the issue please up-grade the printer firmware form the Support.dell.com web site. However make sure that you do not turn off either your printer or computer when you are downloading and installing the printer firmware.
Alternately you can also try to download the and install the printer drives form the support site if the paper jam message is being displayed on the computer’s screen but not on the printer’s LCD screen.
Should you require any further assistance regarding the printer or even any other computer related issue please feel free to contact me I will be more than glad to assist you.
Regards
Malik Khan
Posted on Jan 31, 2008
  • 13433 Answers
SOURCE: paper jam ,no paper jam found Dell 1815dn
give this a try
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Posted on Jun 12, 2009
  • 685 Answers
SOURCE: I have a paper jam
On that printer, you can't pull out the main tray. This video shows how to clear a paper jam on the C7280.
Posted on Jun 17, 2009
SOURCE: I have 2 Dell model 1700n laser printers and they
Take off the two rubber rollers, turn them inside out and replace them, Voila!
Posted on Aug 23, 2009
I keep getting an error message about a paper jam for my printer but there is absolutely no paper jammed anywhere in the machine.
Have you tried a new toner cartridge, The toner cartridge has moving parts, and of the cartridge gets stuck, the printer may indicate a paper jam.
Also paper often tears when clearing jams, and the little shreds of paper can stay in the rollers of the printer and keep it jammed. Make sure to inspect all the rollers to make sure they move freely, and do not have anything stuck in them.
Aug 21, 2014 | D-Link D LINK DELL B1260DN MONO LASER...
Getting a constant "Paper Jam 071-100" error when printing from Tray 1 (no jam found).
You need to replace the paper pick up, feed rollers and separation sub-assebly.
Nov 27, 2012 | Dell 3115CN
Dell 2130cn printer has error message 077-901 but I can find no paper jam.
Hello everybody! i resolved this kind of problems by removing the small piece of paperwas jammed in, my advice is just check inside printer because I did it for 10 or may be 15 times and fixed it on 16 times )))
Apr 25, 2011 | Dell 3130cn Color Laser Printer
My Dell 1720dn constantly has paper jams. A
I am having the same problem, did this get resolved?
Dec 02, 2009 | Dell 1720dn Laser Printer
Dell printer 3110CN keeps saying paper jam everytime we try to print.
you probably have a paper jam. Check all the places the paper goes to find it. Front cover using the button on the side, the back, the fuser, where the cartridges go. Check everything.
Good luck
Nov 26, 2009 | Dell 3110cn Laser Printer
Constant paper jam
It appears to be the printer it self is malfunctioning and may require service. Please call your printer manufacturer and ask for warranty.
Aug 14, 2009 | HP PhotoSmart C4280 Laser Printer
Paper jam 11
Step1
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Step
Step
Step
Step
5
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
Step
6
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
Step
7
If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
Step
8
Step
9
Nov 07, 2008 | Copystar CS-1815 Printer
Dell 2130cn Laser Printer Logo
678 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
