Question about Singer 1116 Mechanical Sewing Machine
Needle jams and breaks off
When I attempt to sew, my needle jams after the 3rd or 4th stitch. When I manually rotate the wheel to loosen it and proceed again, the needle breaks off. I have a Singer model 3116. It is only 1 year old. I have tried to rewind the bobbin, which is where the thread bunches up, but it has not helped.
  • eiman Mar 26, 2008
    i need the user manual plz
    thanks
  • 25 Answers
Needle jams....Thread is caught in the hook...solution...Remove the upper thread and bobbin case,turn the handwheel backwards and forwards by hand and remove the thread remands.
Needles breaks
1. Needles is damaged..Insert new needle
2. The needle is not correctly inserted....insert flat side towards the back
3. Wrong needle size for the fabric...Choose a needle to suit the thread and fabric.
Posted on Jun 02, 2009
  • Jimmie Sill Jun 22, 2014
    When you turn the hand wheel towards you monitor the hook (under the bobbin case) and see if the needle is hitting the hook or not. If it is then you will need to have it timed.
My sewing machine shark euro-pro 361 is jammed. Needle will not move. What do I do
See if you can remove the bobbin from the machine. Most likely the bobbin and upper threads are entangled and have trapped the needle. You can remove the presser foot and loosen the needle from the needle bar (as though you are going to remove it). Then if you get a small pair of scissors in there and start nipping thread pieces and removing them with tweezers, you may be able to loosen it up.
Jan 16, 2017 | Euro-Pro Sewing Machines
The needle and fabric are stuck
Here are some ideas:
  • Try reversing your stitching,
  • Pull the fabric gently on either side of the fabric in the needle to see if it loosens it from the area.
  • Remove the needle from its holder (usually held with a thumb screw) and pull gently. Snip the thread and pull a little more to remove the needle. Rotate the wheel on the side of the machine to see if that loosens the fabric.
Jun 23, 2013 | Singer 3116 Simple
Needle hits the wheel under bobbin
Sounds like the toothed-belt (if there is one) jumped off timing. You can try realigning until the needle goes into the hole as the bobbin holder rotates in place. You can do this by manually slowly operating machine -- do not do with electric pedal.
Oct 08, 2012 | Singer CG590 Mechanical Sewing Machine
Machine stitches 2 0r 3 stitch then skips stitches on rest of seam
try changing the needle
Sewing machine skips stitches
needle inserted incorrectly--flat side of the needle faces the shaft
round needle--groove of needle faces away from the shaft
Raise the needle bar to the highest point, then loosen the clamp screw to remove the needle. Place the new needle in the clamp with the flat side of the needle facing the back of the machine.
If round needle--the groove in the needle faces away from the shaft
Push needle all the way up to the stop or as far as it will go.
possible bent needle--lay needle on flat surface & roll needle over, if the needle does not roll good -replace
blunt needle point--needle makes a popping sound when needle penetrates the fabric--replace needle
needle not all the way up in needle holder--loosen needle clamp screw & push the needle up until it stops then tighten screw
incorrect threading--one step missed in sequence of threading can cause machine to skip stitches
wrong needle in machine--check instruction manual--some machines can use a generic needle with no problem--some can't--
size of needle & thread not compatible--
Using the wrong type needle can cause problems,,
A needle to fine for heavy fabric can bend or break when it hit's the fabric
And a too large needle can make puncture holes in the fabric and pull unevenly while stitching
Jun 01, 2012 | Janome 6019QC Mechanical Sewing Machine
3rd and 4th threads are breaking
Hiya Fiona, i think your problem may be that the tensions are not correct. Try pulling the tread with your hands to see if they are too tight or too loose and either tighten or loosen tensions accordingly. Hope i was of some help to you, kind regards.
Feb 11, 2012 | Sewing Machines
Needle breaks hits needle plate
Check to see if plate is damaged or needle is bent. Could be wrong needle style for the type of work you are doing.
Jan 27, 2012 | Singer Sewing Machines
It is a singer quantum futura ce 200 sewing and embroidery machine .the machine sews but incomplete,skipping and missing stiches. does not always bring up bottom thread . grrrrr---help, i want to sew
1.needle inserted incorrectly--flat side of the needle faces the shaft
2.Correct needle insertion is mandatory for proper use.
3.possible bent needle--lay needle on flat surface & roll needle over, if the needle does not roll good -replace
4.blunt needle point--needle makes a popping sound when needle penetrates the fabric--replace needle
5.needle not all the way up in needle holder--loosen needle clamp screw & push the needle up until it stops then tighten screw
6.incorrect threading--one step missed in sequence of threading can cause machine to skip stitches
7.wrong needle in machine--check instruction manual--some machines can use a generic needle with no problem--some can't--
8.size of needle & thread not compatible--
Sep 14, 2011 | Singer CE-200 Quantum Futura Computerized...
How do i put the bobbin case back in correctly?
The zigzag setting should not have caused it to jam up unless the tensions were off and the thread was bunching up on the bottomside of the needle plate. If you ever jam or break a needle be sure to replace it with a fresh new needle. A slightly bent needle will cause all kinds of problems.
When putting the bobbin back in make sure you keep a good amount of thread hanging out and manually turn the hand wheel around until the needle make a full rotation. The hook should catch the needle thread and allow you to pull the bobbin thread out through the needle plate.
If you jammed it really good it is possible that the needle and hook timing is out of sync in which case you may need to have it re-timed.
Jun 08, 2009 | Singer 6038 Mechanical Sewing Machine
The bobbin is getting caught and needle is jamming
This sounds like there is cotton stuck in the bobbin holder. Check it thoroughly. Take the bobbin out and turn the wheel to lower the needle a few times. This will show up any thread caught. Pull it out gently. You may have to perservere to get it all out.
Oct 19, 2008 | Singer 15ND Mechanical Sewing Machine
Can't change needle/machine freezes!
Hi Ana...To remove/replace needles, loosen the screw on the right side that is attached to the Needle Clamp, which is located at the bottom of the Needle Bar. Your sewing machine should have come with a "kit" that included a small screwdriver. Use this screwdriver, or any compatible screwdriver to loosen the set screw by turning it "towards you" in a counter-clockwise direction. Discontinue turning once the screw is loose, and the needle clamp has a little play on it. While holding your replacement needle in your hand, observe that the top of the needle, which you insert into the needle clamp, has a flat side, and a round side. You want to have the round side facing you, and the flat side away from you to properly insert the needle. Ensure that you continue to apply upwards pressure on the needle until it stops, then finger tighten the Set Screw firmly, but there is no need to clamp down on it. Also observe that with the round side facing you, the majority of the remaining needle has a groove in it. This groove is designed to accomodate the thread as the needle penetrates the fabric, hence creating a hole diameter not in excess of the needle size. As for the physical malfunctioning of your machine I may need more specific information, including whether the beeping is continuous or not. If not continuous, count the number of beeps. If it beeps more than one cycle, count those beep numbers as well, and post the numbers here in chronological order. However, I suspect that the machine is simply running/sewing while you are locking your stitch by hitting the reverse. Normally, hitting reverse while sewing is not an issue, however, if your particular machine has the slightest Feed Dog timing flaw, it can cause needle breakage, fabric bunching, and lockups. So as a test, sew some scraps, and recreate your forward/reverse steps, but this time, do not press or release the reverse unless the machine is at a complete stop, and the needle is in the up position, and free of the fabric. You can manually move your needle vertically by turning the Balance (hand) Wheel located on the right of your machine. Note that should you have to manually turn the wheel to reposition your needle, always turn it in a counter-clockwise direction only......I hope these steps resolve your issues, but please update your post if we still have some work to do.....good luck my friend.
Jul 23, 2007 | Singer 7422
Singer 1116 Mechanical Sewing Machine Logo
382 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
