Question about Canon Office Equipment & Supplies
The copier has a major paper jam. How do I get
The copier has a major paper jam. How do I get inside? I have tried everything obvious and have even tried to take it apart hoping to get inside where the paper is smashed.
  • Leroy Elliott
    Leroy Elliott May 11, 2010
    What copier? Are we supposed to guess?
  • Kyocera HP Expert May 11, 2010
    what model is your copier? and what is the jam code?
  • 1,219 Answers
Wich copier model?
Posted on May 10, 2010
There is a paper jam inside the printer and i dont know where
For some paper jam like this it will be better if you blow air inside your printer and make sure everything is clean and not even a small piece of paper is causing the problem. SO better do check again the inside of the printer and use a flashlight for you to see everything.
Feb 07, 2013 | Samsung ML-1660 Monochrome Laser Printer...
I have a problem with an error of "Jammed paper" and I cant see any paper jammed, What should I do?
Sometimes a "jammed paper" error message is caused by a very small piece of paper lodged inside around a roller, and can't be seen with removing a cover or something, It isn't always a full sheet of paper in an obvious place that causes the problem. poke around inside and look for a tiny culprit, goodluck!
Mar 27, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Paper jam message does not clear after paper jam has been removed
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your copier
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the copier
5. Close all doors and put back all trays
6. Turn on your copier
NOTE: Please rate our help to keep this free service online.
Jan 08, 2010 | Canon imageCLASS D480 Black and White...
Jammed paper the jam is obvious when trying to slide paper drawer in. Jammed Paper is not visible Lifting movable parts does not expose paper
1. Turn off your printer
4. Repeate the above step for all buttons that you can find to access the inside of the printer
6. Turn on your printer
Dec 07, 2009 | HP Photosmart C7280 Laser Printer
My Printer Jammed
If it states that it's jammed, there must be some tiny piece of paper or lint or a foreign object still inside your printer. Check the paper path again.
Oct 08, 2009 | Canon MX300 Office All-In-One Printer
PAPER JAM WITH NO PAPER
This may be caused by a dirty sensor. Disconnect power supply, open the printer and clean everything. You may use toilet paper. Be careful not to leave fragments of toilet paper inside the printer.
May 05, 2009 | HP PhotoSmart C4180 All-in-One Color...
Orange Flashing Light
plz try by reinstalling the drivers and report back
May 31, 2008 | Office Equipment & Supplies
Paper jam
There are several things that can cause a paper jam error, even though there is no paper stuck. The most common is that the paper pickup rollers are worn or dirty, and can't grab paper. Even though there is no paper jammed in the machine, it will show the error message. The solution is to clean the roller with alcohol and a lint-free cloth (don't use paper towels). If the roller is very worn, you will need to replace it.
Feb 04, 2007 | Canon Image Runner 1630 Copier Copier
Major problem please help
i have had that problem for about 3 or 4 months and tonight i went inside and just started cleaning everything and my paper feeds right now. it was really weird. it just started working out of the blue.
Jan 23, 2007 | Canon PIXMA MP170 All-In-One InkJet...
old marine
old marine
