Question about Samsung HCL4715W 47" Rear Projection Television
The colour has pulled away - Samsung HCL4715W 47" Rear Projection Television
    Problem Solver:
  • 19 Answers
Bad ic,s in convergence board ...need be replaced,
Posted on Apr 27, 2010
Replace power cord
Get replacement cord.
Remove cover (remove screws and pull cover from the rear away from front)
If cord is pin plugged then remove one colour at a time and replace with same colour.
If soldered then you need tools (take it to repair centre)
Replace cover and screws
May 03, 2014 | Whirlpool Microwave Ovens
I need to find my door keypod code
Open the right/rear door. Gently pull the on-body weatherstrip slightly away from the body at the rear side of the door opening. Fold and lock the right/rear seat back down into the locked position. Carefully pull the trim panel that houses the seat belt height adjuster and anchor pivot off of the body. Now carefully pull the lower trim panel from the inside outward far enough to expose the VSM (Vehicle Security Module). This module has three electrical connectors plugged into it, coloured green, grey and blue. On the module is a label bearing a number similar to 4L2T-15K602-EA. On the same label will be FIVE large numbers. Those five numbers are your five digit key-less entry keypad code.
Jan 18, 2011 | 2004 Lincoln LS
1999 VT 1100-How do I remove the decal or tank badge from tank?
For stick on decals try using hot soapy water and a lot of care .don't pull too hard as you may take of paint with the decal once you have poured the hot soapy water over the decal ,try and get the edge of the decal to come away from the tank .start with your thumb nail Never use any abrasive tool like a knife or screwdriver as this will scratch the paintwork.and once you have a finger grip pour hot water on the decal directly where its attached to the tank .The hot water softens the glue on the decal .pull very gently .it does help tp have another person pouring the water on the decal ,this will leave your hands free to remove the decal.Once decal has been removed ,try using a small amount of petrol on a rag or a good colour restorer polish .to remove the glue left on the tank .Depending how long the decal has been on the tank ,you may well find that the sun has bleached the tank from it original colour .and the paint under the decal will be much fresher looking and of a deeper colour.
Mar 13, 2010 | 1999 Honda VT 1100 C Shadow Spirit
Nintendo top pulled off hinges
Look on ebay for replacement shells for DS.
There around $15 and you also need to buy a Special Nintendo Screwdriver
Dec 07, 2009 | Nintendo DS Lite Console
Error message won't go away
hmmmm.....try to shutdown or shut it off your printer ...and then up it again..^_^..
May 12, 2009 | Canon Office Equipment & Supplies
Problem
Hi Ginger, The Magnet in the speaker has affected the Electrons beams inside the TV.All uou gotta do is remove the speaker - move it to around 3-5 feet away. Use the TV normally. Most Colour TVs have an in built de-gaussing unit inside them, which will clear any remnanrmagnestism. Will resolve itself over 2-3 days. Alternately, go to a Electronic Tools store, and buy a Portable Degaussing unit. Follow instructions and use. Problem will be solved in minutes.
Apr 14, 2009 | Orion1934 19" TV
Canon LBP5000 laser colour printer. Problem: 'Out of Register Colors Correction has not been performed. Perform calibration again'. I have carried out this instruction so many times, the error keeps...
Had the same problem a while ago.
In my case it was simply that the plastic tab had come away from the plastic strip you're supposed to pull out from from the cartridge before installing. Found the end of the plastic strip and pulled it out and this sorted the error.
An additional problem we had was alignment of the colours when printed. Magenta and black were misaligned by about 0.5mm after changing a cartridge. This was cured (after much frustrated cleaning/calibration) by switching the printer power off and on (couple of minutes to cool down).
Hope this helps.
AJ
Nov 16, 2008 | Office Equipment & Supplies
Televison probs
Most tv's degauss themselves when turned on so turning off and on a few times might help. Leave about 15 minutes between on off cycles and keep on trying untill you see improvement. You could also get hold of an old tape eraser, plug that into the mains and starting from a foot or so away try to brush the badly coloured parts away without coming to close to the screen.
Jan 13, 2008 | Beko 324250WN 28" TV
On preview & scanning I get total red colour image
If you have loaded Adobe 8.X Reader, then unload it, and go to Adobe site and load Adobe 7.02 Reader. Problem will probably go away. Mine did, I can now scan in color again.
Dec 03, 2007 | Umax Astra 3400 Flatbed Scanner
Samsung HCL4715W 47" Rear Projection Television Logo
Jerry Greenberg
Jerry Greenberg
