Question about Boating
How do I remove lower unit to replace water pump on 50 hp 4 cycle out board?
  • 5 more comments
  • Dana Pack Apr 27, 2010
    I removed all bolts from lower unit, but the bottom part does not come free. I tapped with hammer, but unit is still tight with upper part of motor. Do I use more force?
    I can not get my lower unit to let go of the upper part on my 2001 50 hp Yamaha 4 stroke boat motor. I have tapped it with hammer. Should I use more force? I need to change the water pump.
    Thanks
  • Dana Pack Apr 29, 2010
    Daveslave
    I still can't get the lower unit to let go. I took oak 2"x 2" placed on the lip of the unit and hit pretty hard with a dead blow hammer, and still not loose. What else can I do? I have removed a total of 5 bolts. There is nothing else I can see holding it.
    Help
    IT IS F50TLRB
    62Y L 1002589
    Yahama Four Stroke
    F50TLRB
    62Y L 1002589
    Year 2002
    This is all info on tag
    Thanks
  • Dana Pack Apr 30, 2010
    That got it. There is a hidden bolt under that plate.
    Thank you so much
    Dana Pack
    I could have never gotten the lower unit off with out the help of Fixya experts. Thank you.
  • 154 Answers
These are installtion instructions for a mercury so it may vary just a little if any.
  1. Remove the bolts from the lower gear housing (the portion of the motor that has the prop attached). Be sure the transmission is in neutral and that all four bolts are removed from the housing.
  2. Step 2 Slowly, but firmly pull the lower housing away from the upper housing. The only things holding the two parts of the housing together at this point will be the driveshaft, transmission shaft and wiring harnesses. Disconnect the wiring harnesses and pull the lower housing the rest of the way off.
  3. Step 3 Mount the lower housing in an engine vice with the driveshaft pointed up or parallel to the ground. Remove the four bolts holding the water pump onto the transmission using the ratchet set. Carefully slide the water pump housing up over the driveshaft.
  4. Step 4 Using a screwdriver, pry the impeller out of the housing and examine it for cracks or inconsistencies. Also inspect the interior of the water pump housing for cracks, gouges, or general wear.
  5. Step 5 Remove the water pump gaskets still attached to the top of the transmission housing. There should be three in this order: rubber gasket, metal gasket, rubber gasket. Replace with the new gaskets from the water pump repair kit (make sure to lube the gaskets with the engine oil prior to mounting).
  6. Step 6 Slide the new impeller down the driveshaft and then seat the water pump housing on top of it. Give the driveshaft a slight clockwise turn while pushing down on the water pump housing in order to bend the impeller fins in the correct direction. Reinstall the four water pump bolts and slide the transmission housing back into place with the motor housing.
  7. Step 7 Reconnect the wiring harnesses, mount the upper and lower housings together and replace the housing bolts. Test the water pump by lowering the motor into the water and turning it on. Water should spray in a stream out of the water purge hole if the pump is working correctly.
Posted on Apr 27, 2010
  • 1 more comment
  • dave taylor Apr 27, 2010
    you need more force not blunt force, but firm force because its on thier very tight, has to keep water tight so i would get another guy to help u pull it apart because when i did it, it took two. sorry it took so long didnt realize u still had problems good luck
  • dave taylor Apr 29, 2010
    ok whats the model number, ive done this to like 10 ouboard motors they get stuck but pressure is the key let me look up your particular motor so i can see what exactly is going on.
  • dave taylor Apr 30, 2010
    did you take the round metal plate off above the propellor there is a bolt under there too. Sorry just got off work trying to get this problem resolved for you.
    President:
  • 1,194 Answers
Thanks for using Fixya.
To remove the lower unit to replace water pump, please follow these instructions:-
1. Remove the bolts on your lower unit (just below the anti-cavitation plate) using a 12 to 14 millimeter wrench. The make of your outboard motor will determine which size wrench you need to use. All the bolts should be the same size.
2.Take the trim tab (anode) off the bottom of the anti-cavitation plate. You will find the tab right above the propeller. The tab's position on most outboards will be bolted through the bottom of the trim tab. Keep the tab and the bolt separated after you remove them.
3. Remove the last bolt from the lower unit. This will actually detach the lower unit from the motor. Handle this step cautiously to avoid having your lower unit slide out uncontrollably. The lower unit should be entirely free from the motor after you perform this step.
4. Place the lower unit that you removed in Step 3 aside in a safe place. The motor and shift shafts will be exposed once the lower unit is removed. Proceed with removing the motor and shift shafts by applying gentle pressure and sliding them out.
5. Take the bolts off the plastic casing that houses the water pump. Handle the bolts with care to minimize breakage due to corrosion. You should easily be able to lift the casing off of the water pump once you have removed these bolts.
6. Slide the pump impeller over the motor shaft. Remove the steel plate along with the gasket that the impeller was on.
7. Take the stainless steel cup and "o" ring out of the plastic casing that you previously removed. Also, remove the key way from the motor shaft by gently tapping it with a standard screwdriver (flathead) in a top-down motion.
8. Lay the parts of your new water pump kit out neatly in your work space. Installation of your new outboard motor water pump will take place in the exact reverse of dis-assembly. Replace the gasket for the steel plate in it's original location. Put the gasket back over the steel plate and make sure that is securely fitted over the gasket. Install the new key way. Locate the small indentation on the impeller and line it up so that it is properly placed back atop the stainless steel plate. Put the new "o" ring around the outside edge of the cap. Set the new stainless cup in place inside the plastic casing. Slide the stainless cup and "o" ring over the motor shaft to the impeller. Turn the motor shaft clockwise while pressing down on the plastic cap. Grease the bolts that secured the plastic casing and replace them.
9. Grease the tops of both the motor and shift shafts. Grease and replace the bolts.
10.Reinstall the lower unit by finding the two holes in the mid-section of the motor. Line the shafts up to the holes and insert.
Good luck and have a nice day.
Posted on Apr 29, 2010
  • Ranglo
    Ranglo Apr 30, 2010
    If you think you are helped by my solution, please rate it accordingly.
  • 821 Answers
Hello,kindly follow the instructions below
  2. Step 2 Take the trim tab (anode) off the bottom of the anti-cavitation plate. You will find the tab right above the propeller. The tab's position on most outboards will be bolted through the bottom of the trim tab. Keep the tab and the bolt separated after you remove them.
  3. Step 3 How do I remove lower unit to replace water pump - fix-outboard-motor-water-pump-1.3-120x120.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep3 span.image a:first').attr('href','http://i.ehow.com/images/a04/er/6f/fix-outboard-motor-water-pump-1.3-800X800.jpg'); }); Remove the last bolt from the lower unit. This will actually detach the lower unit from the motor. Handle this step cautiously to avoid having your lower unit slide out uncontrollably. The lower unit should be entirely free from the motor after you perform this step.
  4. Step 4 Place the lower unit that you removed in Step 3 aside in a safe place. The motor and shift shafts will be exposed once the lower unit is removed. Proceed with removing the motor and shift shafts by applying gentle pressure and sliding them out.
  5. Step 5 jQuery(document).ready(function(){ jQuery('#jsArticleStep5 span.image a:first').attr('href','http://i.ehow.com/images/a04/er/6f/fix-outboard-motor-water-pump-1.5-800X800.jpg'); }); Take the bolts off the plastic casing that houses the water pump. Handle the bolts with care to minimize breakage due to corrosion. You should easily be able to lift the casing off of the water pump once you have removed these bolts.
  6. Step 6 jQuery(document).ready(function(){ jQuery('#jsArticleStep6 span.image a:first').attr('href','http://i.ehow.com/images/a04/er/6f/fix-outboard-motor-water-pump-1.6-800X800.jpg'); }); Slide the pump impeller over the motor shaft. Remove the steel plate along with the gasket that the impeller was on.
  7. Step 7 Take the stainless steel cup and "o" ring out of the plastic casing that you previously removed. Also, remove the key way from the motor shaft by gently tapping it with a standard screwdriver (flathead) in a top-down motion.
  8. Step 8 Lay the parts of your new water pump kit out neatly in your work space. Installation of your new outboard motor water pump will take place in the exact reverse of dis-assembly. Replace the gasket for the steel plate in it's original location. Put the gasket back over the steel plate and make sure that is securely fitted over the gasket. Install the new key way. Locate the small indentation on the impeller and line it up so that it is properly placed back atop the stainless steel plate. Put the new "o" ring around the outside edge of the cap. Set the new stainless cup in place inside the plastic casing. Slide the stainless cup and "o" ring over the motor shaft to the impeller. Turn the motor shaft clockwise while pressing down on the plastic cap. Grease the bolts that secured the plastic casing and replace them.
  9. Step 9 Grease the tops of both the motor and shift shafts. Grease and replace the bolts.
  10. Step 10 Reinstall the lower unit by finding the two holes in the mid-section of the motor. Line the shafts up to the holes and insert.
  11. thanks for using fixya,
take care.
  • Hammid Disu Apr 27, 2010
    hello,please look vividly that you have removed all the bolts successfully,it is not that difficult.you can as well follow the video link below....
    http://www.youtube.com/watch?v=E-uzQi7Ig...
    take care.
I have a 50 hp Johnson outboard or do I disconnect the shift linkage to get the lower unit off
have a look at the videos
How to remove the lower unit on a outboard engine - YouTube
? 3:24
https://www.youtube.com/watch?v=R6wVMc8GD0w
Mar 29, 2015 - Uploaded by Greg Drinkwater
How to remove the lower unit on a 1989 Johnson 88 SPL Help me remove lower unit. Johnson 90 hp ...
Johnson 50hp Outboard Lower Unit - YouTube
? 2:15
https://www.youtube.com/watch?v=DnU7vKcJkeE
Apr 9, 2016 - Uploaded by Stacy Wyoming
Removing Bearing Housing From a 50 HP Evinrude - Duration: 2:15. Brandon's Garage 274 views · 2:15 ...
how to remove lower unit on johnson outboard - YouTube
? 0:47
https://www.youtube.com/watch?v=_ygxZSxU6-I
May 24, 2016 - Uploaded by 2222buster2222
How to remove your lower unit on a 1984 Johnson Outboard 70HP.
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump ...
? 24:26
https://www.youtube.com/watch?v=Hv8gXqsO2fg
Jun 3, 2015 - Uploaded by Ralph Pierre
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump Service. ... Just bought a Bass Tracker ...
50 hp Johnson outboard remove lower unit Google Search
Jul 07, 2017 | Johnson Boating
Malber WD1000 wont condense the water that is fed through during the drying cycle
Since it drains properly during the wash cycle, we know the drain pump and its impeller (propeller) work, and the coin trap (you called it a filter) and hoses are not clogged. By the way, turning the rightmost knob to "4" will start the pump-out cycle, so you don't have to open that trap-door at the bottom. To condense, the machine needs COLD water (spritzing on an internal screen) during drying. Make sure your cold water hose is connected to the outside (outboard) connection on the back of the machine. As a long shot: If the gray drain hose is pushed too far down into your home's drain pipe (more than 8") there could be a "back-siphon" where dirty water siphons back into the washer. It's a long shot, but it does happen.
Lastly, the controller board (mounted at top of right side) could be bad, and not sending on-off commands to the pump during drying. During drying, the drain pump should cycle on and off constantly, every few minutes. Do you hear it running? If you remove back (about 12 Torx screws), at your lower left you will see the pump. There are only 2 wires (120 VAC) and they can be connected either way. Stick a meter on the terminals and see if power is cycling on and off. If not, the controller board is bad.
You can order one from Malber (in NYC) by calling Nancy at 516-323-5299. Tell her Mike, in Wash. D.C., says hi.
Mar 06, 2015 | Malber WD1000 Front Load Washer/Dryer
How to replace water pump on a evenrude/Suzuki 1999 50 hp 4 stroke
need to drop the lower unit(prop and all) to acess the chamber for the impeller.. give the impeller a small coating of grease so its not dry when starting up..
Oct 14, 2014 | Boating
Oil dirps out of water pump hole setting with motor not running
Depending on the size and make of outboard you will notice oil out of the prop exhaust. This would be different on a 4 cycle engine, because the oil on a 2 cycle leaves the engine in the exhaust.
Depending how the pump pickup is made, the bottom of the motor draws water from close to the exhaust.
You can check the lube in the lower unit to see if it is milky or low on lube as it may be cracked internally. Then you can check whether your plugs are oil-fouled.
If you still need help add the type of motor(2 or 4 cycle) and brand and HP.
Mar 18, 2010 | Boating
Water not pumping through wash arms
It would be helpful to know the model no. of your dishwasher.
I few things to check
1. is the water getting into the unit - tap on etc.
2. are the spray arms free of debris - remove and clean the holes
3. do you hear the arms rotate when unit is turned on.
4. how do you know the water is not pumping through the arms
Hopefully we can diagnose the problem for you.
Jan 24, 2010 | Jenn-Air Dishwashers
Whirlpool washer stops after agitation cycle
Maybe check the belt is it cracked worn or fibers showing if so replace it
Jul 26, 2009 | Whirlpool Washing Machines
Removing lower unit wont seperate
need to unclip shift rod at engine
Jun 13, 2009 | Sevylor Fish Ranger 280
Does not pump water during the wash cycle.
It sounds like you are on the right track.
Open the dishwasher, remove the bottom rack, then remove the thumb nut in the middle of the unit that secures the lower wash arm and housing. Look for debris and clear any you find. Try again. If no joy, you will have to repeat the first step and also remove the wash pump upper housing that is secured with torx head screws. Same thing after you remove it - look for debris in the impeller area and remove it.
If you have to remove the wash impeller, you will need a 1" offset box wrench and as I recall a 1/4" socket. The 1" offset box wrench is needed to keep the impeller from turning while you remove the center nut. You will also need to remove the upper discharge line retainer clip to get that out of your way. Inspect the impeller for any debris and especially cracks or missing blades. If the impeller is damaged it will need to be replaced.
While you have this thing apart, check the lower wash arm and upper wash arm discharge pipe assembling for any obstructions.
I am assuming the motor runs ok and the timing cycles seem normal.
May 03, 2009 | Dishwashers
Having trouble getting water pump out of 94 lantra 1.8 lt
1. Remove the alternator & power steering pump drive belts.
2. Remove four (4) 10mm bolts holding the water pump pullys & remove the pullys.
3. Drain the Radiator (save coolant if intend to reuse).
4. Loosen & remove AC compressor belt.
5. Remove crankshaft pully (22mm bolt).
6. Remove lower timing belt cover (10 mm bolts) to access water pump bolts.
7. Remove the water pump (12mm bolts)
(1) Remove the 2 bolts, then remove the alternator brace (A). (2) Remove the water pump (B) and gasket.
dbb00ee.jpg ef0cc15.jpg 8. Clean mating surface on engine & install new gasket & pump - reassemble. Refill w/50-50 coolant.
Mar 21, 2009 | 2004 Hyundai Elantra
Boating Logo
438 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
