Question about Konica Minolta magicolor 5430 DL Laser Printer
Printing envelopes I have a magicolor 5430 dl and I'm trying to print envelopes for the first time. I changed the dials to "envelope" in the side of printer, opened "properties" in the print window and changed paper to "envelope" and changed paper type to "envelope" and I get an error message on printer that says "Put media: tray 1 envelope" HELP!
    Champion:
  • 214 Answers
Did you put these envelopes right way (portrait/landscape) also you have to change in printer menu paper source paper type from plain paper to envelope.
Posted on Jun 19, 2008
SOURCE:
How do I print an envelope on my Canon MP510?
Envelopes must be fed from the Auto Sheet Feeder. Use either European DL or US Comm. Env. #10-sized envelope.
Important :
  • You need to print from the computer to print on envelopes.
  • Do not use envelopes with embossed or treated surfaces, a double flap, pressure seals, or sticker flaps.
  • Select either DL Env. or Comm. Env. #10 in the printer driver according to the envelope size you are using. If you do not, the address will be printed in the wrong direction.
1 : Retract the Paper Support.
2 : Load the envelope against the Cover Guide (the right side of the Paper Support).
Load with the front face UP and the rear flaps DOWN on the left.
A maximum of 10 envelopes can be loaded at once.
*1 Printing orientation
*2 Make sure the flaps are folded.
Important : Make sure that the Cover Guide is set upright.
3 : Pinch the Paper Guide and slide it against the left side of the envelope.
4 : Press the Paper Feed Switch so that the Auto Sheet Feeder lamp lights up.
5 : Set the Paper Thickness Lever to the right.
In the printer driver, select 'Envelope' in Media Type, and then select 'DL Env'. or 'Comm. Env. #10' in Page Size.
Jun 21, 2011 | Canon PIXMA MP510 All-In-One InkJet...
I've had the printer for about 18 months with no problems. I need to print envelopes for the first time, and can't figure out how to do it. Any help out there?
Load the envelope against the right side of the back paper tray.
Load with the address side facing UP and the rear flaps DOWN on the left.
Set the Paper Thickness Lever to the right, return to the left after finishing printing.
The Paper Thickness Lever is located inside where the paper come out of printing.
Specify the settingin the printer driver.
Select Envelope in Media Type
Select DL Env. or #10 Env.
Select Landscape in Orientation.
Jan 18, 2011 | Canon PIXMA MP470 All-in-One Printer
How do I print 8-1/2" x 14" paper. I only have one 8-1/2" x 11" tray? Konica Minolta Magicolor 5430DL
On the 5430 DL there is an aux legal tray that can be purchased for legal printing. On a later successor the 5550 a manual feed option was included, however for the 5430 there is no option for printing legal without the extra tray being installed. On a side note, I have this tray and when not printing legal it lets me load an extra 500 sheets of letter paper which is very convenient when I need to print a bunch of sheets overnight.
Mar 15, 2010 | Konica Minolta magicolor 5430 DL Laser...
Magicolor 5430 dl doesn't print magenta
Please check your magenta cartridge if they are properly installed.
Make sure that your magenta cartridge are not empty.
Make sure that you are using the original konika minolta cartridge and not just a refill one or replacement one.
Aug 20, 2009 | Konica Minolta magicolor 5440 DL Laser...
Can't print DL envelopes on a Pixma iP4600
Hi ...
If you like to print DL envolopes, check the below 3 points and I am sure you will be able to print from your printer.
Prepare the printer:
  1. Open the Rear Tray and pull out the Paper Support. Put your finger in the rounded indent of the Paper Support and pull it out until it stops. (See <1> in Figure 1 below.)
  2. Open the Paper Output Tray. Put your finger in the rounded indent beside the Paper Output Tray and open it gently. (See <2> in Figure 1 below.)
  3. Open the Output Tray Extension. Open up and set the Output Tray Extension completely by pressing down the hollow on its front side. (See <3> in Figure 1 below.)
  4. Adjust the position of the Paper Thickness Lever. Set it to the right when printing on envelopes or T-shirt transfers, and left when printing on any other type of paper. (See <4> in Figure 1 below.)
    * Figure 1
  5. Load the envelope.
    1. Load the envelope against the right side of the Rear Tray. (See <1> in Figure 3 below.)
    2. Load the envelope with the address side facing UP and the rear flaps DOWN on the left. (See Figure 2 below or, <b> in Figure 3 below.)
      * Figure 2
    3. Pinch the Paper Guide and slide it against the left side of the envelope. (See <2> in Figure 3 below.)
      * Figure 3
      Note: Reset the Paper Thickness Lever to the left when you finish printing. (See <3> in Figure 3 below.)
Preparing Envelopes to Load:
  1. Press down firmly on the edges of the envelopes to make the folds crisp. Also, press firmly on the area that corresponds to the edges of the back flap.
  2. Remove any curling by holding the edges diagonally and bending them gently.
  3. If the edges of the envelope are inflated or are curling, place the envelope on a flat surface. With a pen, press down while moving it from the center toward the edges of the envelope.
  4. Ensure that no curl or puff exceeds 1/8 in. (3 mm).
Paper Type
Precaution
Envelope*
DL / #10
Set paper with the flap closed.
Unsuitable Envelopes:
  • Envelopes with an embossed or treated surface
  • Envelopes with a double flap or pressure seals
Printer Driver Settings:
  1. Select Envelope in Media Type.
  2. Select the size for envelopes.
    * In Windows, select DL Env. or Comm. Env. #10 in Page Size.
    * In Macintosh, select DL Envelope or #10 Envelope in Paper Size.
  3. Select Landscape in Orientation.
Note:
  • Be sure to set the printer driver setting properly. If you do not, the address will be printed in the wrong direction.
  • It may be required to change the paper size option to 'Envelope' in File Page Setup menu.
Don't forget to vote if this helps ... Cheers :)
Jul 27, 2009 | Canon PIXMA MX310 All-In-One Printer
Printing DL envelope on Canon Pixma iP4600
its not the problem of your way of operation, its the limitation of of the printer.
Jul 10, 2009 | Canon PIXMA MX310 All-In-One Printer
Cannot print envelope on MX310
Note:
    Note:
1Select Envelope in Media Type.
  1. Select the size for envelopes.
  2. * In Macintosh, select DL Envelope or #10 Envelope in Paper Size.
Apr 02, 2009 | Canon PIXMA MX310 All-In-One Printer
When I print enveloppes with my Konica 2430DL, I get shadows, but not on other print jobs
When you look at an envelope, it has spots where there are 2 to 4 thickness of paper in spots.( folds of the envelope) If this is where your shadows are, and your printer does not have any settings for envelopes, your printer may not be able to print those types of envelpes. You might try a lighter and thiner envelope.
Mar 03, 2009 | Konica Minolta magicolor 2430 DL Laser...
Printing envelopes
Open a MS Word Document, select 'Tools' then 'Letters and mailings' then 'Envelopes and labels...'
Envelopes and Lables dialogue box opens - ensure you are on the 'envelopes' tab
Then type your recipient address in the larger white box
for standard letter envelope (DL 220m x 110mm) - Insert envelope into Brother HL-2030 manual feed, with print side up, gummed flaps down and to the left side (bring gray plastic guides in close to secure).
Then select print.
I have found that during the feed, one end of the envelope gets a little bit crumpled but overall it's still a little bit more professional looking than my handwriting.
Jan 12, 2009 | Brother HL-2030 Laser Printer
Printing Envelopes
Be sure you have set the PRNIT PREFFERENCES on your program that you are using to print the envelope to accept a #10 envelope and not 8.5x11 paper, you ALSO must set the PRINTER PREFERNECE to MANUAL FEED and not automatic so it won't look to the paper tray.
//CowboysFanZ
Mar 28, 2008 | Dell 3100cn Laser Printer
Konica Minolta magicolor 5430 DL Laser Printer Logo
477 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
