Question about Dell Axim X30 Pocket PC
The device is stuck on the blue Dell screen.
The back up battery failed and the main battery was loose. Now when I turn the device on all I get is the blue screen with Dell in the center. How do I get it to re-boot?
  • 590 Answers
1. Remove the memory card and all the accessories connected to your device, If any.
2. Try powering up your device and there should be some hole in your device using which you can reset the device.
3. Find out the reset hole and press it using a needle like materials and by this way your problem may get solved.
Thanks
Posted on Apr 27, 2010
My acer aspire z3100 all in one has a black screen when powering it on, already changed the mother board and battery,when turning on you can hear the fans and the blue led light for power on
I understand why, for space-saving reasons, some people choose to purchase an all-in-one computing device. The inevitable downside is that when the display fails long before the device itself is obsolete, then you are stuck with no options. Chances are that the back light circuit or the LCD panel itself has failed here. Repair of a unit of this age is not cost effective. Replacement is the better option.
Dec 15, 2015 | Acer Aspire Z3100 (2771498) 21.5 in. PC...
Why doesnt my compter get past the booting screen?
Early in the post stage, bad ram or failing hard drive.
Do all the following with the PC unplugged:
Remove cables from Hard drive - pay attention to where the go back, turn on pc and see if it goes further (if it does, you probably have a failing hdd and should seek professional help immediately. Don't keep trying it, else you lose everything for sure.
If that doesn't work, plug the hdd back in and again with power UNPLUGGED, remove one of the ram sticks. Turn pc on.
If works, you have a bad stick or slot, if still nothing, put ram back in and take out next stick. Repeat until you find the problem.
Aug 09, 2014 | Dell Studio Xps 7100 PC Desktop
Where is the LCD cutoff switch located ?
Both the D620 and the D630 use the same keyboard.
The picture below shows the keyboard.
Hold down the blue Fn key at lower left, and then press F8 while holding down Fn. Press F8 multiple times until the screen returns.
If that fails, the ribbon cable connected at the main board from the screen may be loose and removing it, then reconnecting it, is the most likely solution.
ixquick proxy com
May 17, 2014 | Dell Latitude D630 Notebook
Config-list fail, flat main battery and i suspect the bios battery is flat to computer will not boot past dell media screen and a blue fail screen is left. is it time to replace parts eg. hard drive.
This may be a sign of a virus or malware. Have you tried the diagnostics by holding down the Fn and Power button at start up?
Let me know if the diagnostic shows any problems. We can go from there. Thanks.
Jan 31, 2011 | Dell Computers & Internet
My Dell vostro A860 Laptop shuts off after 5 seconds that I have turned it on, the blue light showing that is has turned. The screen is black, I don't even get the boot up screen.
Its stuck on finding a bootable device. your PC has a virus or HDD is gone bad (unlikely). Try putting in the OS disk n boot for it.
Nov 02, 2010 | Dell Vostro A860 Notebook
Computer is stuck on blue screen. will not reboot. will not turn off with power button.
Hello
Thank you for using
FixYa for your problem
Blue screen is a device isure, remove power and battery, put back the power and restart and press F8 and goto "Safe Mode with internet"
If the unit boots up fine we then know it is a device isure.
Try using the system restore feature and go back a few days and see if this helps
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Nov 18, 2009 | Dell Inspiron E1505 Notebook
Dell Inspiron 1501
Are you using the original charger or another. The Dell power system will give this message when you use a 70W charger on a system that needs a 90W charger - check the sticker on the back. Also, if the plug to the main board gets just a little loose you will get this message. Be careful you are not putting too much strain at the power plug or you will need a repair soon!
Jon
Dec 31, 2008 | Dell Vostro 1000 Notebook
Blue screen with dell logo??
This is usually called the "Blue Screen of Death" and the system tries to dump memory
See if you can Read any of the text which may detail the error
Try starting it in safe mode by tapping F8 every few seconds during startup
If it starts post back and i'll tell you how to use system restore
If it still fails then call in an Engineer
Oct 14, 2008 | Dell Axim X50v Pocket PC
Dell Axim X30 Pocket PC Logo
129 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
