Question about Sylvania Dual Deck DVD/VCR
Hook up How do i hook up my old dvd player to my home theater system and to my new HDTV. Does my cable wire go into the dvd player and then out to my converter box that then hooks to the tv? when i attach it in this way, my tv works but i cannot play a dvd.
    Genius:
  • 1,112 Answers
Hi:
This type of hook up is only for television viewing, to view the DVD you might consider purchasing some componet cables, they are color coded so hooking up is a snap, on the back of the DVD player you will see three RCA type connections Red/Green/Blue. componet cables are also these colors, connect one end of the cables to it coorsponding color on the back of your DVD and the other in the same color connectors labeled componet 1 input on the back of your television. You will also need a red and white RCA connector also for the audio as this is sound, a total of 5 connections will complete the hook up. Or you can go the simple route and use RCA type cables that come as yellow/red/white but for the best picture use componet cables this will allow you to watch your movies in HD.
Posted on Apr 27, 2010
Hook up new blueray thru old home theater system
Yes you can. If you have more than 1 HDMI sources and your old system only has 1 HDMI in, you may want to invest in an HDMI switch. They are inexpensive (under $20 on Amazon) and let you choose 4 HDMI sources to feed your system. The audio is embedded in HDMI and you may have to select the choices (surround versus stereo) when you play the disc.
Dec 25, 2012 | Sony DAV-DZ175 DVD Home Theater System
I want to hook up my bose 321gsx system to my hdtv and a blue ray dvd player and be able to have suround sound out of the one im listening to, Do i have to hook up my old vcr also ?
No, flushing anything hi-def through a VCR is counter-prooductive and could lose the definition you paid for.
but some assumptions are necessary because you don't provide the details regarding the audio capabilities of your HDTV and BluRay player.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/s/Bose-321-GSX-Home-Theater-Systems-review-manual/id/524dj983/t/1-2/
Run the Bose and the Bluray
Feb 26, 2011 | Bose 3 2 1 GSX System
Ihave a bose 321gsx, I want to hook up my hdtv . ,blue ray dvd and vcr. Brain is frozen right now. Could use some help.
How to Connect an HDTV to a DVD Player
Hooking up a DVD player to an HDTV, or high-definition TV, is just as simple as hooking one up to a standard-definition TV. While a regular DVD player may be hooked up to an HDTV, it does not necessarily mean it will have high-definition quality picture. Unless a Blu-Ray player is connected to the HDTV, only a standard-definition picture will be shown.
Things You'll Need:
* Component cables
Instructions
Turn off and unplug the HDTV set and the DVD player before attempting to connect component cables to them.
Match the red, green and blue colored cables to each of the color-coded counterparts on the back of the DVD player. Be sure the cables are being plugged into the TV-out section of the DVD player.
Plug the other end of the color coded cables into the HDTV set. There should only be a red, green and blue cable being plugged into the TV. It does not matter what input these cables are plugged in, but keep track of which particular one it is. Most HDTV sets will have more than one A/V input, which is why it's important to take note of where the component cables are located.
Power on the DVD player and the HDTV set. If not already plugged in, ensure both of these are properly plugged into an outlet.
Press the "Source" button using the HDTV remote and locate the input channel that has the component cables plugged into it. The HDTV set should now show the DVD player logo or an introduction to the DVD.
Do not purchase HDTV component cables to hook up a regular DVD player to an HDTV set. Unless using a Blu-Ray player, only standard component cables are required. HDTV sets consume a lot of energy and should be plugged directly into an electrical outlet rather than a power strip.
Turn off all electronics before connecting and disconnecting wires to reduce the chances of getting an electrical shock.
Ensure that you have the proper cables to hook up your new HDTV. Take inventory to see if you have an ANT-IN, DVI-D/HDCP IN, Video In or Component Video In cables. The placement of these plugs will be indicated in your user book.
Begin by connecting the coaxial cable to the back of your cable box. Run a video cable to the TV; an S-Video cable may be used as well if you do not have any other video cables.
Locate a digital audio cable, or analog audio cable. Connect the audio cable to the TV from the cable box.
Now connect all other components including DVDs, VCRs or LaserDISC players. Try using all digital audio and digital video connections for the most complete HDTV experience.
Use a splitter to connect multiple components such as cable box to DVD or TV to VCR to avoid running out of chords. Calibrate your HDTV before enjoying fully, adjust the brightness, contrast and color settings.
Tips & Warnings
You can utilize a program to help with proper calibration of your HDTV system; these instructional videos can be purchased from many electronic stores.
You can opt for the store from which you purchased your HDTV to hook up the system for you. They will often calibrate the system for you as well.
Hope it helped.
Have a nice day...
How can I hook my alternate DvD player to SA-HT700 subwoofer without a cable ?
Without a cable? You probably can't unless wireless DVD is out.
http://www.retrevo.com/support/Panasonic-SA-HT700-Home-Theater-Systems-manual/id/312bh731/t/2/
If you want to use a wired DVD player, you would have to settle for just audio (analog stereo or optical digital) from it since this unit doesn't accept any video IN.
Jan 12, 2011 | Panasonic Audio Players & Recorders
Rf modulator hook to Dvd and HDtv but no sound coming through the dvd surround home theater player. What should I do to make it work through the DVD player?
Check to see if your audio cable RCA (red and White) wires are connected to the correct inputs. A good rule of thumb is: If the cables says out it has to go in. If it says in it has to go out. Also check your settings on your HDTV in the menu audio section or channel selection.
Dec 06, 2010 | Dynex RF Modulator AV Signal Converter
When I hook the HDMI cable to the tv and put the dvd player on the setting for 1080p I get no picture but when I put it on 480p it works fine. What do I need to do to make the dvd player to play the 1080p?
you can only upscale through a good amp.set the dvd player to auto.how old is the tv?are you playing a new release?is the HDMI cable compatible with 1080 1.3b?
Jul 11, 2010 | JVC TH-G30 Theater System
I have a protron dvd pds 2315, hooked up to a Insignia LCD HDTV, the sceen is completely pink when I turn on the dvd player. I am using the 3 color coded video cable and a regular white/red cable for...
Turn on your DVD player, go to your set up button on the DVD remote, go to TV and select p-scan. It fixed my problem. My screen was all blue before I did that. Hope it works
May 07, 2010 | Protron PDS-2315 Theater System
I purchased aRCA 250W DVD Home Theater System with
do you have a set of cables coming from the tv AV out to your home theater system? if not you need to you can use coax out or anolog out either one
Dec 03, 2009 | Televison & Video
Do not know how to get regular T.V. hooked up to this system
try using the red White cables from back of tv to back of dvd player/receiver. Do the same with DTV/dvr or cable box. not sure if cable box has red and white cable outlets, however the DTV-DVR does, The quick patch is from TV to back of dvd (input audio)side,....that should work
Sep 26, 2009 | Coby DVD-937 5.1 Channel DVD...
Hooking up audio video to cable box with home theatre
From Cable Box to Input on DVD Player, from DVD Player Out, to TV in, from TV Audio Out to Home Theater Audio In.
That should work.
Will have to have the VCR on to watch cable. Plus make sure that you use A/V cables as much as possible. Coax works ok, but not as good as R/W/Y.
Feb 13, 2009 | Panasonic Home Theater System System
Sylvania Dual Deck DVD/VCR Logo
192 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
