Question about Poulan Pro " Pro" Self Propelled Mower
MODEL CH65Y21RDP WILL RAN FINE BUT IF I CUT IT OFF WILL NOT START TILL IT COOLS DOWN,EXPLAIN WHY PLEASE
2 Suggested Answers
  • 2239 Answers
SOURCE: poulan 18" wildthing chainsaw (model
This could be a couple of things, if the fuel tank brather is blocke the tank will vacume, to test this try slackening off the fuel cap when the saw starts to die, if it picks up again it is a fuel tank braether issue, the other possibility is a bad ignition unit breaking down, the only test for this is to replace the unit and try again.
Posted on Sep 19, 2011
What causes engine to cut out?
Maybe your coil pack. It can overheat and short out. Then it cools down and will work for a while till hot again.Could also be spark plugs and wires.
Feb 12, 2016 | 1999 Honda CR-V
My car starts ok until I stop it it won't start again till it cools down
Maybe your spark plug is drained already. Try to replace it with a new one.
Aug 23, 2015 | Cars & Trucks
Engine over heats while driving but cools down at idle
while driving coolant will cool down because air is flowing across radiator at idle no air movement ---check fan operation as well----- but until you fix leak you will still over heat due to lack of coolant and pressure
Aug 02, 2015 | Cars & Trucks
I have 94 deville, The car ran fine then all of a sudden it cut off. Tried starting it and it turned but wouldn't catch. I let it sit for a while and it fired right up! Ran for a few minutes then shut off....
Most likely the problem is with the electronic ignition Module. THE CAR CAN START AND RUN FINE TILL THE MODULE GETS WARM oops, then it breaks down inside causing the car to stall once it cools down the car will start again. the module is sealed and is supposed to be insulated , usually with some sort of grease or something applied to it when installed but it breaks down allowing it to over heat. It is probably inside the distributor if that year and model has one if not it can be located someplace else you just have to find it and replace it. It also could just be a wire or connection breaking down, or a problem with the computer.That should give you some ideas. Good luck.
Dec 17, 2014 | Cars & Trucks
Car stops after afew miles and wont start till it cools down
Try checking your coolant. see if that needs to be replaced.
May 20, 2009 | 2003 Jaguar X-Type
Poulan Pro " Pro" Self Propelled Mower Logo
145 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
