Question about Proform 585 CS Treadmill
My pro form 585-ex has power but the belt won't run
When i plug in the treadmill all of the running lights come on but when i try to slid the power button to start the belt moving nothing happens.any suggestions?
SOURCE: pro form service manual?
Please type in your model number on this page to get the free downloadable manual:
http://www.iconservice.com/proform/manuals.html
Hope this is helpful
Posted on Sep 12, 2009
  • 24 Answers
SOURCE: once you step on the moving treadmill the belt
try standing on it then starting it, some units have a saftey curcuit that cuts th motor if there is a spike in service Voltage level this how the machine detects if you have fallen and shuts off
Posted on Jul 27, 2009
SOURCE: Pro Form treadmill display lights up but the
Check out The treadmill Doc. Fantastic site and great people to do business with. A lot of helpful trouble shooting information for free! I'm betting it is the motor control board. Site will lead you through step by step instructions to check and fix it yourself. I saved a ton of money and with a little know how and good information you can too.
Posted on Dec 16, 2009
maxtreadmill
  • 832 Answers
SOURCE: describe how to unfold a treadmill, pro form ex
Hold the upper end of the treadmill with your right hand on the back end of the unit. Using your left hand, pull the lock knob to the left and hold it. Pivot the treadmill down until the frame is past the pin on the lock knob. Note: You may need to push the handrail to the side slightly. 2. Move in front of the back end and hold the treadmill firmly with both hands, and lower the treadmill to the floor. CAUTION: To decrease the possibility of injury, bend your legs and keep your back straight
Posted on May 31, 2010
SOURCE: Pro-Form XP 550 Troubleshooting
My Proform 550 doess not work the treadmill is not getting any power. Wht might the problem be.
Posted on Sep 21, 2010
No lights on the top panel of Treadmill Pro-Form 345s
1) replace the old batteries by new ones. clean the contacts batteries very well
2) tight the ribbon cable for keypads and clean it
3) tight the upper connector vs lower connector
4) adjust the REED switch, see the diagram clean it, test for open or faulty and tight the connector.
Jan 22, 2013 | Proform Exercise & Fitness
My pro form treadmill was stuck in the incline position. Now it is down but the belt won't run
If the console takes batteries, replace them. If this does not work or your console does not require batteries, check the reed switch or optic sensor. Reed Switch: Unplug the treadmill and remove the motor hood cover. The reed switch is mounted on the frame next to the front roller pulley. There is a magnet glued into the front roller pulley. When adjusting the reed switch, make sure it is pointing directly at the magnet. Move the tip of the reed switch within 1/8" of the magnet. Also, check to see that the wire is not damaged, and is connected to the console.
Optic Sensor: Unplug the treadmill and remove the motor hood cover. The optic disk and sensor are located either at the end of the motor or the right hand side of the front roller. The optic disk spins between two sensors on the optic switch. The disk must spin freely without touching either sensor. The sensors can be moved by loosening the adjustment bolt holding the switch to its bracket. The switch can then be slid. Center the disk. 11_13_2011_7_47_47_pm.gif11_13_2011_7_48_35_pm.gif
Nov 13, 2011 | Exercise & Fitness
Pro form 400gi belt adjustment
should be a allen wrench adj on the rear of the tradmill
Nov 11, 2011 | Exercise & Fitness
My belt is over to one side to much is there and easy way to get it back in the middle
If the walking belt has shifted to the left, first remove the key and UNPLUG THE POWER CORD. Using the allen wrench, turn the left rear roller adjustment bolt clockwise, and the right bolt counterclockwise, 1/4 of a turn each. Be careful not to overtighten the walking belt. Plug in the power cord, insert the key and run the treadmill for a few minutes. Repeat until the walking belt is centered. If the walking belt has shifted to the right, first remove the key and UNPLUG THE POWER CORD. Using the allen wrench, turn the left rear roller adjustment bolt counterclockwise, and the right bolt clockwise, 1/4 of a turn each. Be careful not to overtighten the walking belt. Plug in the power cord, insert the key and run the treadmill for a few minutes. Repeat until the walking belt is centered.
Jul 16, 2010 | Proform Quick Burn Pro Treadmill with 12...
Got a 390pi proform and when I step on the
Go to your local hard ware store and purchase silicone spray. Apply Lubricant by lifting one side of the running belt spray contents length wise starting at motor shroud to the back end repeat this process the other side. If this unit bogs down again then you will have replace the running belt and possibly the deck.
Jun 01, 2010 | Proform Sport 1000 Folding Treadmill...
Pro form service manual?
Sep 11, 2009 | Proform Sport 1000 Folding Treadmill...
Looking for instructions to remove belt from J8 pro-form treadmil
I have a proform j8li treadmill. What size allen wrench to I need to adjust the belts?
Danielg@jcnj.org
Thanks
May 03, 2009 | Exercise & Fitness
Proform 585 CS Treadmill Logo
247 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
