Question about Northstar Pressure Washer Turbo Nozzle
Can't unscrew nozzle from hose what do I do to loosen?
I used a vise and pipe wrench to loosen. Have to be careful with the vise that you don't over tighten it and damage the hose fitting. When replacing the nozzle, lube the threads with non-water soluble grease.
Posted on Aug 29, 2010
Spray not working, doesn't stop water from faucet.
It sounds like a kinked hose under the sink or a clogged nozzle. Unscrew the nozzle from the sprayer and check for calcium buildup. New parts can be purchased cheaply from the local hardware store, take the old parts in and a sales rep can help you with the correct parts. Some sprayers have replacement nozzles...unscrew the old and screw in the new.
Sep 20, 2015 | Plumbing
The water is not coming out from water hose
Check that the nozzle jet is not clogged. To do this removed (unscrew) the nozzle at the end of your wand. Squeeze the handle. If water sprays out then your jet nozzle is clogged/corroded and either needs to be cleaned or replaced. This happens sometimes if you leave the wand sitting for several months with water still in the line.
Aug 09, 2014 | Daimer XTREME POWER XTREME POWER XPH-5900I...
How to remove a clog
Hey there! Most of our vacuums you are able to remove the tool hose without the use of a screwdriver or other tools. Follow these brief steps to check your vacuum for clogs.
Remove the hose from both ends. Use a broom stick to gently loosen and clear any clogs from hose.
Remove the hood or nozzle to access the brushes, remove the brushes. Use a wooden spoon or something similar to loosen and remove any clogs from the lower hose
Hope this helps you!
Jun 01, 2014 | Hoover Vacuums
Replace radiator hose
unscrew the clamps on each end or if they are snap clamps use a vise grip to loosen clamp and slide the hose off and replace. tighten clamps or snap clams in place. refill the rad and your done
Mar 15, 2013 | 1997 Ford Taurus
How do I remove grohe water restrictor in kitchen pull out
Unscrew the nozzle from the hose. On the end of the nozzle that screws to the how, you will see the water "restrictor, white ring with 4 little prongs and a black "O" ring in the background. Use a long nose plier and grab one of the prongs and pull out. Screw nozzle back and the water flow will be greatly improved.
Sep 11, 2012 | Grohe Ladylux Cafe Faucet with PullOut...
The motor on my carpet tool (beater brush) stopped running yesterday. The main vacuum still works, but the switch for the carpet tool just clicks and doesn't turn it on.
Knowing the model would help.
Possible problems:
Broken or disconnected wire in hose, connections, power nozzle.
Hose needs replaced. Check all connections for discoloration and cracked supports. Have power nozzle checked at a vacuum shop. Depending on the model, take it to an authorized Aerus Electrolux store for this.
Bad power nozzle motor Needs replaced.
Bad switch. Take the whole machine in for thorough check and repair..
Jan 25, 2011 | Electrolux Vacuums
How to replace the flexible hose between the upright and floor modules?
Turn the vacuum on it's side. Pull the power nozzle end out. Unscrew, in a clockwise direction, the hose from the body/tank.
Reverse to install new hose. Screw the hose into the tank, turning counter-clockwise. Place other end into power nozzle. Ensure it's set properly.
Dec 31, 2010 | Electrolux Epic 3500 Vacuum
Removal and replace radiator on 1990 ford taurus V6 3.8L w/AC
  • Remove the pressure cap. Place it aside for the new radiator.
  • Drain the coolant into a drain pan. The drain valve is located at the bottom of the radiator. Twist it counterclockwise until the fluid starts to drain. Close the valve when the coolant stops draining.
  • Locate the transmission lines at the bottom of the radiator. Ensure you mark both of the lines so you will know which one goes where. Unscrew these with a line wrench. Plug the line with a towel to prevent the transmission fluid from leaking out.
  • Unscrew the radiator hoses at the top and bottom of the radiator. The hoses are held on by hose clamps that can be loosened with a flat head screwdriver. Slide the hoses off the radiator with your fingers after the hose clamp is loosened.
  • Pry the overflow hose off with your fingers. The hose slides over a tube at the neck of the radiator.
  • Unscrew the mounting bolts at the base of the radiator. There will be one bolt on each side which can be unbolted with a socket wrench.
  • Unsnap any sensors connected to the radiator. They will have quick connect fittings that can be undone by separating the tabs and pulling apart.
  • Unscrew the fan shroud with a socket wrench. The fan shroud will slide off the top of the radiator. You can also remove the cooling fan as it is held onto the fan clutch by four small bolts. You will need a socket wrench to remove.
  • Lift the radiator out from the hood. You may need assistance as the radiator can be heavy and awkward to lift.
  • Oct 08, 2010 | 1990 Ford Taurus
    My 01 Durango just started to overheat? Thermostat? And where is it at?
    If you have the 5.9 engine, the T stat is under the nozzle where the upper radiator hose connects to the engine.
    If you have the 4.7 motor, the T stat is behind the composite nozzle on the engine end of the lower hose.
    Be sure to soak the bolts on the 4.7 motor nozzle and don't over torque them when loosening or tightening as they will easily break turning a minor repair into a major frustration.
    Also, the 4.7 motor has a special "burping" process you must go through after servicing the cooling system to purge air from it. Otherwise, it will surely overheat.
    I recommend the OEM T stat if you have the 4.7 unit. It runs $26 or so but is worth it.
    Don
    Apr 13, 2010 | 2001 Dodge Durango
    How can I remove the (hood mounted )windscreen washer nozzle?
    1. Open the hood of the vehicle for clipped nozzles or nozzles with retaining screws that are attached to the hood. Locate the nozzles and hoses attached to the hood. Some vehicles may require removing an insulated panel that is retained by plastic clips. Pry the clips out and remove the panel (if applicable).
    2. Note the way the nozzle is attached to the underside of the hood. Clip-on nozzles will either be attached by a single clip on one side of the nozzle and a retaining anchor on the other end. Other clip-on nozzles may have two retaining clips that need to be squeezed together (with needle-nose pliers, if necessary). Press the clip or clips inward towards the nozzle and it will pop out of the hole in the hood. If the nozzle is retained by screws, simply unscrew them with the screwdriver. If there are hose clips holding the hose to the hood, unfasten the clips (by hand) to allow more movement in the hose-to-clip assembly.
    Nov 13, 2009 | 2002 Toyota Highlander
    Northstar Pressure Washer Turbo Nozzle Logo
    244 people viewed this question
    Top Northstar Garden Experts
    John Trevino
    JOHN LAPIER
    Are you a Northstar Garden Expert? Answer questions, earn points and help others
