Question about Galaxie Revell '65 Ford 500
Hi my galaxy wont start red light flashing on door terns owfer wont start kan u hellp me
    Problem Solver:
  • 14 Answers
Its your passive anti theft system thats giving you problems, check relay 30 in the middle of your fusebox. www.fgoc.co.uk
Posted on May 10, 2010
Avital 3100 keyless entry remote sets off alarm when trying to unlock or lock doors with remote. Doors stay unlocked but alarm keeps sounding off and car wont start.
hi'
i think the wire that connects to the door trigger for the interior light
a negative or a positive one has been mixed up
if its neg change it to the positive one
if its positive change it for the negative one
25666027-extj4arg1t42xbh3l3byl5v2-3-0.jpg the purple or green wire
cheers
Apr 26, 2015 | 3100L 1way Security System
My zanussi zwg 6141p washing machine is calling water at start of cycle but is not going into drawer to swill out detergent , is also stopping half way with the green light on the start button flashin
Some appliances malfunction can be displayed in hexadecimal or in binary code.
So your device is defective and shows you what's wrong. You have to count how many times flashes red light and how many times flashes green light. Red light shows the first error number and green light the second error number.
For example: you forgot to close the door and you started washing machine. After some time (timeout) will generate an alarm. Four times will flash red light and once the green light which means error code " E41 " or "Open door"
" E20 " means "No drain water"
" E10 " means "No fill up water"
Dado
Sep 08, 2014 | Zanussi Washing Machines
Cycle won't start/start light flashing red
Probably a bad wax motor in the door switch or a bad control board.
Yeah you should call someoneif you're not a learned handyman.
Feb 06, 2014 | AEG Washing Machines
2005 rendezvous wont start
TRANSLATION TO ENGLISH IS:
Battery is in good shape, it has gas, fuses check good in center console fuse center and in front of hood, wen i tern the key i can hair relays clicking but ignition wont tern or start ,check starter and its good. OK then do you have a "security" light on in the dash cluster?
Jun 14, 2012 | 2005 Buick Rendezvous
H42PZ70B4 red light flashes
Unfortunatly, a 7 blink error can mean all kinds of things. If you are handy with a DVM then you should be able to diagnose the problem. Odds are, you either have a bad SC board, a bad SU or SD board, or in worse case scenario . . . a bad panel.
Unplug the unit and take the back off the unit.
Start with the power supply and disconnect the top two cables. They go to boards on each side of the power board.
Take your DVM and measure resistance on pin 1 of both connectors to chassi ground. If either are shorted, then your power supply is damaged. If checks ok, then move to next step.
Measure resistance on the same cable, except this time on the SC board side. Make sure cable is still disconneted. If there is a short, then your SC board needs replaced. If not, move on to next step.
Disconnect the SC board from the set. The two little boards that are left on the side need resistance checks. If bad - replace. If ok . . .well your panel is bad. I hope this helps.
Apr 10, 2012 | Televison & Video
When i turn the ps3 on the red light terns green ,then blue ,then white ,then back to a flashing red
ps3s do not have a white light but the red flashing one at the end means you have a critical hardware failure something has died on the circuit board usually the cpu or gpu cannot be fixed easily if you dont know much bout electrical stuff but it can be done, but first id check if the console is under warranty if so return it for a brand new one
Oct 06, 2009 | Sony Playstation 3 (PS3) Console
One red light (x-box 360) error code 74
my xbox 360 is not working right when i tern it on my flashing red light come's on i just wont ta know if it's broke'n
Oct 19, 2008 | Microsoft Xbox 360 Console
Whirlpool door lock
hi
We have a whirlpool AWO?D4705 washing machine. The red light is flashing to say clean pump.wee cannot find our manual , can you help please?
Jan 20, 2008 | Candy CNW136 Front Load Washer/Dryer
Galaxie Revell '65 Ford 500 Logo
354 people viewed this question
Top Galaxie Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Galaxie Toy Expert? Answer questions, earn points and help others
