Question about Reliance & 50gal Electric Water Heater
No hot water from brand new heater
I hooked up a 606 55gal. hot water heater and its not heating the water.ihave power at the elements..what could the problem be?
  • 94 Answers
Check your thermostat's,be sure they are turned up,tighten all (check),elect' connection's.
Posted on Apr 27, 2010
  • 30 Answers
Check the pilot light, sometimes it is hard to see if it is lit, so move your vision around the pilot light area and if you still don't see a flame, try lighting it until you do. that and or you don't have a valve or pipe hooked up properly to allow the water to flow through.
Posted on Apr 28, 2010
Ihave all valves open on hot water tank not getting hot water
If it is a Gas water heater, check the pilot and/or the igniter. If it is an electric heater, check to ensure the the power source is available. If power is available, it could be the thermostatic controller or possibly the heater elements are burned out.
Mar 13, 2015 | Water Water Heaters
BRADFORD WHITE 40 GALLON ELECTRIC WATER HEATER MODEL M240S6DS-1NCWW.. PROBLEM : I WAS ONLY GETTING A FEW GALLONS OF HOT WATER FROM HEATER. FIGURED ONLY TOP ELEMENT WAS HEATING SO BOUGHT TUNE UP KIT AT
Doesn't sound like its the dip tube, its a element problem, I would contact bw directly to see if heater is stil in warranty and they will send you new parts free.
Dec 18, 2012 | Bradford White M240s6ds-1ncww 40 Gallon...
Brand new water heater is not heating up. checked the upper heat element and got 240 volts reading, the bottom one is not reading any voltage. Please help
1) If upper element is receiving 240V, then water heater should have some hot water.
If upper element is burned out, then tank will have no hot water, but element will still test for 240V
http://waterheatertimer.org/How-to-test-water-heater-element.html
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
2) Keep in mind that upper element heats top part of tank first.
Only when top part of tank reaches thermostatic temperature will power be sent to lower thermostat and element. This is called non-simultaneous operation.
http://waterheatertimer.org/How-it-works.html
3) Non-simultaneous operation is necessary for most water heater installations because both elements are not ON at same time. Either upper element is ON or lower element is ON or both are off.
Each element is typically 4500 watts, which is 18.75 amps.
If both elements were ON at same time, it would consume 37.5 amps, so circuit breaker would have to be 40 or 50 amp with 8 or 6 gauge wire.
4) Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 26, 2011 | Rheem Water Heaters
New Rheem electric 50 gallon not heating
Check the elements, if you have access to a meter to check them. If they are getting power to elements and you have no hot water.
The elements are not working correctly. I had some elements check out ok till the thermostat's turned on and the elements didn't heat.
Sounds like the elements are bad.
Jun 01, 2010 | Water Heaters
Brand new 2.5 gallon water heater will not heat water.
sound's like it is the element.place a continuity test on element ,and see what you get
Apr 21, 2010 | Rheem 81VP2S 2.514"9-3/4"22
Sounds like a squirrel inside water heater
The noise is inherent in electric hot water heaters. It is the noise that the water makes when it is being heated by electric heating elements. Mineral buildup on the elements can make it worse, so changing the elements can help...but will not totally elimenate the noise. When I install a new tank and turn it on all I have to do is listen to it to see if it is working or not...even brand new will make a sound...it is the sound of hot water... :-)
heatman101
Mar 25, 2010 | Rheem 30 GAL ELEC SHORT Water Heater 6YR...
Not heating
un hook the incoming power lines, turn the breaker back on, and carefully measure power between the 2 hot wires, not the ground. You must have 220 to 240 volts between these 2 wires, if you dont either the breaker is bad, or the wire is broken somewhere. If you have 240 volts to the heater, with the power OFF unhook the wires from both elements and use an ohm meter to test the resistance on the elements, both should be around 30 ohms and about the same, if not one is bad. Test across the elements after re connecting them and turning the power on you must have 240 volts across the elements when they are on, if you have only 120 or 0 then the trouble is the breaker or the wire.
Mar 06, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
We just bought a new water heater and it's not heating up water.
The heating element was bad. It's hard to believe that a brand new water heater would have a burn element, but that's the problem. I replace the heating element and its started working properly.
Dec 01, 2009 | Whirlpool Water Heaters
I have an old rheemglas fury 22v40 that's leaking from the bottom. What could be the cause? Also, it DOES need replacing, Who does installs at no cost at the time of purchase?
my top element to the hot water heater is working but my bottom element isnt there both brand new elements and im just not getting power to the bottom element but i have power to the top element is it possible that the top heats first and the bottom heats later running out of options!!!
Dec 06, 2008 | Rheem 40 Gallon FVR NATGAS Low WATER...
Reliance & 50gal Electric Water Heater  Logo
122 people viewed this question
Top Reliance Water Heaters Experts
Mack Baxter
Gil Shultz
rickb63
Are you a Reliance Water Heater Expert? Answer questions, earn points and help others
