Question about Viking DFUD042 Built-in Dishwasher
Detergent Packets not dissolving
I use the Cascade dishwasher tablets (gel) which have been working just fine for the past year. In fact I have 2 dishwashers and the other has no issues. The packet is not dissolving completely and the dishes and interior of the washer all have a white film on them.
  • Viking Master
  • 43,501 Answers
How do you eliminate the film on glassware after washed in dishwasher ?
Your heater may not be working properly. It is used to heat the water during the main wash as well as dry the dishes at the end. But don't under-estimate the importance of using the right detergent. Some discount detergents (especially liguids or gels) don't work very good. Stick with Cascade or Finish powders or those All-In-One tablets by Finish corporation (the ones with the little red "power ball"), or the new tablets put out by Cascade called "Platinum". In our repair business and experience, we find those work best.
Aug 30, 2014 | Kenmore Dishwashers
My detergent is always still stuck in the dispenser. The water temp and pressure are both fine, the machine is clean as well as the spray arms, and the door opens but water just isn't dissolving it. I have...
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Apr 22, 2011 | Magic Chef 24 in. DU2500 Built-in...
We use the Cascade tablets but they don't dissolve
Either:
1. the water does not get into the dishwasher open the dishwasher 3-4 times during cycle, you should see some water at least once, if not - check water valve, water level float and water pressure.
2. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
3. motor in main pump is not working - could be caused by something stuck on the impeller or chopper or could be a problem with the motor itself or control board. Check if line voltage is coming to the motor during wash/rinse cycle.
Good luck,
Vlad
First Choice Appliance
Apr 13, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Tablet will not dissolve
Either:
1. not enough water gets into the dishwasher. open the dishwasher 3-4 times during cycle, you should see some water on the bottom at least once, if not - check water valve, water level float and water pressure.
Good luck,
Vlad
Apr 02, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
The detergent packet doesn't dissolve. The dishwasher seems to go through the cycles ... the dishes are wet. However I find the detergent packet in the bottom of the dishwasher.
Hello- Water flow, temperature, and pressure inside determine whether this little packet will dissolve.  Sump blockages or pump /motor weakness both effect amount water spraying inside. Some of these packets don't dissolve in time to enter wash water. Start by using powder or gel again. If it still leaves soap residue, other pump/motor issues exist. Let me know if this info helps- have more if needed. Thanks- ED
Mar 09, 2010 | Frigidaire Dishwashers
Dishwasher wont dissolve soap and not washing properly
The make and model number can probably be found around the door edge (usually right side) If you can find it, post the make and mode # here.
Recommend you get a box of brand name detergent powder (like Electrosol or Cascade) and begin only using that. (Neve use gel or tablets) Cheap Cheap, generic detergent does not dissolve properly, leaves residue of its own and cleans poorly.
If problems continue, check the heating element as it is very possible that it has failed and the dishwasher needs to get to the proper temperature to activate the detergent. Also check to see if the holes in the spray arms are not blocked with debris.
If the heating element is working, then the wash pump motor has begun to fail and you need to decide to replace it or replace the entire dishwasher.
Apr 08, 2009 | Dishwashers
Dishwasher detergent won't dissolve
Recommend you stop using the gel and switch to a brand name powder - like Electrosol or Cascade. Never use gel, gel packs or tablets in any dishwasher. Avoid untra-cheap, generic powders.
If problems continue, a service call, with them checking that the heating element is working is the follow up step.
Good Luck!
Apr 02, 2009 | Whirlpool DU930PWSS Stainless Steel...
Detergent caked in holder after running a cycle, using Cascade
Try this before you jettison your current dishwasher. Yes, it is possible that the wash motor is getting weak, beginning to fail but:
Buy and use a box of brand name box of detergent powder Electrosol or Cascade. Stop using the generic powder and never use a gel or tablet in a dishwasher.
You will be amazed how how much better the detergent dissolves and the DW cleans.
Good Luck!
Mar 31, 2009 | GE 24 in. Profile PDW7800 Built-in...
Tablets not dissolving
either there is not enough water (check water valve) or the pump filters are clogged (check and clean as necessary)
Jul 06, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
Re:dishwasher
Ginga, first of all it's still under warranty so I would call for service. Here's a few things to consider; first, I would switch back to the powdered detergent like Cascade. You want to make sure that the water entering the dishwasher is at least 120 to 150 degrees, anything less will cause the detergent not to dissolve. Check your loading and make sure nothing is blocking the spray arms from the soap dispenser. Make sure the spray arms do not have any cracks or splits. After the dishwasher fills, make sure that the water level is right at or just below the heating element, a short fill will cause this also. Catriver...post back.
Nov 04, 2006 | Kenmore 24 in. 16182 / 16189 Built-in...
Viking DFUD042 Built-in Dishwasher Logo
1,298 people viewed this question
Top Viking Dishwashers Experts
Mike
ray gallant
Ronald Rissel
Are you a Viking Dishwasher Expert? Answer questions, earn points and help others
