Question about Samsung WEP450 Bluetooth Headset - Retail Packaging
How do i pair my wep450 to my blackberry
What buttons do i need to hold/push to go into pairing mode?
  • 38 Answers
SOURCE: My BlueAnt won't go into pairing mode anymore!
Have you tried resetting the Blueant Z9i? You push the Volume Up, Volume Down and Blueant buttons all at the same time (with the device on). This will eliminate all paired phones, then re-pair with just your phone (hold down Blueant button for 6 seconds or so to enter pairing mode).
Posted on May 10, 2009
SOURCE: setting up pairing
thank you so much. I must be retarded cuz i couldnt get it at first. But LOL, common sense kicked in later. Thank you.
Posted on Aug 24, 2007
ziraffa
  • 827 Answers
SOURCE: Samsung Bluetooth WEP210 and Blackberry
If you have lost the pairing on your Blackberry with the headset follow these simple steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the Blackberry
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The Blackberry should search for any available Bluetooth devices and display what was found
5) Select the Samsung device and click add
6) You will be required to enter in a pass code which is standard ‘0000’. If not try '1234'.
7) If successful then the headset will start flashing BLUE every few seconds.
• The headset is now paired with the Blackberry
Hope this helps
Chris (ziraffa)
Posted on Jan 11, 2009
SOURCE: Bluetooth syncronization from my BlackBerry to my laptop.
0000 is the standard passcode for all bluetooth headsets these days. Try this code and I'll bet it will work.
Posted on Feb 07, 2009
  • 3 Answers
SOURCE: Wep 200
first switch off the headset and then press and hold the multifunctional button for 10 sec then the blue light gets constant then u search frm the phone
the code is 0000
Posted on May 14, 2009
How do i make my jabra work with my blackberry
Hi there, You need to pair the two devices. Make sure the cruiser is off, then push and hold the power button the Jabra for 8-10 seconds until it is in pairing mode. You need to continue holding the button after the device has powered on until you get there. Once there, on BlackBerry go to Bluetooth settings and select search for a device. Select the Jabra Cruiser and put in the passkey - 0000. You have now paired the two devices! Alex
Jun 03, 2011 | Jabra Cruiser InCar Speakerphone Black
I can not pair my phillipson bluetooth #BCK08A to my blackberry curve. How do u pair them together?
Make sure you are in "pairing mode" by holding down the Multi Function Button (MFB) until the red and blue flashing alternately. When the device is off, holding down the MFB for about 5 secs will turn the device on; however, don't release the button and continue to hold until red and blue flashes. Then, you are in pairing mode.
May 06, 2011 | Philips Cell Phones
Hi, I have purchased Samsung Galaxy ACE S5830 whether it is possible to connect Samsung Bluetooth Headset WEP 450. Kindly inform me how to do it.
1 Enter Pairing mode. • Turn off your headset and press and hold the talk button until the blue indicator light remains lit after blinking. • If you turn it on for the first time, it proceeds into Pairing mode immediately.
2 Search for and pair with your phone --> turn on the bluetooth with the widget on the home screen or in the settings. (Bluetooth PIN: 0000, 4 zeros)
• If the pairing is successful, the blue indicator light will flash 10 times rapidly before entering Standby mode. • If the blue indicator light remains lit, retry pairing.
Mar 13, 2011 | Samsung WEP450 Bluetooth Headset - Retail...
Plantronics voyager pro plus is connected and paired with blackberry tour. when a call is coming in, I cannot answer or hang up the phone from the bluetooth headset.
Make sure that your Blackberry's headset mode is activated. If the headset mode is turned on in the Blackberry menu and settings, you may also need to re-pair the headset to your phone to make sure that it has a good connection. Before running through the pairing process, be sure to totally delete the headset from the Blackberry's menu. You may want the headset turned off for this process.
Once you make your Blackberry discoverable, then put the Plantronics Voyager Pro headset into pairing mode by holding the power button until the headset flashes red and blue. Here is the link below for the Voyager Pro pairing instructions.
Plantronics Voyager Pro Pairing Instructions
Good luck from Headsets Direct!
Mar 09, 2011 | Plantronics Voyager PRO Bluetooth Headset
I have a BlueAnt Supertooth BTSLBC3 car speaker that won't pair up to my new BlackBerry curve 8530 phone. The BlackBerry won't see the BlueAnt Supertooth BTSLBC3. The BlueAnt Supertooth BTSLBC3 is paired...
Pairing Your BlueAntStep 2: Activate Pairing Mode on the Supertooth Light
  1. If the microphone arm is open, close it to turn the Supertooth Light off.
  2. Press and hold the answer button.
  3. With the answer button held down, open the microphone arm.
  4. The lights will start flashing red and blue, indicating that the Supertooth Light is in pairing mode.
You now need to activate Bluetooth
Apr 03, 2010 | Blueant Supertooth Light Bluetooth Speaker...
How to pair blackberry storm to plantronics explorer 232
I am a little rusty on the PLantronics 232. but I believe to put it in pair mode, you have to press the volume up and the MFB (multi function button= button that answers and disconnects calls) at the same time. then pair your blackberry like normal. as I recal the pair code either 0000 of 9876
Feb 14, 2010 | RIM BlackBerry Storm 9530 Smartphone
Won't pair with Motorola HS850 headset
How to pair a Motorola HS850 bluetooth headset How to place a Motorola HS 850 bluetooth headset into paring mode:
  1. Close the boom to turn the unit off.
  2. Hold down the call button until the blue light comes on.
  3. While holding down the call button, swing the boom open.
The headset is now in pairing mode, and you can search for it using your phone. When it asks for a PIN, use 0000.
Apr 20, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Bluetooth
Your bluetooth needs to be in pairing mode. Depending on what model bluetooth there are several methods to put it in pairing mode. the most common is pushing and holding the main button until a light changes color.
Dec 02, 2008 | RIM BlackBerry 8800 Smartphone
I have a blackberry curve and am wanting to pair my bluetooth HS850 to it. Please help!
There actually is a trick to the HS850 - flip the boom closed, then hold down the button just until the light holds solid - IMMEDIATELY after it does flip the boom open and this should keep the light solid. Then on your cell/device search for bluetooth devices - you should be able to find it now. Passkey for most devices is 0000.
Jun 30, 2008 | AT&T Blackberry Curve 8300 Smartphone
Pairing
The same way you did to your Razr. Make sure the H700s microphone are is in the off position. Push in and hold the button on the H700 until the light lights up purple. Release the button and quickly open the microphone button. The light will stay purple and you are now in "Pairing Mode". Now follow the instructions for your phone to pair with a BlueTooth unit. When it asks for a code, use 0000 (that is 4 zeros).
Oct 26, 2007 | Motorola Mobility H700 Wireless Headset
Samsung WEP450 Bluetooth Headset - Retail Packaging Logo
723 people viewed this question
Top Samsung Radio Communications Experts
JP Services
JP Services
Jerry Greenberg
Jerry Greenberg
Are you a Samsung Radio Communication Expert? Answer questions, earn points and help others
