Question about Sharp AR-M450N Copier
Copier will not copy error code L6-10 comes up on the screen, what is it?
  • 328 Answers
Change laser unit
Posted on May 30, 2010
I have a problem in bizhub 750 code error c-6708 how can i fix this code error
Might be the Exposure lamp the bright light that comes on under the document feeder make a copy with the doc feeder up does that bright light come on? Or mite be CCD (this is the device that read the original document before it is sent to the LASER) the big black assemble under the big glass. Either one or both mite need to be replaced.
Mar 13, 2015 | Konica Minolta bizhub 750
Minolta Di3510 cannot make copies error code Co500
mam/sir,
First check the right side cover where the image unit is located. Check the two latches that latch that door are not broken especially the rear one. Then get a paper clip and stick the clip in the small hole on the right side of the control panel it will touch a switch. The control panel with go thru some screens when you see the screen with copiers on it on the left side of the screen in the middle you will see a small "." when dot appears touch 3 button. Then the machine will continue to the code screen. Press the utility button should see a new button "Maintenance Mode" touch it then touch trouble reset. The machine will again go thru screens will see the"." again do nothing. Should go ready to Copy. If the code comes back do not reset you are messing with the Fuser the Hot part continue reset without a technician looking at and or replacing it can catch on fire that would ruin a perfectly good day
Jul 30, 2012 | Minolta Di3510f Bizhub Copier
Our copier just started flashing F5 on it's screen. I looked in the manual and it has nothing about an F5 error. Is there anything I could do to clear the error and get it going again?
Hello
The error that you see has got to do with the copy lamp.
Either the control ciruit (inverter) or the the lamp is open circuit
Regards
Apr 28, 2011 | Sharp AL-1642CS Copier
I have purchased machine Aficio 410C. Ones the main power is on it shows error SC542. It should not be solved. Once we clear the error code also. After few seconds it shows same error. Please help us.
Press the keys in this order.
Press Clear all, ( yellow button) then 107, then press and hold the red stop button until the screen changes and displays COPY SP, etc. Press the COPY SP box, once the screen changes again, shut the machine off, then back on. That should reset the code.
If it continues to come up, you will need to replace the hot roll thermistors.
But if it hasnt been used in a while that SP reset should resolve it.
Let me know if this helps please.
Feb 02, 2011 | Ricoh Aficio 1035 Copier
I have a sharp arm237 the error code is h2-01.... I cleared the melted peice of injet paper my daughter used from the heat roller. I still have the error but can't figure out how to clear it.
double check to make sure all paper is removed.
On the key pad press P * C * it will bring up another screen enter 14 and press the copy button it will ask you if your sure you want to clear the error select yes and press copy button machine should restart if error code comes back you will need a tech to come out and check the fuser and connections
Aug 22, 2010 | Sharp AR-M237 Digital Copier
After putting on the copier the scan lamp carriage is vibrating for about 3 to 4 minuet then after the code e7 came.
You need to clear the code, press the following buttons in the order below.
  • Clear Key (far right key)
  • Exposure Key (far left key)
once you do this correctly the screen should go blank. Type in the following
  • 14 (using the copy quantity keys)
  • Press your copy key
  • 1 (using the copy quantity keys)
  • C (until the machine restarts)
If the code comes back then you are having a reference error and will need to call a local Sharp Authorized Dealer to service your machine.
Oct 09, 2009 | Sharp AL-1000 Copier
Comes ready but wont copy. wrench comes on and calls for repair service.
You will need to press and hold "clear" and "8" keys simultaneously. This will display the error code in copy quantity screen. What is the code?
Jun 08, 2009 | Toshiba 2860 Copier
NP 6545 Copier - Error Code E401
error code E401...DF paper feed motor lock...check the motor of your DF...try to turn off the machine and unplug the communication cable from DF to the machine and turn on the machine again...
Mar 16, 2009 | Canon NP 6545 Copier
Error code
will you give more details
blue error?? u mean blue screen of death (BOSD)??
whats the code??
anyways just try to reinstall the drivers that should fix it
Jul 05, 2008 | Canon PIXMA MP470 All-in-One Printer
Ricoh copier
Must have unplugged the thermister on the coupling connection bank. Reset fuser: Clear modes/ 107/ press and hold clear/stop. Pick copy sp. select mode. exit out of all screens and cycle power.
Feb 21, 2008 | Ricoh Aficio 450 Copier
Sharp AR-M450N Copier Logo
79 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
