Question about HP 530 Notebook
My processor fan doesn't work? my space char doesn't work?
  • sajjad ahmed Apr 27, 2010
    nyprocessor fan is make noise
  • 808 Answers
Chek the supply of fan if giving same problem then change the fan
Posted on Aug 03, 2010
My computer shut off in the middle of a game I was playing. After some digging It was because the processor reached 180 degree.
Also where you have the computer has enough space? If this space is a "hole" in your desk the air can't circulate for cooling down.
May 23, 2017 | The Computers & Internet
Processor
Is it clean, free if dust? If you reboot the machine the fan does not spin? This may help: http://www.youtube.com/watch?v=CJ5ZPHiyvEA
Jan 09, 2013 | HP ProBook 4510s Notebook
I cant play fifa 09 on my acer aspire one 522, is it with the resolution? how can I fix this?
Your processor is the problem : It's a dual core 1GHz AMD C-Series processor C-50 and even though it might barely be able to run the game, the game was made before the processor type was released, and thus the game doesn't know what the heck it is and only sees that its a 1GHz CPU and thus considers it to slow to run the game.
Here are the system requirements:
Operating Systems: Windows XP SP2 / Windows Vista - CPU: 2.4 GHz
- RAM: 512 Megabytes of RAM (1 GB required for Windows Vista)
- DirectX 9.0c Compatible 3D accelerated 128 MB video card or equivalent (must support Shader Model 2.0 or above)
- DirectX 9.0c Compatible Sound Card
512kbit/s or greater broadband connection for online gameplay
- 6.1 GB free hard disk space for DVD format and additional space required for DirectX 9.0c installation
- 8x or faster DVD-ROM drive
May 23, 2012 | Acer Aspire One AOD150-1920 Netbook
The LED in my motherboard is on, but if i turn on the switch, their is no response. the power connection is correct. but it doesn't work
Try swapping the power button connection with the reset button connection. Then to turn on your computer you will need to press the reset button. If that works you have a faulty power button. Otherwise try using a different PSU. One that you know works. If that doesn't help the motherboard will have to be replaced.
Jun 18, 2011 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
My Gateway GT5412 suddenly freezes without warning, sometimes the mouse still works and sometimes not. The computer doesn't respond to anything or any button press except a hard power down, then when...
No, it has nothing to do with the fan - a program is using all the power of the processor so when you are forced to shut it down the hard way the file system gets corrupted. If you keep doing it in the end the corruption will be too great to recover and Windows will be completely gone.
To find out what program is causing this you should open Task Manager and have it set as Always On Top from the Options and on Processes tab. When the pc freezes look at it, the bad program will use more than 95% CPU. Restart the pc and uninstall that program.
Jun 14, 2011 | Gateway GT5412 (232587) PC Desktop
Hp a6320in processor fan air flow direction?
Processor fans are setup to nearly always blow air inward onto the heat sink that sits on top of the processor. The heat sink pulls heat off of the processor and the processor fan blows air onto the heat sink to cool the heat sink so that it can pull more heat off the processor. However, read the following link to see that it probably doesn't matter that much which way you put it: http://www.overclock.net/faqs/14695-opinion-****-vs-blow-way-do.html
I would definitely set it up with the processor fan blowing inward onto the CPU. If you're experiencing overheating you can try switching it to see if that helps. Use a program such as SpeedFan to monitor your computer's temperatures.
Good luck, please post back to this solution if you have any difficulties, and thanks for using FixYa.
Jun 01, 2011 | HP Compaq Fan Assembly
Does the patio caddie use any kind of charcoal or lava rock
Your model Char-Broil LP Gas Grill use Lava Briquets on the lower grate above the burner(s). Any generic type will work. Just space them in evenly on the grate in one layer. You'll probably have some left over. So store them in an airtight container for future use (replacement).
Jan 26, 2011 | Char-Broil Patio Caddie 4654870 (LP) Grill
Sunon cpu fan stopped working and I bought another fan/heatsink combination because I couldnt find just the fan only. When I screw the heatsink onto the bracket it leaves a quarter inch space between the...
It sounds like you have the incorrect replacement. You do not want any space between heatsink and CPU.
Will the fan off it swap with your original?
Don't forget themal paste either.
Nov 03, 2010 | E-Machines T5082 PC Desktop
When playing World of Warcraft, my computer overheats in approx. 10 min. It just started doing this a week ago. The fan sounds like it is operationg properly for the laptop. Basic work (E-mail etc....) the...
Hi and thank you for using fixya:
Laptop are very sensitive to heat. They do not contain enough space to put a big fan to cool off the processor. I recommend you buy the cooling docks they sell for about $20.00 with a fan on it. If your laptop has a AMD processor you are really going to need it AMD gets really hot.
Good luck
Apr 08, 2010 | Compaq CQ60-215DX Notebook
After about 15 minutes my laptop heats up and
cooling fan may be pugged up causing processor to heat up and shut down
Feb 01, 2010 | Acer Computers & Internet
HP 530 Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
