Question about Imperial IFS40 Deep Fryer
I need to know the best wayto clean the inside of an IFS40 deep f
We have abuild up of oil inside fryer and need to find a product or solution so we can clean it
    Problem Solver:
  • 11 Answers
Mr. Muscle Commercial oven cleaner, a good brush, a stainless steel scrubbie. Boil out the pot in accordance with Mr. Muscle directions. If all else fails, find "SWELL" oven cleaner in Restaurant supply, use rubber gloves. Spray on, let sit, Use brush and Scrubbie to remove. RINSE WELL!
Posted on May 13, 2010
Have you had any recalls on this product?
Hi there.
If the bubbles come up after loading products on fryer, check the product load quantity and reduce as needed so oil will not overflow. Bubbles came from the water content of the product; more water inside the product, the more bubbles it will produce during cooking so it it better to check the loading quantity.
Regards.
Jun 22, 2014 | Imperial IFS40 Deep Fryer
How do i clean thermopil for ifs40 deeo fryer ?
Buy a new thermopile will be the best thing to do
Apr 21, 2012 | Imperial IFS40 Deep Fryer
Imperial 40 ignites but does not extend flames into heating tubes. Burns only fron
It sounds like your gas line either is clogged or your heating tubes are clogged up with oil/dirt/gunk? You can blow these out with a small hand held compressor or if you have a small enough brush, you can use that to clean it. The compressor is the quickest way, but have you cleaned this unit at all? Using a fryer boil out and running the fryer will also help clean out your holes, but again, the compressor works best.
Nov 21, 2011 | Imperial IFS40 Deep Fryer
I just need to know how to completly clean the bottom of my imperial fryer
Are you talking about the actual burners? They make a L shaped brush that you can use to get around the burners themselves, and a quick tip is to clean the fryer warm.... Once you heat up a griddle or fryer, the cleaning gets substantially easier. They also make either liquid or dry powder cleaning additives, which also help with the cleaning... Once cleaned, make sure you rinse all the soap residue out of the frypot, as that will help to quickly break down your oil, once that new oil is heated up. Another tip is to ony turn the temperature up to 325, not 350, as that also helps to break down your oil. Keep in mind, no matter what yu do, your fryer will never look clean again.... Even the clean, used ones look alittle used after some use and never look shiny new again. If you need any of the cleaning solutions, I do sell them and would be happy to ship some to you... Our individual packets of liquid Mr. Muscle cleaning solutions run $1.95 each and for a 30-40 lb fryer, you need two per cleaning. The directions says to drain oil out and rinse to clean out loose soils, fill w/'water to oil fill line, and get water boiling. You add the Mr. Muscle while filling w/water.... Boil at about 225 temperature for 10-30 minutes. (225 degrees keeps it from boiling over). While it's boiling, gently use a fryer brush or scraper to remove baked on soils. You can also buy the powder version, which is $11.95 for a 9lb jug... Fryer brushes are $24.95 and can withstand alittle of the high heat.... I stock all of these items and can ship to you, if desired. Try this anyway, whereever you end up buying your products and this should work for you...This is how we clean the dirty deep fryers we get in and we've never had any trouble. Our phone number is 888-542-5959, and we are Restaurant Equipment Outlet, Cincinnati, Ohio. We sell new/used equipment, furniture, smallwares, just about anything you need for a food service business.
Thanks, Susan
Jul 18, 2011 | Imperial IFS40 Deep Fryer
I'm not sure on how to wire the new valve for the Imperial IFS40 Deep Fryer does any one know ?
IF THE NEW VALVE IS DIFFERENT FROM THE ORIGINAL IT IS CALLED" FACTORY REPLACEMENT PART",CONTACT THE STORE WERE YOU PURCHEASED THE PART OR CONTACT THE MANUFACTORY FOR INTRUCTION..
Feb 19, 2011 | Imperial IFS40 Deep Fryer
How to drain oil from fryer
Most fryers have a valve right inside the front door that you can place a bottle under and drain the oil right into it...
If not then get a small diameter plastic hose from a hardware store and siphon the oil out...**** the oil up the hose till it is over the side of the fryer, then hold the vacuum and drop the hose over the side and lower then the oil level and the oil will start to siphon out...
heatman101
Sep 03, 2010 | Imperial IFS40 Deep Fryer
We purchased new fryers that are Imperial IFS40 and the salesman was going to check them out and demonstrate the fryers by putting water in them and turning them all the way up. It got so that the water...
Fryers use 2 types of stainless steel. Get a magnet and see if it sticks to the inside of the tank. If so...that is a lower grade of stainless. Use some steel wool to clean the rust spots and cover with vegetable oil. The tanks should be ok if you just bought them.
Tom
Jun 22, 2010 | Imperial IFS40 Deep Fryer
How oftern should a deep fat fryer Oil be change and unit be cleaned
It depends on how much you use it. If you use every day all day them change oil once a week and cleaned at the same time. If used rarley then change oil when food tasted not as good as it shood.
Sep 10, 2009 | Imperial IFS40 Deep Fryer
What is the best way to clean outside?
go to the nearest restaurant supply store and get any product that they sell to clean deep fryers. They all work great
Apr 07, 2009 | Imperial IFS40 Deep Fryer
Imperial IFS40 Deep Fryer Logo
235 people viewed this question
Top Imperial Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dan Webster
Dan Webster
Paul Carew
Are you an Imperial Kitchen Appliances - Other Expert? Answer questions, earn points and help others
