Question about Xerox Phaser 8500/DN Printer
HELP!!! Phaser 8500 Error 09.035.43:28534
Thank you so much for your help in advance!!
  • awiles Mar 24, 2008
    AWESOME!!! It worked!! Thanks!!
    President:
  • 2,072 Answers
That is a cyan ( blue) ink stick count failure.
Look in your ink loader. First just try opening and closing the lid.
Then look for gaps in the cyan sticks. Most likely one is broken, cracked or otherwise jamed in the slot.
If you have to remove them, take a screw and screw it into the ink stick then slide it up the chute and out, then reload.
Hopefully someone didnt try to add or cut up a stick from a differerent phaser.
Thats your problem. Just a stuck cyan ink stick.
Posted on Mar 24, 2008
How to clear error ending in 3433
Phaser 8500/8550 Support - Xerox Support and Drivers
www.support.xerox.com/support/phaser-8500-8550/.../enus.html
XeroxProduct support for Phaser 8500/8550. ... Phaser 8500/8550 Support & Drivers. Customer Technical Support. Fast Track to the Expert > 1-800-835-6100 U.S. & ...
Jul 28, 2015 | Xerox PHASER 8550 COLOR Printer
Hi i have phaser 8560, it gives me a error 09,038,46:62248, plese who can solve me the problem.
Hi there
The onlty thing I can find close to this is.
Acording to the manual its a ink loader error like your loading the wrong type of ink like the puzzles pieces arent matching and hitting the sensor flags right. Yours by the 8 is referring to the black ink. Anyway go to troubleshooting on the control panel. then to service tools. when in service tools press and hold the up arrow while still pressing the up arrow press the down arrow. the display should say hidden menus. go to diagnostic mode press enter go to funtion menu. then go to clear ISC fault and enter. ISC=ink stick count fault. I hope that helps. Just to let you know Ive had nothing but problems with third party ink and once its in the system its hard to get out so I would watch what im doing with my expensive equipment
Feb 18, 2010 | Xerox Phaser 8500/DN Printer
Xerox phaser 8500 error 09.005.40:64314
Best way to do that is take a screw. I use a drywall screw, and twist them into the blocks and slide them back and out. Remove all of them, see if there is just one stuck or not compltely advanced in the loader. Then replace them all . That should clear the code.
Feb 03, 2010 | Xerox Phaser 8500/DN Printer
Please help me wit lsu error for my workcentre pe220 Thank you
Your Laser Scanner Unit has a problem, probably a bad Polygon Mirror Motor.
Dec 14, 2009 | Xerox Phaser 8500/DN Printer
Phaser 8560 Error Code 09,005.40.5185
Hi mark711:
Here is you problem.
9,005.49: Ink loader fault. The cyan ink melt heater is on, but the ink does not
appear to be dripping.
Troubleshooting Procedure
Step Questions and Actions Yes No
1 1.
Are the ink sticks all Xerox ink? Go to
Step 2.
Advise
customer. Run
clearISCfault
test to clear the
error.
2 1. Manually verify that the ink stick is able to
advance in the ink loader chute.
Go to
Step 3.
Remove any
blockage and/
or replace the
ink stick.Run
clearISCfault
test to clear the
error.
3 1. Run the appropriate Ink Melt [1, 2, 3, 4]
Heater
test.
1 = Yellow
2 = Cyan
3 = Magenta
4 = Black
2. Did the test pass?
Replace
the
printhead.
Replace the ink
loader
assembly. Run
clearISCfault
test to clear the error.
Hope this helps
Apr 23, 2009 | Xerox Phaser 8500/DN Printer
Phaser 8500 error 19.003.48
That is a print head calabration error.
Most likely the print head has failed.
Those also are extremely expensive parts you put into it.
Oct 21, 2008 | Xerox Phaser 8500/DN Printer
I have a Phaser 8400 printer that needs to be repaired. Where are your authorized service stations in my area (Miami, FL 33142)?
Here you go
clear.gif UNITED DATA TECHNOLOGIES INC
8825 NW 21ST TERRACE
DORAL, FL 33172
Phone: 305-882-0435
Fax: 305-882-0436
Products Serviced: Phaser 8200, Phaser 860
clear.gif MONARCH ELECTRONICS INC
SUITE 319
1440 79TH STREET CAUSEWAY
NORTH BAY VILLAGE, FL 33141
Phone: 305-866-1885
Fax: 305-865-8087
Products Serviced: Phaser 6120, Phaser 8400, Phaser 8500, Phaser 8550, Phaser 8560, WorkCentre C2424
depot_logo_small.gif IT SOLUTIONS
7210 NW 58TH ST
MIAMI, FL 33166
Phone: 305-513-0059
Fax: 305-513-0062
Products Serviced: DocuPrint 4508, DocuPrint N2025, DocuPrint N2825, FaxCentre F110, Phaser 3150, Phaser 3400, Phaser 5400, Phaser 5500, Phaser 560, Phaser 6200, Phaser 6250, Phaser 6300, Phaser 6350, Phaser 740, Phaser 7400, Phaser 750, Phaser 780, Phaser 8400, Phaser 850, Phaser 8500, Phaser 8550, WorkCentre C2424, WorkCentre PRO 423, WorkCentre PRO 423/428, WorkCentre PRO 428
clear.gif LASER PRINTER SOLUTION / FIX A FAX CORP
7240 NW 31 STREET
MIAMI, FL 33122
Phone: 305-471-0093
Fax: 305-471-0113
Products Serviced: Phaser 6200, Phaser 6250, Phaser 6300, Phaser 6350, Phaser 840, Phaser 8400, Phaser 8500, Phaser 8550, WorkCentre PE120, WorkCentre PE120I
clear.gif P M E INC
SUITE 130
10800 NW 21ST STREET
MIAMI, FL 33172
Phone: 305-994-9222
Fax: 305-994-9922
Products Serviced: CopyCentre C20, DocuColor 2006, DocuPrint 4508, DocuPrint 4512/4512N, DocuPrint N17, DocuPrint N2025, DocuPrint N2125, DocuPrint N24, DocuPrint N24/N32, DocuPrint N2825, DocuPrint N32, DocuPrint N3225, DocuPrint N40, DocuPrint N4025, DocuPrint N4525, DocuPrint P1202, DocuPrint P1210, FaxCentre F110, FaxCentre F116, N2025/N2825, N2125, N3225/N4025, N4525, N4525, Phaser 1235, Phaser 2135, Phaser 3150, Phaser 3200MFP, Phaser 3400, Phaser 3450, Phaser 3500, Phaser 4400, Phaser 4500, Phaser 5400, Phaser 5500, Phaser 560, Phaser 6100, Phaser 6120, Phaser 6200, Phaser 6250, Phaser 6300, Phaser 6350, Phaser 7300, Phaser 740, Phaser 7400, Phaser 750, Phaser 7700, Phaser 7750, Phaser 7760, Phaser 780, Phaser 790, Phaser 8200, Phaser 840, Phaser 8400, Phaser 850, Phaser 8500, Phaser 8510/8560MFP, Phaser 8550, Phaser 8560, Phaser 8560MFP, Phaser 860, WorkCentre C2424, WorkCentre M20, WorkCentre M20I, WorkCentre PE120, WorkCentre PE120I, WorkCentre PE16, WorkCentre PE220
clear.gif ADVANCED BUSINESS COMPUTERS
1523 NW 89TH COURT
MIAMI, FL 33172
Phone: 305-477-2320
Fax: 305-477-3735
Products Serviced: Phaser 4400
Oct 01, 2008 | Xerox Office Equipment & Supplies
Phaser error ERROR CODE: 09,038,46.8515
that is an error with the ink sticks. Most likely one of the sticks is not advancing downward in the machine. Look where the sticks are loaded you will most likely find one not advancing because its twisted , cracked etc. The 46 at the end most likely means its the cyan stick, but check them all for proper movement in the ink loader.
If you have to remove them, take a screw, like a dry wall screw and twist it into the ink block and slide it up and out.
Rarely will the ink loader itself fail. If you have somehow loaded an ink stick from a different phaser model number, they are different shaped and will not actuate the switch at the end of the ink loader.
Aug 05, 2008 | Xerox Phaser 8500/DN Printer
Xerox Phaser 8500N Printer Error
That is a yellow ink stick fault.
One is most likely stuck. cracked or otherwise not advance to the front of the ink loader. Check the sticks
May 27, 2008 | Xerox Phaser 8500/DN Printer
Xerox 8500 Error 07,101.43:20955
That has to do with the process drive gear box. May be mis timed or a gear broken.
Apr 11, 2008 | Xerox Phaser 8500/DN Printer
Xerox Phaser  8500/DN Printer Logo
598 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
