Question about Garden
I have a puch lawn mower that is idling high and
I have a push lawn mower that is idling high and low. It is a briggs and stratton with a rectangular tank and carb on the same side. I have check the governor spring which seems fine. I have also taken off the fuel filter and cleaned it. It still idels funny whether your stopped or pushing it. Any ideas?
    Sniper:
  • 52 Answers
I don't know what type carb is on this one, but most have a diaphram. If the diaphram is weak it will cause this. You can purchase a new diaphram at a Lawnmower service center. It's not that hard to install.
Posted on Apr 28, 2010
Gas controll only operates in high or low controll will not stay ingaged between high and low.
The mower is designed to mow at high throttle only... Low is for warming up or idle purposes...
Jul 28, 2014 | Husqvarna "MZ6128ZT 61"" Briggs And...
How do I adjust a throttle on a briggs and stratton engine?
If it the simple handle type throttle cable..push it to full tbottle and follow the cable to the carb..you should fund a small clamp that hold the cable in position..jus loosen and adjust the carb throttle to full throttle and tighten..then push it back to idle to make sure it Idles if not adjust the clamp again until you reach both throttle and idle..good luck..
May 17, 2014 | Briggs & Stratton Briggs Stratton...
How do you control idle
This sounds like a governor problem, try moving the governor back and forth,l
Apr 17, 2013 | Craftsman 675 Torque 190cc 21" Briggs ...
Low idle after starting
if it is powered by Briggs n Stratton donnyboy73 on youtube has a excellent video on that set up.
Nov 06, 2012 | Poulan Push Mower
How do i idle down the engine or govern down the engine on a briggs and stratton 550 series mower model 10T802
that engine uses a fin style governor remove the upper cover and see if there is a nest or something holding the fins movement
Jul 12, 2012 | Briggs & Stratton Briggs Stratton...
Adjusting governor/throttle briggs and stratton
there should be a little screw to help adjust your idle try that..counterclockwise to add more idle, clockwise to slow idle..
Apr 26, 2012 | Briggs & Stratton Garden
Poulan pro 625 lawn mower idles slow and rough
Try changing your plug and check gap and put in some fresh fuel. Empty out the old stuff especially if it has been there a while. Also check your low idle setting on the carb open it up a half turn for starters. Good Luck...
Aug 27, 2011 | Poulan Pro 22inch 625 Series Briggs ...
I can get my briggs & stratton push mower to
Your carb needs to by cleaned out. Needs to be taken apart and cleaned with carb cleaner. There is also a gasket that needs to be replaced. It collapsed and not letting gas in the carb.
Jul 07, 2010 | Poulan Pro 22inch 625 Series Briggs ...
Mtd 22" low idling how do I correct the problem?
if this has a briggs & stratton engine on it, then the idling is set thru a spring on top of the carberator. some units have an idle set screw also. if it has an idle set screw, turn it in untill it idles where you want it to, if it just has a spring, then replace the spring.
May 28, 2010 | Mtd 22" Yard Machine Push Mower
Lawnmower engine idling to low
First, follow your throttle cable down to the carb. Locate the clamp that holds the housing in place and loosen it just enough to move the cable. Start the mower and adjust the idle by the screw that touches the same plate that your cable hooks to. Then push the throttle control to idle and retighten the cable clamp.
Apr 26, 2010 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
Garden Logo
203 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
