Computer Hi, I built my own computer 5 years ago and it's been absolutely reliable until just the last 3 days. I leave my computer run almost 24/7. Two nights ago, in the middle of the night, I was woke up by this awful, high-pitched whine. When I figured out it was coming from my computer, I ran over and hit the power switch, which did nothing. The monitor was already off from a power-down setting, so nothing was happening there, but it was still whining. I had to reach to the back of the tower and switch off the manual power switch to stop the whine. I went back to bed, got up the next morning, powered it up and it was fine the next day and all day yesterday until last night when the same thing happened. Only, this time, I was using it. The high-pitched started up and the entire machine just shut off. Immediately. I waited about 5 minutes and turned it back on so that I could check temperatures of the motherboard and CPU and they were in the medium to high range but not over my automatic "shut off" setting. Any ideas? Thanks.
  • 4 more comments
  • Teresa Clark Mar 31, 2008
    Okay...here's so far. I unplugged my wireless network and the PC ran great with no problems for almost 2 days. But, then again, while I was working, it started the constant LOUD high-pitched whine and then shut off all by itself. So, I swapped out the power supply and it ran now for about 30 hours. In the middle of the night, it woke me up screaming but instead of automatically shutting off, I had to manually shut it off. The old power supply had a manual "off" toggle switch on the back of it and when I would shut that off, the mother board made a sound that I really can't describe other than it sounding like someone let the air out of it, or a release of some kind, but it wasn't an "air" sound, it was more like a squeak. Sorry, I can't be more specific then that. With THIS power supply, there is no toggle switch on the back of it. When I went to turn the PC back on this morning by the power switch, it wouldn't turn on. Nothing. So, I unplugged it, it made that same "squeak" sound, I plugged it back in, and I could turn it on. It's now ran for 5 hours. The PC fan now is new, so it's not that. The fans inside my computer have been checked and my computer runs with the case open, so I'm watching them as I write this, they are running smoothly. This happens whether or not I have a bunch of programs running or only a few. I've checked the temperature, it's not high enough to shut it down. Could this be a motherboard giving out? It's 5 to 6 years old now. Thanks for all your input, everyone.
    I looked at each capacitor with a flashlight and not one of them is bulging. I've seen that before on someone else's computer so I knew what you were talking about and knew what I was looking for and nope, not one. They all look just like they did the first day I built the PC. Thanks.
  • Teresa Clark Apr 01, 2008
    It's a Soyo KT400 Dragon Ultra Board with VIA KT400+VT8235 chipset.
    I found someone last night that was unusual. When looking at my device manager, the drivers for the RAID controller were missing. These drivers were there before and I pulled out the installation CD and restored them. So far, so good. Could this have anything to do with it? I don't fully understand "RAID" so I'm not sure if this could have contributed to my problem or not.
    Thanks so much for your help. Sorry that I didn't give you the MB name and model sooner.
  • Teresa Clark Apr 03, 2008
    Ever since I reinstalled the drivers for the RAID controller, it hasn't woke me up in the middle of the night and it hasn't shut down. So, evidently, it's the motherboard then, correct? Now I just need to determine whether it's the Biopsies, or hardware, but still the motherboard? I guess maybe I should just order a new motherboard and plan on replacing it soon. Very soon, eh? Thanks so much for all of your help, everyone.
    The BIOS!! not biopsies... LOL.. Sorry. I forgot to shut off my keyboard shorthand.
  • Marty marty May 11, 2010
    sounds like the power supply is starting to kick out...
  • 4,234 Answers
Look at the capacitors on the motherboard. These are cylinders scattered all over the place. The tops should be flat. I would suspect that some of them are now bulged up. This means that the main power lines are not being filtered correctly. Over time this will result in oscillation which is what you hear. These parts can be replaced by anyone with experience with multi-layered Pc boards. Let us know if you still have the problem.
Dan
Posted on Mar 31, 2008
    Brigadier General:
  • 6,966 Answers
Can think of only three possibilities:
1. CPU fan motor, bearings needs lubrication or replacement;
2. Power Supply fan motor, same as above or any of the other fans;
3. Hard disk spindle motor (though unlikely).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Mar 24, 2008
  • 2 more comments
  • Louie  Role
    Louie Role Mar 31, 2008
    Hi again,
    If you are sure that it is not the CPU fan nor the PSU neither any of your other devices (HD, CD etc) then that leaves us only with the motherboard. Some Asus brands have been known to have a twee-dee sound when the motherboard is failing. It is different from the beeping sounds.
  • Louie  Role
    What is *********** board (brand and model) pls?
  • Louie  Role
    Louie Role Apr 01, 2008
    Hi again,
    Appreciate the postback and the additional information.
    The RAID configuration being there before and suddenly missing (without your intervention) is indicative of your BIOS/CMOS resetting. Perhaps you can try to reset your CMOS/BIOS using the jumper for that purpose. Alternately, you can do a reset by removing the Lithium memory battery for a couple of minutes. Upon initial startup, I would suggest that you just change the day/date/time and select Default Settings, Save and Exit. This is the Fail Safe mode/setting of the motherboard and most advanced features would not be enable. Thereafter you should try the PC again and burn it in to determine if problem will recur. If no, then it is a motherboard (BIOS) problem, if yes then it is a motherboard (hardware) problem.
    Again, the above was based on the presumption that all other components have checked out to be OK.
    Cheers.
  • Louie  Role
    Louie Role Apr 03, 2008
    New motherboard would be the best option. However, consider availability of one appropriate for your processor and memory. Glad to be of some assistance and appreciate the rating. Cheers.
Freezer too warm, and i feel heat on the door seals
The door seals warm is from the mullion heater that minimizes moisture from forming in that area, under working conditions. You need to provide more information.... What did you see that made you defrost it 3 weeks ago..
Nov 27, 2013 | Kenmore 53542 / 53544 Side by Side...
Tip
Make your Lithium Laptop Battery last longer.
Hello folks,
Although I usually offer advice on backing up files or recovering them, I have been asked a lot lately how my 3 year old laptop still runs 1:45mins on a standard battery when many peoples 1-2 year old laptops can barely last an hour.
Simply put, most people do one of two things wrong. Both are common misconceptions and easy to remedy. First I've heard countless people tell me they pop the battery out of their laptop and toss it in the desk drawer until needed, often months. Second I have been told by more people than I can count that they leave their laptop plugged in 24/7 for most of the year.
Bottom line, although popping it out and leaving it in the drawer is less harmful to it's lifespan, both ideas are wrong.
The shelf life of most unused lithium batteries is shorter when unused than ones being used properly. The lifespan of a battery that is constantly being trickle charged is even shorter.
Most batteries in modern laptops are 4-6 cells, designed to give about 2 hours of charge and should last 3-5 years with charge life starting to degrade in the third year.
A "stored battery" has only 3 years of shelf life due to extended times sitting discharged and one that is trickle charged 24/7 may burn out in as little as a year.
Many laptop manufacturers have taken measures to improve this but ultimately the best thing for your battery is to use it. If you currently run you laptop plugged in 24/7, unplug it every night after you shut it off, then when you start it in the morning, let it run an hour before plugging it back in. This will give the battery both down time and exercise.
If your battery is in a drawer somewhere for safe keeping, put it back in the laptop, run it down then charge it over night and run it down then recharge it one more time. Store it back in the drawer charged and repeat the cycle at least once a month.
These tips will help drastically improve you batteries performance over time. My 3 year old laptop only ever got 2 hours of battery life and still gets 1:45 with no power saving measures, give it a try.
Crankstart
on Mar 20, 2010 | Computers & Internet
Hi, I am in the process of installing a new kitchen. I was recommended to buy Smeg appliances- an oven and ceramic hotplate by a salesperson stating they are very good aplliances, however another...
From experience I have found Smeg appliances to be very reliable.
It is difficult to judge reliability of appliances but generally these days NO appliance will last without some form of brake down. They are not made to the same quality as appliances of a few years ago.
If you stick to german made appliances (Bosch, Neff, inc Smeg ) then they tend to be built to a higher spec.
Regards
Aardvark Repairs
Nov 16, 2009 | Ovens
Contour died after starting - 3 times total - kept foot on gas until I got out on highway - ran fine. Car has started and run fine for the last 4-5 days, approximately 24 starts.
did u have a check engine elight? had you just recently gased up?, u may have had some water in the fuel, i would have a Autozone parts store test the system for trouble codes, tell them u need an OBD 2 test run, it is free, if anything is failing it should have set a code in the cars computer.
Oct 20, 2009 | 2000 Ford Contour
I have had two computer shops look at my vaoi and test everything form hard drive to software to how hot it runs etc. NOTHING. The computer works for a day and then freezes where you have to press the...
I had the same problem, and it came back twice. Last resort was to completely format hard drive and reload windows and has been running fine for 3 months now.
Sep 16, 2009 | Sony VAIO VGN-N250E/B Notebook
Monitor goes blank less than a second after turning on.
I start my computer and turn it on, and everything looks fine for about 1/4 of a second and then it goes black while leaving the power light green. I can only see the screen again after turning it off and on, but that's only for another 1/4 second. What's up?
I got my rosewill flatscreen as a hand me down from my father. I've had it for several years now. Was working fine until a month ago. When I turn the computer on the screen goes black after 1/4 of a saecond. I have to turn it off and on anywhere from 10 to 20 times before it stays on. I have checked all plugs to the computer and outlets. I have absolutely no idea whats causing this.
Dec 28, 2007 | Rosewill R700J 17" Flat Panel LCD Monitor
Ultra Wash
Sounds like your not getting water to it. Turn on and let run for a few minutes then open door and check to see if you have water in it.
If not check to be sure water to it is turned on. Check float in front corner of dishwasher to see if moves freely up and down and that there is nothing underneath it. If these check ok you probably need a water valve.
Nov 03, 2007 | Kenmore 24 in. 15689 Built-in Dishwasher
Can see screen for one second
I had mine for almost 3 years and last month ran into the same problem and i take good care of it. I turn it on it stays on for a 1-3 sec and goes black. can't figure out what it is
Apr 19, 2007 | Liquid Video L17LCD2 17" Flat Panel LCD...
Computers & Internet Logo
276 people viewed this question
David Payne
David Payne
