Question about Whirlpool Duet GHW9150P Front Load Washer
Washer will wash for much longer than the cycle states it is supposed to wash. For example, on the 18 minutes, quick wash cycle, it may take 1 hour to complete the wash.
  • mistymbrown Apr 27, 2010
    Plus, the whole house shakes when it is washing and spinning. The washer is level. I also get error codes and have had a repairman out to fix. I am now getting a SUD error now. I turn the washer off and wash on a quick wash cycle and it will complete in an hour. But if I try to wash on a normal wash cycle, I get errors?
    Problem Solver:
  • 7 Answers
Ya its good there is no problem wid it
Posted on Apr 27, 2010
Manua beko 5kg aa class 1000 rpm
most washers on a full wash cycle take about 60 minutes. It will take longer if you use a soak cycle with extra minutes because if you have a soak cycle and you set it for 30 minutes the total wash time will be around 1 hour and 30 minutes.
Jun 22, 2013 | Washing Machines
I just moved into a furnished apartment with a Hoover washer. Please could you explain how to operate it. I have used it twice, but both times it took at least 3 hours to complete the washing.
this is probably because most front load washer heat the water. check if you can adjust temperature or turn off,or check if the washer has a quick cycle for example quick 30 minute cycle.good luck keep me informed
Jun 22, 2010 | Hoover AAA160 Front Load Washer
The washer takes forever to complete it will take
front load washsher do take longer to wash than top load but it should not take 2 hours on a short cycle. has it always done this
Jun 23, 2009 | LG WM-2277HW Front Load Washer
E10
Are you using HE or high efficiency detergent? E10 code can also indicate over sudsing caused by standard detergents. Also, standard detergents, due to over sudsing can cause long washing cycles as well. This sounds like your problem.
Jun 07, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer has timing issue, says it will wash for 45 minutes and wash for 1 hour and 15 minutes. The cycle says 50 minutes but it ends up taking 75 minutes.
This is really not uncommon. The more and more sophistocated the machines become, the more small decisions they make on their own. I have seen a one hour load take up to 2.5 hours.
If a load is off balanced, it will change the time. If the spin cycle doesn't spin enough water out, it will increase the time, and may still be too wet. (In that case you need to clean out the lint/drain trap.)
If you really want more control and quicker washes, there will be a setting like "Quick wash " or "Fast wash." Theis setting is quite basic and does exactly what you tell it to do, and you can always add and extra rinse, or higher speed cycles.
Kenmores and GEs are the highest reported rate of longer times. Relax. The more you add, ie, delicate, two rinses, light spin, medium dry, the longer it will take. It's just trying to do its job! :)
Sirwriter
May 29, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
try using less detergent. I found the more i detergent I used the longer it took for the cycle to complete.
Mar 28, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
When doing quick wash "25 minutes" why does it take an hour?
one think comes to mind if you have extra rinse selected un select it all preset cycle times arent based on extra rinse
Sep 05, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Pre select cycle times are getting longer
try cleaning the hose screens and the screens in the water valve. tuen off the water supply and remove the hoses from the back of the machine as well as the water supply. check for sediment or other debris and replace the screens as needed and reconnect.
Jun 09, 2007 | Maytag Neptune MAH5500B Front Load Washer
Washing time & quality
Look for wash cycles in your users'manual. It is best the read the manual well before operation.
Apr 05, 2007 | Whirlpool AWG320 Front Load Washer / Dryer
Whirlpool Duet GHW9150P Front Load Washer Logo
256 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
