Question about HP LaserJet 1600 Printer
I got of my HP Color LaserJet 1600 a warning Jum
I got of my HP Color LaserJet 1600 a warning "Jum in output bin and Open door and clean jum", What should I do ?
    Director Badge:
    Uploaded 100 video answers.
  • 1,751 Answers
Open the door of your printer and remove jammed paper
Posted on May 01, 2010
Gympac 1600 manual
Device error An internal error occurred in the device. Press (Select) to resume the job. - Door open The printer door is open. The door must be closed before printing can continue. - Engine comm. error The device experienced an internal communication error. This is a warning message only. Job output might be affected. - Invalid driver You are using the incorrect printer driver. Reselect the printer driver appropriate for your device. - Invalid entry Invalid data or response. Correct the entry. - Jam in Cartridge area A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel - Jam in Output bin A paper jam has occurred in the output area. Clear the jam, and then press the (Select) button on the control panel. - Jam in print paper path. A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel. - Jam in tray 2 A paper jam has occurred in Tray 2. Clear the jam, and then press the (Select) button on the control panel. - Jam in tray 3 A paper jam has occurred in Tray 3. Clear the jam, and then press the (Select) button on the control panel - Load paper The HP Color LaserJet 1600 printer is out of paper. Please load specified paper type into the tray indicated. - Load Tray X [TYPE] [SIZE] The printer is processing job, but the tray indicated is empty. Please load specified paper type and size into the tray indicated. - Manual feed The printer is waiting for paper in the tray indicated Load the paper as indicated. - Memory is low The device memory has been almost completely filled. Allow the device to finish the job, or press (Select) to cancel the job. Break the job into smaller jobs that contain fewer pages. - Misprint The printed pages have been incorrectly placed on the paper. To continue, press the (Select) button on the control panel.
Dec 31, 2014 | Office Equipment & Supplies
Paper Jam errror
Jam in output bin - duplex area
Error message
Jam in output bin
alternates with
Open door and clear jam
Description
Paper jam in duplex reversing area
Action
  1. Clear the jam.
  2. Press the (SELECT) button on the control panel.
  3. If the problem continues, contact HP Customer Support Center for technical assistance at http://www.hp.com/support/clj2600n or see the flyer that came in the printer box for additional contact information.
Jam in output bin - fuser area
Error message
Jam in output bin
alternates with
Description
A paper jam has occurred in the output bin near the fuser area.
Action
  1. Clear the jam.
Goodluck..
May 14, 2008 | HP Color LaserJet 2600n Printer
My hp color laserjet 1600 leaves blue streaks on all the copies how do i clean the unit to stop this?
please refer to the link below. I have read up on the cleaning sheets mentioned above and it seems that they either work or they thoroughly jam up your printer
HP LaserJet 1600 Printer Print Quality Defects
Sep 17, 2014 | HP Color LaserJet 1600
How do i fix door open message on my hp color laserjet 1600
hi you have to check the door closer assembly there is a liver that operate the door sensor
Jul 14, 2014 | HP Color LaserJet 2600n Printer
Paper Jam at HP LaserJet P2055d
There is output sensor where the papers come out, make sure its lowered down, be VERY CAREFUL not to break it.
Jun 11, 2010 | HP LaserJet P2055d Printer
My printer says there is a jam in the output bin but there is no visable jam. HP color laserjet 2600n
Just try the steps
Jam in output bin - fuser area Error messageJam in output binalternates withOpen door and clear jam DescriptionA paper jam has occurred in the output bin near the fuser area. Action
  1. Clear the jam.
  2. Press the c00381085.jpg (SELECT) button on the control panel.
Jam in output bin - duplex area Error messageJam in output binalternates withOpen door and clear jam DescriptionPaper jam in duplex reversing area Action
  1. Clear the jam.
  2. Press the c00381085.jpg (SELECT) button on the control panel.Please Rate my response!!!Thanks, SF
Jan 28, 2010 | HP Color LaserJet 2600n Printer
The screen says JUM Error Reset. What do I do? I was charging the phone and when I unplugged it this is what the screen said. Push to reset it and the screen shuts off and comes back on with the same...
oof. JUM= oh ****. What JUM error code is it?? With the phone on pull the battery out. I doubt that will do anything but it's the easiest and what do you have to lose ?? And when that doesn't work download a program called JL commander and wipe the phone clean, re-install the OS. Hope you backed up your info
Dec 14, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
Paper jam in printer
Dear
It is the problem paper end sensor is open or fedd sensor is open.
power on then paper jum it is the same problem. or power on printer is ready after print command then paper jum it problem your cartridge chip is diable or feed claught is not active
Jun 17, 2009 | HP Color LaserJet 5550dn Q3715A Workgroup...
Blank screen
cartridge sensor eror or cartridge not detect or paper jum
May 18, 2009 | Samsung ML 2010 Laser Printer
HP LaserJet 1600 Printer Logo
335 people viewed this question
Seeker5211
Seeker5211
