Question about Gigabyte GA-EP45-UD3L Motherboard
Using Corsair XMS Memory 2 1g sticks and works good, tried putting 2 more memory modules to upgrade to 4g and goes into a post loop??
    Genius:
  • 1,027 Answers
The memory should all match each other (same type). That board should handle up to 16gb using DDR2 1066/800/667 modules, although Win XP can only go to 3Gb.
Posted on Apr 27, 2010
Ok i have 2 1gb corsair memory sticks and when i put them both in they wont work but when i use one it will its the slot on the mother board i think is there anyway to fix it
try the known good memory stick and try to reseat the memory stick to every slot that your mobo have. so you would know if the problem is with the mobo or the memory stick itself
Mar 29, 2010 | EliteGroup ECS 915P-A2 Intel 915P Socket...
Cannot upgrade memory on my Gateway MX3215
Use Corsair Value Select VS1GSDS533D2.
Aug 17, 2009 | Gateway MX3215 Notebook
Acer Aspire 5601 4GB memory upgrade problem
Acer systems are picky about the type of memory you use.
What is your RAM Speed on the old chips compaired to the new chip
You may have to reorder the same type of speed memory
Try this website it will tell you what will work with your system
http://www.ec.kingston.com/ecom/configurator_new/mfrmod.asp?root=us&LinkBack=http://www.kingston.com
Aug 22, 2009 | Acer Computers & Internet
Memory upgrade
Hi there.
The best memory for that motherboard is DDR SDRAM, the supported ram speed is 266 MHz • 200 MHz(maximum 2BG, 1BG in each slot)
Kingston or corsair memory running at 266MHz is my recommendation to you. Try not to buy used memory as it may not work!!
Good luck and thanks for using Fixya!!
Feb 19, 2009 | Mach Speed PM2MP Motherboard
Abit AW8 LGA775 Maximum memory
Hi there
Sounds like the bios will need updating as the board will support 8BG ram.
Put your old memory back in the machine, boot into windows, go to the motherboards manufacturers website and download the latest bios update and install it and reboot.
make sure you read the info on how to install the bios update.
I must also warn you that if you are using a 32bit operating system it will only recognize 2.9BG of memory, there is nothing you can do about this apart from install a 64bit operating system if the board supports 64bit processors.
Good luck and thanks for using Fixya!!!
Feb 11, 2009 | Abit AW8-MAX Motherboard
I have 4 sticks of memory that are Corsair XMS 2x1024, (2GB) and I have already got 2 installed. My question is I have installed the other two and now have 4 sticks. The LED lights are working, but the...
winlogon.exe has become corrupted....shouldn't be memory related.....try using safe mode to restore your pc from a restore point....alternativly you'll need a boot disk like ERD commander to boot from cd and get to a restore point
Dec 30, 2008 | Corsair Memory 2GB PC6400 DDR2 Desktop...
2 GB or more RAM is not functional
try maybe theres a problem in memory compatibility...dude first try to put same memory card brand and specs
Sep 01, 2008 | MSI K8N Neo4-F Motherboard
Added a memory stick to my Dell 2400 Desktop computer and the monitor, mouse, & keyboard won't work
Hi
The supported Memory types for Dimension 2400 Series is PC2100 (266-MHz) or PC2700 (333-MHz) DDR SDRAM (non-ECC). Supported Memory capacities are 128, 256, or 512MB and a Max if 1GB (1024MB).
The first obvious question is does the new 512MB Memory module meet the above specification? Some Memory modules are able to steep down speed.
If it does, then first ensure the new memory module is properly installed. Take ESD (ElectroStatic Discharge) precautions or you may damage the new memory module and/or the system board.
To proceed compare the system beeps and diagnostics lights color and sequence to the Advanced Troubleshooting guide.
It is possible that the new memory is DOA (Dead On Arrival). Or there is a new fault on the system. If you have access to another compatible system, you may test the new and old memory modules. You may also swap the new and old memory modules to determine if the memory slot is at fault.
Lastly, if you remove the new memory module, does the system complete POST (Power On Self Test)?. If it does you may indeed have a DOA or incompatible part.
Mike
Jul 26, 2008 | Dell Dimension 2400 PC Desktop
New Graphics card wont work
is the bios set to dispaly using a built in graphics card on the mobo?
Jul 02, 2008 | Intel Motherboard
Won't run
you have,nt seated the memory module back correctly.
push module in at an angle, usually about 45 degrees.
while pushing it back in, apply pressure, to push down towards the motherboard. ** check for any specs of Dust**
also check that you have,nt knocked the hard-drive ribbon cable in the process of cleaning.
Mike @ Compurepair.
Feb 23, 2008 | Toshiba Satellite A85-S107 Notebook
Gigabyte GA-EP45-UD3L Motherboard Logo
87 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
