Question about RCA P52960 52" Rear Projection Television
Rca model p61960 projection tv dead
No picture no sound hor output tested good main fuse good .before it went dead there was no sound.could it be the eeprom?
Most likely a bad push pad on front of tv button stuck or bad push pad
Posted on Nov 02, 2008
I have a P61960 RCA TV and it is really acting crazy. It is displaying numbers in the top right corner and they are scrolling from 1 to 99. This is nonstop. None of the controls (volumn, channels, menu) work while these numbers are scrolling. Any suggestions??
Posted on Aug 01, 2008
    Genius:
  • 1,694 Answers
More likely a bad flyback transformer......T.
Posted on May 12, 2008
SOURCE:
Rca p61960 model has sound but no picture
Control board and lamp may need replacing. Start with the lamp and then have a pro check the board if necessary. Good Luck
Nov 20, 2013 | Televison & Video
Picture not on
no tv picture so
und comes on and goes off
Oct 23, 2013 | RCA P61960 61" Rear Projection Television
My rca 60" projection tv turns on and has sound
I had a 56 toshiba do that and it was the light bulb inside. It wasn't difficult to replace.
Nov 14, 2010 | RCA P61960 61" Rear Projection Television
I hear sound,but no picture. I was watching it heard a popping noise and the picture went out.
you will have to trouble shoot the deflection circuit it may be a bad flyback transformer and output transistor
most likley still worth fixing
Nov 09, 2009 | RCA P61960 61" Rear Projection Television
I would like to buy a rca 61 P61960
Hi jkclay841 i live new york and have a RCA REAR PROJECTION TV 61" MODEL # P61960 CHASSIS NUMBER PTK195Y06T
IT POWERS ON BUT IT'S OUT OF ALIGNMENT ON ALL COLORS AND MISSING THE CLOTH THAT COVERS THE SPEAKERS HAVE THE REMOTE SCREEN IS IN GREAT CONDITION ALSO HAVE SOME NEW CRT COOLANT RUBER SEALS ,AND THREE NEW LENCES THAT I WAS GOIN TO REPLACE BUT CHANGED MY MIND PLUS NO TIME.
HERE IS MY NUMBER 347- 847 -3348 IM JOSE
Apr 03, 2009 | RCA P61960 61" Rear Projection Television
Rca p61960 projection tv
That sounds like a Pincushion problem if you having bowing. It's probably bad caps and diodes on the deflection module. This is not an easy fix. If you know how to read a diode and you visually inspected the caps you might have some chance of fixing it yourself.
Aug 17, 2008 | RCA P61960 61" Rear Projection Television
RCA P61960 61 in not working
I am looking for parts for this television if you can't find a way to fix it, let me know
Feb 19, 2008 | RCA P61960 61" Rear Projection Television
RCA 61" Model P61960 stopped working
You have a flyback transformer and horz output transistor bad
Nov 04, 2007 | RCA P61960 61" Rear Projection Television
32v434t dead
please go according to procedure 1 isolate h/output section supply. 2 check power supply output is ok if not repaire it. 3 after power supply is ok 4 check hor osc, driver &output if problem repair it. 5 check for loose contact or print break. 6 connect supply to hor section. set will work fine. good luck.
Sep 21, 2007 | RCA 32V550T 32" TV
DEAD TV
Is good you have checked the main fuse and is good,what that means is you have voltage going in but you loose it down the line,if you have no indication of power(no lights ,no clicks) you need to check if you have the 5 volts that power the microprocessor witch is the brain and it uses 5 volts to aperate,the 5 volts come from a 12 volt regulator so you will have 12 volts in one side and 5 volts in the other,if you have lights or clicks when you push the power button you have 5 volts but one of the other voltages is missing,Check the horizontal output transistor for a short,if it is bad it likely cooked the safety resistor that gives him the voltage.If you are familiar with tv service you have a place to start but if you are not too familiar be safe and call for assistance from a servicer.Let us know if you need more information or how it went.
Oct 05, 2006 | RCA P61960 61" Rear Projection Television
RCA P52960 52" Rear Projection Television Logo
198 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
