Question about Whirlpool GHW9400 Front Load Washer
Leaking water from bottom of machine and giving error messahe
    Problem Solver:
  • 7 Answers
Ya this seems good n better then the others
Posted on Apr 27, 2010
Lg top loader ie error message, fills ok, but water running out of bottom of machine
Hi IE means Inlet Error. The machine thinks that it is not filling (as a certain time has passed without reaching level it wants).
This makes sense if water is running out the bottom.
You will need to find the leak. Maybe the tub to pump hose, or the drain pump itself. Once you stop the leak and the machine can fill in the correct amount of time, you shouldnt see the IE error any longer.
Cheer
Jun 01, 2014 | LG WD-1045FH Front Load Washer
My Siemens IQ700 displays error code E23. I switched off and on again and still the E23 is displaying. What should I do now? Thanks!
You basically have water in the sump at the bottom of the machine, and the sensor gives you E23 error to stop a 'flood'.
Unscrew the back cover and dry it with towels and then a hair dryer and you should be fine...
You must have added extra water and overfilled the tray, or there's a leak somewhere if the problem persists.
Oct 18, 2013 | Washing Machines
Westinghouse dishwasher error code i30
Not familiar with this particular model but the indication is for water in the very bottom of your unit. Either due to a leak or a faulty switch. A quick leak check is to tip your unit to the side and see if water dribbles out of the bottom. Side needs to come off and either find and fix the leak or replace the switch itself. If its just a leak and you tip the water out it will actually work till the leak fills up again.
Jul 08, 2013 | Westinghouse Dishwashers
Displays E1 code. water is on
Hi there Dolly, error code E1 relates to water leaking. Its the code the machine displays when the flood switch in the bottom of the machine activates. The flood switch activates when the bottom of the machine gets filled with water from a leak. I surgest you have a look underneth the machine for signs of water. I hope this helps regards Gary.
May 04, 2011 | LG 24 in. LD-12BS6 Stainless Steel...
Leaking water from the bottom
Hi, If you coukd get me a model #, I could look this up and give you ideas om how to locate pump to see if it is leaking.
Vic
May 30, 2009 | Washing Machines
IE error code, machine keeps on draining
It sounds like the flood switch in the bottom of the washer is activated. check for water in the base as the machine if maybe leaking. This is a Dishwasher?
Feb 24, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Leaking
This machine has two removable front panels. At the bottom of the unit are two (2) 10mm bolts. Removing these bolts will give you access to the working parts since this is an inspection plate, The upper panel : There are two (2) 10mm bolts located at the bottom corners. Remove these bolts, pull the bottom of the panel toward you to release the top latches. This will give you full access to see where the water is coming from. I suspect a leaking pump but cannot rule out a bad tub seal.
Jan 08, 2008 | Maytag SAV515DE Top Load Washer
Shots are small, and water leaks from bottom of unit
You machine has an internal leak and this is why you shots were getting smaller and smaller. The more time goes by the more it leaks, hense, the reason for smaller shots.
You should have someone look at your machine.
Saeco Service Center for New York
www.cerinicoffee.com
Nov 21, 2007 | Gaggia Syncrony Espresso Machine
LG Dishwasher
according to the manual that i have just downloaded from the net,E1 code means.water leakage in Hose connections.
.water is leaked by damages
hope this helps,
keith
Sep 20, 2007 | Dishwashers
Whirlpool GHW9400 Front Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
