Question about Hotpoint First Edition FEW12 Front Load Washer
Hotpoint electronic 800 deluxe 9526 wont spin
My Hotpoint lets water in and then wont spin at all, i've checked the belt but it is fine.
Any help please
Rob
gittos73
  • 244 Answers
SOURCE: hotpoint washing machine belt come off
u need to take the lid off and keep the small panel off now 2 ways u can do it 1)undue the botls on the motor just enough so u can move the motor now put the belt around the pulley wheel by placing your hand through the small panel once done put the belt around the motor wheel now last thing pull motor so it tightens the belt and tighten the bolts on the motor 2)place the belt around the wheel on the motor now with your other hand put the belt on 1 side of the big pulley wheel and hold it in place as u turn the pulley wheel it will slide on but with tension once on spin the pulley wheel and it will line up the belt
Posted on Jan 27, 2008
SOURCE: Hotpoint WMA50p won't spin
Had same problem today with our machine. Brushes looked OK (although one appeared a little shorter than the other).
After removing and re-fitting the brushes, motor worked fine - suggesting that it was the brushes afterall.
Now looking for replacement brushes
Posted on Mar 27, 2008
  • 1462 Answers
SOURCE: hotpoint 800 de luxe 9526
at rear of machine, remove the small panel at bottom. you will see a large diameter hose going from bottom of machine to the pump. remove this hose at the machine end and the filter is inside. take out and clean. careful - water will come out is machine has not drained
best to disconnect from mains of course
Posted on Aug 05, 2008
SOURCE: REPLACEMENT BUSHES
i managed to find a lip underneath the carbon bush
lifted it up slightly and slid out the plastic casing to the side
then replaced the new ones
Posted on Sep 22, 2008
john2072
  • 5 Answers
SOURCE: not spinning out water of Hotpoint WF 560 washing machine
pump problems
Posted on Jan 17, 2009
Door stay locked after finished washing hotpoint w/machine ref 9526
See if you notice any water still inside the washing machine, if so run another spin cycle to try and remove it as it will not open if there is still water inside.
If you don't see any water inside, try unplugging it and letting it cool off, the lock should release after this
Jul 03, 2016 | Hotpoint Washing Machines
Hi, My hotpoint wm 25 wont spin? Brushes are fine. Help!
Why no spin?..Is the water fully pumped out, is it out of load balance? This happens when too few items are in the drum the machine senses this and will not spin.......Hope this of some help
Jan 08, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Electronic 800 WM 12 Aquarius won't rinse
If it won't rinse because it won't fill, it's most probably because the cold water inlet valve is faulty. Many machines will only rinse with cold water....No cold water.....No rinse!! Not a big job.....Nomess
Apr 13, 2010 | Washing Machines
Hotpoint electronic 800 delux 9525. can not open the door help
Make sure there is no water left inside washer.
If it still will not open, then you need to remove the top cover, and release the door manually from inside at the front where the door latches in.
Can be caused by the belt being off the pulley,or a broken ****** assy.
Jan 12, 2010 | Hotpoint Washing Machines
Hotpoint wma76 stops and displays ON
Could be rinse water valve ..Faulty Solonoid coil
Nov 10, 2009 | Hotpoint WMA76 Front Load Washer
REPLACEMENT BUSHES
Sep 21, 2008 | Hotpoint 18 in. DC28 Slim-Line Built-in...
Hotpoint 800 de luxe 9526
Aug 05, 2008 | Hotpoint 18 in. DC28 Slim-Line Built-in...
Washing machine won't spin
check the pressure switch the unit wont spin unless it knows all the water is out of the unit
May 28, 2008 | Hotpoint Aquarius WF220 Front Load Washer
Hotoint 800 delux 9526
get an engineer to do it , much easier , its not hard but for a novice fiddly . an enginner should also bed the new brushes in with a special stone ... i normally charge about 40 pound including parts .
Mar 11, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint First Edition FEW12 Front Load Washer Logo
242 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
