Question about NEC AccuSync 900 19" CRT Monitor
Large screen everything got large
  • 38 Answers
Try clciking auto on screen or downlaod grathics drivers eg intel grathics , then u can change from there
Posted on Apr 27, 2010
Everything went to large print
Go to settings - scroll down to accessibility and then switch off large text.
Alt - press your home button 3 times quickly and press the zoom button
Apr 03, 2013 | Apple iPhone 3G
Enlarge text on screen
A. right click on desktop > properties > Appearance and choose in the lowest entry large or extra large fonts
B. Change screen resolution desktop > properties > settings. Go to screen resolution
C. in a browser (i.e. IE) under view you can either choose "Zoom" (for everything) or "Text size" (only text)
Jun 06, 2010 | Lenovo ThinkPad X200 Notebook
Adp242 do not wash everything remain stain the
Make sure that water is entering the machine as the first operation--open the door to check shortly after you hear the wash cycle come on. Water should be dripping from everything. If there are several inches of water sitting in the bottom, but nothing is wet, and you have heard the pump running, you will need to tear down the lower spray arm assembly down to the deck to clean the large intake screen at the bottom. Keep track of orientation and placement of each piece removed. Remove the large screen and soak it in hot water/white vinegar/detergent solution for an hour or so, then scrub the screen to help remove deposits. Inspect all holes in the deck surface for plugging--a wet/dry vacuum will remove most of this debris. Reassemble everything in reverse order. Inspect the spray arms for any plugging of holes and for any split seams. With luck, this should fix your problem.
Nov 28, 2009 | Washing Machines
Water does not completely drain from dishwasher
Remove everything from the lower spray arm down to the deck. Keep track of everything that is removed: in what order, and which way to reinstall. Pay particular attention to the large screen at the bottom for being plugged as well as the several ports in the bottom deck. Check plastic parts for warping or cracking. Soak the large screen in a solution of white vinegar and hot water (1 to 5 parts vinegar to water) with some detergent added for about 1 hour. Because the water drain is a timed event, restricted water flow will prevent emptying all of the water.
Sep 06, 2009 | GE 24 in. Profile PDW7800 Built-in...
Page is too large on the screen
click and hold left control button then use ur mouse wheel to minimise or maximise th script
Nov 23, 2008 | Toshiba Satellite A105 Notebook
Screen
If the inside screen and the outside screen is blank, the possible problem is the LCD flex cable. But if the outside sceen is on
but the large inside screen is blank. The large screen could be defective.
Aug 11, 2008 | Motorola Mobility V300
I850 Large Screen problem
The backlight on the phone has probably burnt out. The only way to fix this problem is to get the flip on the phone replaced. This will work almost 100% of the time.
Jun 07, 2008 | Motorola Mobility i850 Cellular Phone
VX8100 cracked large LCD
I just received a replacement screen, purchased on ebay. Will be installing it in the morning. look at http://repair4mobilephone.org/disassembly_lg.html
got part from EZ Elektronixx of Santa Clara. eBay seller ID is bureenz
Oct 12, 2007 | LG VX8100 Cellular Phone
NEC AccuSync 900 19" CRT Monitor Logo
42 people viewed this question
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
