Question about GE JSP34 Electric Kitchen Range
Stove too hot
The eyes stay really hot even on low
  • GE Master
  • 43,501 Answers
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4404788-electric_oven_problem_oven_will_not_shut
heatman101
Posted on Apr 28, 2010
Cook top indicator lights stay on long after it has cooled off. The largest cook circle sometimes doesn't reduce heat when the dial is changed
Cook top indicator light will stay on as long as the stove is hot I think. Also, the burners don't heat real steady? or evenly or true to their settings even, quite often. they also take a really long time to cool down as well as to adjust temperatures, so it may just be that it is taking an awfully long time for it to cool down in order to adjust.
Apr 04, 2015 | Cooktops
On my electric stove, one of the burner caught on fire, and now the indicator light stays on even after the stove is turned off
If the light remains on, that would indicate the circuit was damaged. The light goes on when the circuit is complete. This usually happens when the burner gets hot. If it caught fire, then the stove is registering it as hot all the time.
Elisa Jed ' http://www.atlasappliances.com/en/pg-kitchen-appliances
Jul 07, 2014 | General Electric Stove/Oven/Range Chrome...
Getting hot stove
Replace the switch for that element. Be sure to unplug unit beforehand.
Nov 06, 2017 | Hotpoint RB787 Electric Kitchen Range
Hot plates go red hot even on low setting on my westinghouse avondale 529 stove
The hot plate needs a new thermostat. When thermostats go bad, there is no control of temperature and they stay on high. The circuit remains closed, not allowing any cycling of power, which regulates the temp
May 16, 2010 | Ovens
Indicator light stays on when eye(s) are turned off
The stove indicator light normal stay on until the burner cools off, and then the indicator light goes off, this is to prevent someone from touching the burner, alerting them that the stove is still hot.
Dec 11, 2009 | Kenmore Kitchen Ranges
Oven wont light unless you turn on a stove eye and
Sound`s to me you need a new hot surface ignitor. Sorry to hear you may have changed the valve & regulator for nothing, but that happen`s quite often when you get the symptom`s you`ve described, I`ve even seen tech`s. do it. The reality is 9 times out of 10 when a hot surface ignition gas/lpg oven won`t light it is the ignitor.
Pick up part number 74007498 for approx. $40 and you`ll be cooking.
Hope that help`s. If so please take a second and rate the solution I provided here at fixya for you.
Good luck.
macmarkus :)
Dec 05, 2009 | Maytag Kitchen Ranges
GE Electric Stove Broiler doesn't stay on
If the door is closed the broil element will cycle off an on normally. It should stay on most of the time if the door is in the broil position (partially open). If your range has an electronic control it will probably also have a hi and low broil setting. On low broil it will cycle off an on even with the door open but more with the door closed
Dec 31, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
I have a Inglis smooth top stove, model IME 8230. One of the front has a dial for single/dual --for quick heat up. It was working fine, til couple of days ago, it suddenly went haywire. When I turned it...
The swich for the burner is bad and needs to be replaced. The glass will be fine, but unless your just boiling water you wont be abe to use it until you replace the switch.
Apr 08, 2008 | Kitchen Ranges
Problem with left front eye
This sounds dangerous! you can lift the top of the stove to access the burners source of electricity. Unplug one of the hot wires to the bad eye and conpletely cover it with electrical tape. NOTE: This is a temporary fix. consult Maytag Support @ 1-800-688-9900 For a better long term solution! Have a great day, Alan
Dec 25, 2006 | Maytag MER6772 Gemini Electric Kitchen...
GE JSP34 Electric Kitchen Range Logo
114 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
