Question about HP Pavilion dv9000z Notebook
Wireless detection fails when you plug the laptop in again
Anyone have a problem where you plug the computer back in and the wireless shuts off? Mine does that all the time. Every driver is updated and I can't get it to work. Tried everything tech support said to try.
  • 198 Answers
Have you tried going to start, run type in 'services.msc'?
scroll down to wireless zero config
double click
make sure it's set to started and auto
Posted on Apr 27, 2010
Acer Aspire 5733 Wireless connection lost
Check the wireless router and high-speed modem.
If the two are not powered on, or if the Ethernet cable connected the two is not completely inserted into both connection ports, you are unable to access the Internet on the Acer Aspire One laptop computer.
Activate the wireless Internet connection on the laptop computer.
Right-click the wireless icon on the desktop, then choose "Enable" from the pop-up menu.
Without activating the wireless receiver on the Acer Aspire One, the laptop is unable to detect any wireless network.
Select the appropriate network you wish to connect to.
Your computer may be attempting to connect to a different Internet connection, preventing you from access the network you desire. Right-click the wireless icon, select "Search for available wireless networks," then choose the network you want to access.
Restart the computer.
The system may have booted and failed to detect the wireless receiver. Restarting the computer corrects this issue.
hope this helps
Sep 13, 2012 | Acer Aspire 5733 Laptop
Packard bell - wont recognise wireless adapter
i have the same problem, mine wont even recognise the adapter at times.
Dec 14, 2011 | Packard Bell Computers & Internet
I had to put my computer back to factory settings and now my Belkin wont go on wireless.It does work if i plug cable in.Is there anything i can do?
HI,
I see you set Windows back to defaults as you mentioned and now your Router will not go Wireless.
First Restoring Windows Back to Factory Defaults will not reset your Routers Settings to Defaults together with Windows.
So Most Probably the issue is since you restored windows back to factory defaults you may need to install the Wireless Driver again on the Machine / Computer to make your computers wireless card work again and be able to detect and connect to your Belkin Router.
try a difefernt device that can connect wireless to your Router or maybe a different Laptop to see if the Belkin is working fine wireless.
If any other Laptop will not detect the Belkin then try turning the Wireless Radio ON again in the Router Settings of Belkin.
But I suggest to check all your system drivers if installed for it to be wireless capable again on the issue, Restoring Windows back to Default will not change anything in the Belkin Router. I believe this is a Driver issue on the Wireless card of your Computer.
You mentioned the system does work if plugged in Wired right, check your drivers install every driver that needs to be installed from the Manufacturer Website of your Computer for proper and compatible drivers.
Have a nice day.
Aug 23, 2011 | Belkin N Wireless Router wireless router
Have 2 computers connected to Netgear WGT624NA router via ethernet connectors and have operated well for over a year. Now have gotten DSL and have run phone line to modem and via ethernet cable have...
Have you tried to reset router. It has to be done in order.
1. unplug router
2. unplug modem
3. shut down computer and restart after waiting 1 min
4. after restarting computer plug power back into modem and wait for all the lights to start blinking
5. after the modem is working plug power back to router and plug in the computer with ethernet cable and make sure you have internet,
6. try to link up with wireless,
If this does not work you will have to setup the router for wireless if it is att wireless you will have to call them to give you the password to set it up.
Jan 10, 2011 | NetGear WGT624 Wireless Router
Get connection to internet
Connections to the internet can be tricky. It depends on how you connect- modem, lan,or wireless. If wireless, is it at home, or at a hot spot. If you are connecting at home, try shutting off your wireless switch on your laptop.(if you can), then shut off (unplug) your router, plug it back in, and then plug in the lan (ethernet) cord, and reboot. It should find your connection. You might also go to control panel, then to internet options, then to connections. See if there are any listings in the box. You might have to change things if there is one that says "use this connection first" or something like that, if you are trying to connect otherwise. Then go to lan settings, and uncheck "automatically detect settings". For a modem you need to make sure the modem is installed in devices (in control panel) and then make sure the software, from your internet provider, which will tell your laptop which number and how to connect, is installed. If you are using a wireless connection, do as instructed above and uncheck "automatically detect settings." and make sure your wireless switch is on. Occasionally there are conflicting connections, or possibly unsecure wireless connections "remembered" in your system that may have changed. Right click on your wireless icon on bottom right, then network and sharing center, then manage connections. You may want to delete the ones you don't recognize, or the ones you don't use anymore, as you can always connect again if you want to. If you are having trouble connecting to a particular connection, remove it from that list and then try connecting again. I know a lot of this sounds difficult, but like I said, connecting to theInternet can be tricky.
Nov 23, 2010 | Sylvania Computers & Internet
Cant access internet through wireless network.
How do you know your notebook is connected to your wifi AP? Did you try pinging the gateway? If not, open your command window & type "ping 192.168.0.1" (put in your own gateway address.) If you get replies, then ping something outside of your network: "ping 4.2.2.2" (this is a verizon dns server). If you get replies, then "ping yahoo.com". If it does not fail at any of the above steps, you don't have a connectivity problem. If you fail any of the above, then report back & we'll continue the troubleshooting.
Jun 08, 2010 | Acer Aspire 5536-5224 Notebook
Acer aspire 5730zg xp wireless problem
download a separate wireless driver
Oct 12, 2017 | Acer Computers & Internet
Hi there, my computer cant detect my wireless mouse, even thou the curser is in the screen. but it can detect my keyboard. i did change battery, plug out the wireless antenna, keep pressing the connect...
to know if your windows keyboard and mouse controller is working try to use first a cabled keyboard and mouse, if you find it working try this steps.
first, try to remove the wireless usb device which your keyboard and mouse is connecting to, try to use another usb port from your computer.
second, your wireless device comes with a cd installer, try to reinstall the program of your wireless device
and then try again
Jan 05, 2010 | Computers & Internet
Wireless button (and wireless in general) does not work
ok. unplug your computer and remove the battery. leave it that way for two full minutes. then put the battery back in and plug the computer back in. These steps reset your computer.
now open it up and crack it up using your usual method. It should be fine. if not get back and I will take you through the steps of making it recognize your wireless modem again. hopefully this will not be necessary.
Aug 14, 2009 | HP G60-120US Laptop
Aspire 5315-2153 wireless or not?
I bought the same Acer at Wal-mart and it IS wireless,,, Sounds like Acer gave you the run around. If you already had a wireless router, then why on earth would you think you needed to purchase another one??? even if Acer told you to. That just doesn't make sense. What kind of router did you have to begin with? (Make and model please) Are your other computer that you have on the internet connected with a cable? If so they are not wireless.
Aug 02, 2008 | Computers & Internet
HP Pavilion dv9000z Notebook Logo
32 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
