Work Pro 416 copying issues
I am trying to copy a legal document...when I copy it the document prints out with a top margin. Can you help?
    President:
  • 2,072 Answers
Make sure your tray settings are correct. most likely though the paper tray lead edge registration has to be set. Make sure the tray is not set to 8 1/2 by 11 or A3 paper.
Do you want me to send you the info? Or if you have a maintenance agreement place a service call since that has to be done in diagnostics.
But I can forward that procedure to you if you provide an E-mail address.
Posted on Mar 24, 2008
My Kyocera fs-1118MFP is cutting off top margin of all documentscopy or print. How do I fix, plz help.
I don't know that machine but generically, the description suggests a faulty drum or fuser unit...
How many prints or copies since either or both were changed, please?
Sep 02, 2016 | Kyocera FS-1118MFP Laser Printer
My workcentre pro 416 is printing all copies as all black.
It sounds to me like the High Voltage Power Supply, Biasing Ground, or Blanking Exposure Lamp may be a fault. You could also have a problem with the Digital Scanner unit. But, there is nothing that you can do yourself: EXCEPT: If the unit takes a Toner Cartridge that includes the drum, I would try replacing that first. Then if no joy, your going to have to call out the big guns. Good Luck!!
Jun 13, 2012 | Xerox WorkCentre Pro 416 All-In-One Laser...
HP Office jet plus 8600+ - supposed to print legal but does not!!?!
The printer set up procedure may reveal there is no provision for legal size printing.
May 26, 2017 | HP OfficeJet Pro K8600 Printer
Legal size copies
Your printer doesn't support Legal size to Scan and Copy, you can scan/copy it by reducing the size of the paper from the menu. 10% will fit since the actual paper size supported by your printer is 8.5X11.7inch while the legal size is 8.5X14inch. Good luck. For more info check out here : http://h10010.www1.hp.com/wwpc/us/en/sm/WF06b/18972-18972-238444-12019-3328086-2511708-3643610-3643611.html
May 15, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
Can't print proper legal size documents
please you aply the comand control p and you go the property select
and ok. you so the paper select and ok and you so the paper size
in select legal is ok and ok
and aply print legal size print ok
Sep 15, 2009 | HP LaserJet 1018 Printer
How can i copy a legal document with cannon MF3200
you can print legal document through print command go to print property and give command on legal size.
but you can't scan legal document in single go.
if it urgent to scan in legal scan it in 2 parts then join using some software like corel draw or word.
Jun 10, 2009 | Canon MF3110 All-In-One Laser Printer
Thin black line on Xerox 4011 laser printer
Does the same thing occur with a different document.. Because it is not repetative, it leads me to believe the line is being drawn at the direction of the software. Try printing a test page, and see if the line appears. If not the issue is from within the word processsing software. It almost sounds like a legal template for a pleading..
Nov 21, 2008 | Computers & Internet
Printing document
Did you change the top margin setting?
Make sure that the paper size is correct in the printer settings of the control panel when you print. You have to tell it what size paper you are printing on.
Aug 15, 2008 | Sharp AL-1551CS Copier
How do I copy a legal size document?
You need to change it in the menu, it's stopping because once it reaches the letter size the sensor detects that there is still paper there and jams.
Oct 16, 2007 | HP OfficeJet 6110 All-In-One InkJet...
Legal Sized 2-sided Copies through Automatic Feed
Does the copier print correctly when copying off the glass? I suspect that the document feeder has been set up to feed other paper sizes eg A4, A4R. Because of the conflict between sizes the copier adjust the image.
Oct 05, 2007 | Canon imageRUNNER 5000 Copier
126 people viewed this question
k24674
jasbo
jasbo
