Question about Hotpoint Ultima WF860 Front Load Washer
Test keeps coming up on the washing machine - Hotpoint Ultima WF860 Front Load Washer
    Problem Solver:
  • 7 Answers
No this is bad
Posted on Apr 27, 2010
Toshiba 10kg washing machine display error code E7, it can't wash but can spin so what's the problem? Can anyone help please???
try reset the machine's control board. try this step and bear in mind this may working/not working:
- plug in and power on
- press Rinse, Preset and Water Flow simultaneously, keep pressing and release after lights come on.
- wait about 5 second then press Cancel/Off
- unplug about 5 minutes
- plug and power on, test if it works
good luck
Sep 28, 2017 | Washing Machines
Hotpoint wma32pr door light keep flashing and no wash
1) test the lid switch for open
2) test the door switch for open too
3) see the diagram attached, any switch faulty can not START the motor.
God bless you
Jun 19, 2012 | Washing Machines
My machine keeps bleeping to tell me the cycle is finished but will not begin another programme ?
1. Set the cycle knob to any "X" (reset) position
2. Press and hold the Pre-wash and the Start buttons at the same time. While still holding these buttons, turn the unit on by pressing the On/Off button
3. Keep holding the Pre-wash and the Start buttons until the digital display comes on (about 5 seconds)
The digital display will show 00 for no faults or will show a fault code.
To end the test program turn the washer off at any time
Let me know what error codes come up, if any.
Nov 25, 2010 | Bosch Washing Machines
Washing machines keeps stopping half way through a wash and error code fo4 keeps coming up
The F4 error code on your washer indicates a problem in the electrical circuits of the washer... and not end-user repairable.
This problem requires a technician to test the wiring circuits to diagnose the problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Nov 03, 2010 | Washing Machines
I have a hotpoint ultima wf860 washing machine when trying to do a wash it just keeps saying test what is wrong with it ?????
SomeHotpoint's are designed to go into test mode when the start button and the on/off button are pressed at the same time. If you are stuck in Test mode, simply hold the start button down until it comes out of test mode, then hold both the start buttons and the on/off button down until you see 'D:end' (or similar message). Now try a normal wash programme again and hopefully it should be fine. If it goes into test mode by itself, then it may be an indication that there is a real fault, or a faulty programmer board. hope this helps.
Sep 26, 2010 | Hotpoint Ultima WF860 Front Load Washer
The machine keeps showing test. it won't go onto any other programme. it keeps running through the test programme then stops, i then try and put it to wash and it will come up with test again.
http://appliancejunk.com/ge/washer/31-9103.pdf OK, to help you, I have found you your service and troubleshooting manual. Below is a DIY self help. washer link, this will help you to troubleshoot your issue. http://www.acmehowto.com/howto/appliance/washer/washer.php
You should try to reset it, but if that doesn't work, you may find you have a main controller board failure.
Jun 06, 2010 | Hotpoint Aquarius WD640 Front Load...
My washing machine keeps coming up test can you help me
Hello Lainy34,
Give this a try, turn off then back on. When on appears on the screen press and hold the "start/cancel" and the "on/off" at the same time until "D:off" appears in the display. It should be back to normal after that. Hope this fixes it for you.
Thanks,
edgin96
May 12, 2009 | Hotpoint Ultima WF860 Front Load Washer
I have a bosch washing machine. The tumble lights are blinking and I cannot get the machine starting a new program
Restart the machine and repeat the following procedure to reset the machine to original factory settings.
Enter the test program by:
To end the test program turn the washer off at any time.
Post the results.
The result would be a fault code which indicates the error. Will await your further comments.
Apr 10, 2009 | Washing Machines
Washing machine
Pressing and holding the two centre buttons ie on/off and start/cancel together for a few seconds causes the machine to run in 'test' mode. Doing the same again puts it back to normal wash.
I nearly called an engineer once because my daughter causes it all of the time!
Sep 28, 2008 | Hotpoint Ultima WF860 Front Load Washer
Test on washing machine
yes try pressing the on/off button and start/cancel button at the same time
May 26, 2008 | Hotpoint Ultima WF840 Front Load Washer /...
Hotpoint Ultima WF860 Front Load Washer Logo
126 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
