Here's a link to the Lexmark website to guide you on how to install/replace the cartridges on your Lexmark printer. http://bit.ly/cevMS4. The printer shown may not look exactly like your printer, however, the steps are the same. But, there are cases that the cartridge carrier doesn't move to the center when you lift the scanner unit. If that happens, unplug the printer from the power source. With the scanner unit lifted, hold the solid white tape you see inside the printer. The other end is connected to the ink cartridge carrier. Slowly drag the carrier to the center to remove the cartridges and install the new ones. Close the covers. Close the scanner unit. Plug printer back to power source. Let it print the alignment page to align the cartridges. Hope this helps.
Go to "Lexmark solution center", then go to maintenance, then "install new cartridges".Check "No, this is new" option on cartridges and ink level will reset.
take out the cartridge , turn off your printer and take out all the cables behind your printer and wait for 5 minutes and put everything back in.. if the same error shows.. im sorry but your printer needs to be replaced.
The BEST slution is GENUINE original cartridges. There is an eclectronic communicator on the cartridges and that "TELLS" the printer thet the current cartridges are not GENUINE ones. Untill you have replaced these cartridges with the GENUINE ones you will always get these error messages
What you need is to reset the ink level: 1) Goto the Lexmark Solution Center application. 2) Press button Maintenance>Install a new print cartridge, follow the instruction on screen. U may then have your new full ink level. Note: u only can reset to full level, cannot customize the level by your own. Hope this help.
The front panel is hinged at the bottom so grab the top and pull towards you. Under that is a protective cover, the one with the 2 paper guides. towards the bottom of that there is a hole in the middle. Put your thumb in it and lift the cover up. Your carrier for the cartridge is under that. Please Rate!
http://www.lexmark.com/publications/eng/x125/index.html
That link will give you the manual..just in case you need it.
your own.
Hope this help.
Swith on the printer. Open the printer top cover. It is called flap.
Now press upwards the cartridge's top end. and lift up that. now take
the cartridge out. insert the new cartridge the same way took the
cartridge out. put the cartridge layer down. Now close top cover.
